Brakes wearing unevenly
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by The Phoenix, Dec 27, 2017.
  1. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    Brake fluid is hygroscopic and collects water (moisture).
    The fluid will be compressed during braking und will heat up under this pressure. At long enough downhill passages the heat will be high enough to vaporize the water contained in the fluid. While the fluid is incompressible, the vapor is. That means the brake pressure will decrease rapidly at boiling point and then the brake force, too! (Boiling point of new brake fluid is much higher than the b.p. of water, it won't vaporize itself.)
    At least the front brake pistons of the gen 2 are made of plastics, so they won't rust. But the rear pistons will rust over the time. The will press the pads at the disks/drums, but they won't release proper, resulting in more wear.
  2. Patrick Wong
    18,200
    6,491
    I would not worry about that because the brake fluid typically is not subjected to the same temperature extremes as a normal vehicle, as most of the braking effort is via regen vs. the friction brakes.
  3. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    But moisture is still absorbed into the brake fluid. And on emergency braking (basically) all braking just happens with friction brakes. And bad brake fluid can cause other problems too.
    And if you have 10 year old car with brake bleeder that have never been opened that has driven on salted roads it’s super hard to open the bleeders when/if you need to.
  4. Mendel Leisk
    40,265
    Toyota Canada's seen fit to include brake fluid change in the schedule, for all cars they sell, from 2012 onward. IIRC it's 36 months or 48K kms (30K miles).
    I'm a little nonplussed, by the disinterest in following the Toyota proscribed brake maintenance interval. I appreciate it's somewhat overkill, but maybe look at it as akin to getting your teeth scaled every 6 months, vs the alternative?
    Tri-yearly or 30K miles is certainly not onerous, for decent brake inspection. I wonder what's the root of the malaise: dealerships are downplaying the need for it, too busy pushing fuel injector cleaning and other crap?
    MickyMatter likes this.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    No just stating the fact.
    I went to the dealer to have my brake fluid changed. The brakes work fine. I was told they would not change the fluid as it has caused many ABS units to fail on a G2. They do not recommend having it changed anywhere. Unless as Pat said the ABS is replaced also.
    Pads look good as do the rotors. What would you have me do?
    Cue Honda reference.
  6. Mendel Leisk
    40,265
    My wife and I managed to bumble through a brake fluid change, in about an hour, with the section from the Repair Manual, and watching @NutzAboutBolts video. Maybe easier with 3rd gen, not sure.
    NutzAboutBolts likes this.
  7. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I have really enjoyed reading all the responses to my post. Thank you very much. Through some discussions with my mechanic we are confidently speculating that the caliper it self may not be the cause but indeed the slider pins. Yes I have lots of wear on the left rotor. I have already purchased two centric rotors and the super duper Akebono pads (ASP 822), and will be replacing the parts this Saturday. My follow up question is why would my left side wear so severely while my right side seems fine? Any ideas are welcomed, thank you
  8. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    I would think that such a difference is most likely just luck of the draw. One slider pin got more jammed up than the other slider pin due to corrosion and loss of lubricant. Other thought is that generally the left side of the car is slightly heaver than the right for most driving (due to having a driver only in the car) and therefore the brake gets worked just a touch harder than the other side (I can't confirm this - just speculating).
    This effect can certainly be seen on cars' tires that have never been rotated at the end of their life - the driver's side front tire will be bald, the passenger's side will have a mm or two left, and the rears will still be at 40%.
  9. valde3
    2,002
    746
    Finland
    That was already answered at the first reply to this tread. That side just happened to seize. After it’s seized it wears fast. One side will always seize before the other. Unless you service brakes often enough (if you do then they wouldn’t seize).
    Kevin_Denver and Mendel Leisk like this.
  10. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    Thank you for all the input I did change the pads and rotors this past Saturday, and took apart the slider pins on both side, funny thing was none of them were completed seized. One of the two pins on the left side came out a little hard but there was still some lubrication around all the pins. So still no real answer to my question or cause for that matter. Everything was lubed up generously and put back together. The right side was better but did show wear, I drove on those brakes for 71,000 mi, and I dont know when they were put on before me. I've included a few pics of the left and right side before replacement and the left side after replacement 20171230_100904.jpg 20171230_101038.jpg 20171230_101052_001.jpg 20171230_103551.jpg 20171230_115157.jpg
    #30 The Phoenix, Jan 3, 2018
  11. Mendel Leisk
    40,265
    Wow, that's one done pad:
  12. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    It sure was Mendel, I was just trying to make it till Saturday without losing parts or wearing through to the fins of the rotor. I definitely got all I could out of that pad
  13. padroo
    padroo Senior Member
    2,763
    2,251
    I have a brake caliper theory that I cant' prove. Here it goes. As the brakes wear the piston travels out of the piston bore. After it extends to a point where it doesn't move as well because there isn't enough material to keep it in alignment. Here is an example, you take two pipes, one larger than the other but the smaller one will fit inside the other one. Start separating them and when they are close to being separated try to push them back together and they bind.
    Back to brake pads, this would happen about the time your pads needed changing.
    MickyMatter and Mendel Leisk like this.
  14. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I like your theory Padroo, and information helps feed my curiosity. Hopefully there is no major underying issues and that the change and lube has remedied the situation, the brakes are working nice and smooth, and remember I drive deliveries and I'm using the pads recommed for law enforcement and fleet vehicles:p
  15. Mendel Leisk
    40,265
    The piston extension is only about 8 mm though. But yeah, could make the difference.
  16. MickyMatter
    260
    168
    Germany
    Yeah, and the small colored area indicates, that very much heat occurred at least one time. Hopefully it didn't affected the piston. (The front ones are made of some plastic.)
    But if the piston moved back in for enough space for the new disk and pads there shouldn't be any problem, I think.
  17. MickyMatter
    260
    168
    Germany
    When changing wheels, you can have a look at the pads thickness. And if you have a micrometer screw gauge, you can easily check/compare the disks, too.
  18. padroo
    2,763
    2,251
    Every time I remove my wheels I always look at brake pads thickness and the condition of my rotors.
    Aftermarket rotors are cheap, I just replace them. I have never used a micrometer to check rotor thickness but have checked run out but not on a prius.
    I have only ever needed to turn rotors twice and the second time they were worse than before I had them done
    I like new ones.
