2012 prius III both high and low beams stopped working at once
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Direwulff, Dec 18, 2017.
Tags:
  1. Direwulff
    Direwulff Junior Member
    Hoping someone has an idea. My GF is reporting that both high and low beams stopped working at once on both sides. Foglights/driving lights still work though. Any thoughts would be greatly appreciated. Is there a fuse that controls both sets of bulbs?
    pulled fuse 20 and now high beams work but still not lowbeams. Fuse diagrams I am finding online seem to be different then what shows in the panel
    #1 Direwulff, Dec 18, 2017
    51,805
    not sure, but it would be listed in the o/m.
  3. Sippy Theut
    Sippy Theut New Member
    Virginia
    This happened to me several times last year. Real fun with an hour drive home in bad weather. (They always went out in snow or rain)
    Anyway, I had non OEM bulbs in, they continuously blew. I put in OEM bulbs and no problems in the last year.
  4. bisco
    51,805
    dang aftermarket parts.:mad:
  5. icyrius
    icyrius Active Member
    238
    114
    Florida, USA
    2014 Prius v wagon
    I received a letter from Toyota this week describing this problem. The letter says it is not a recall, but this is a problem that they are aware of. They also mention if you had to do any repairs, they would refund those expenses. I had the low beams blown out too, but unfortunatelly I changed them myself and lost the bill to clain for any repairs. I suggest you call the dealership and ask about this. This repair is supposed to be at no expense.
    Sippy Theut and bisco like this.
  6. bisco
    51,805
    what did you change, the bulbs?
  7. icyrius
    238
    114
    Florida, USA
    2014 Prius v wagon
  8. bisco
    51,805
    what causes them to burn out, defective, or something else?
  9. CR94
    CR94 Senior Member
    2,687
    1,165
    Northwestern S.C.
    High voltage
  10. bisco
    51,805
    so just replacing the bulbs means they will burn out again?
  11. CR94
    CR94 Senior Member
    2,687
    1,165
    Northwestern S.C.
    Yes. Long-life bulbs should last longer.
