HELP.....My Prius won't shift to Drive or Reverse, stays in neutral, Red Triangle on
Discussion in 'Gen 2 Prius Technical Discussion' started by Samantha33, Jan 1, 2018.
  1. Samantha33
    Samantha33 New Member
    wichita, ks
    Hello my fellow Prius owners,
    First let me wish everyone happy new year, I hope everyone a year full of success and happiness.
    I have an 05 Toyota Prius with 143k miles on it. two days ago I went to the store and parked the car, when I was getting ready to leave, I press start, put in reverse, nothing happened, it would not switch from neutral, the "READY" light on the display did not come on. I tried and tried numerous times with no success. I stayed in the parking lot and did some research on my phone what can be the issue, someone said to replace the 12v battery, since I was a walking distance from an O'reilleys, I went and dumped almost 200 buck on a brand new prius battery, put it in, it started. I went home, the next day it starts fine, after 10 mins of driving the red triangle comes on along with "temp low" light (no check engine light). I stopped the car and turned it off, then tried to turn it back on again and did the same problem as before.
    I think the main battery is working fine as I see it recharging and recharging at a healthy rate. I am really not sure what I else to do here. I know there is a lot of knowledgeable people here, pleaaaaaase help me.
    Thank you.
  2. Prodigyplace
    12,569
    11,782
    Central Virginia
    The red triangle says there are one or more trouble codes that can be read by the dealer. Without those codes, any other advice would be guessing, which can get expensive quick.
    After the car has sat for a while, what is the voltage of the 12 volt battery, before turning the car on? A weak 12 volt battery can confuse the computer systems. The 12 volt battery, if marginal, is a rather inexpensive "guess" at a fix.
    Raytheeagle likes this.
  3. Samantha33
    wichita, ks
    thanks for the reply, this is a brand new battery, I just got it yesterday
  4. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    If you're still on the original 2005 HV battery, it should be considered suspect until verified good. As previously stated, the trouble codes need to be read or, like the first guess which cost you $200, it's just a guessing game. The auto parts store can read codes for free but unless their reader is up to date it may not read the specific Toyota hybrid codes but only generic OBD codes.
    GOOD LUCK!
    scona likes this.
  5. bisco
    51,976
    welcome!
    what was the temp in wichita when the light came on?
    scona likes this.
  6. Samantha33
    wichita, ks
    oh it is extremely cold here these days, hasn't been above 15 for the past week. when this happened first it was around 10 or so.
  7. bisco
    51,976
    car should run in those temps, but you need a fully charged 12v. sometimes new batteries are charged up and require charging before installation.
    Raytheeagle and scona like this.
  8. davecook89t
    davecook89t Senior Member
    1,089
    825
    Washington State, Florida
    Four Touring
    A newly purchased 12V battery is not always a fully charged battery. It may have been sitting on the shelf for a few months and become partially discharged. Although at this point the 12V may seem like an unlikely cause of trouble, it would be best to first eliminate this as the cause by testing it with a multi-meter. It should show a minimum of 12.7V. If that checks out, then it's time to start considering other, more serious causes. The quickest and most certain way to get the codes read would be to visit a Toyota dealer and pay them $100 or so to do it. If you have a little more time, you could order a Prius compatible code reader online for $30 or so and read them yourself, with the proper Android or Apple program.
    I hope this helps.
    Pointguard11 likes this.
  9. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    The suspicion harbours on the HV system.
    Even though there isn't a CEL as you said, just get scantool hooked in there. Some cars are just freaking deceptive with their check engine light. The build could have being dead already.
    If you still don't get any codes read out from your scantool, use a Toyota compatible scantool like tech stream, to access the HV voltage blocks. Check the min/max voltage readings, and all that.
    Dxta
  10. strawbrad
    strawbrad http://minnesotahybridbatteries.com
    953
    1,007
    Hi Samantha,
    Try disconnecting the 12 volt battery for at least 30 seconds. When reconnected I suspect your car will start just one time again.
    When a high voltage leak is detected the car will keep running until shut off but will not restart. Disconnecting the 12 volt battery clears the failure code and allows the one start until the car again sees the high voltage leak. By putting in the new battery from O'reilleys you cleared the failure code and got the one start to get home.
    Once a high voltage leak is confirmed there are steps to determine the source of the problem. The likely suspects are the HV battery or the transmission.
    Brad
    davecook89t and Prodigyplace like this.
  11. valde3
    valde3 Senior Member
    2,002
    749
    Finland
    Or AC especially if the system has been contaminated with wrong oil.
  12. Prodigyplace
    12,569
    11,782
    Central Virginia
    Assuming you mean Air Conditioner, the Prius air conditioner is electric. How would the incorrect oil stop the system from going to READY?
  13. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    What was meant was that using the incorrect oil in the A/C can also be a cause of the HV leak as the compressor is electrically driven.
    #13 dolj, Jan 3, 2018
    Prodigyplace likes this.
  14. jerrymildred
    jerrymildred Senior Member
    11,517
    14,152
    Tampa, FL
    Still no trouble codes. And people are still guessing. So far, I think @Prodigyplace has the only helpful suggestion:
  15. valde3
    2,002
    749
    Finland
    Of course we are guessing before the codes are posted here. (Actually I was not guessing just added to strawbrads comment) But just like a sports game you can’t bet after the game has started. And in this case “game” really starts with the codes.
    Reading the codes was mentioned in the reply so what would be the point of repeating that?
    #15 valde3, Jan 3, 2018
    jerrymildred likes this.
  16. Prodigyplace
    12,569
    11,782
    Central Virginia
    Reading the codes was NOT mentioned in the first post - I just checked.
    In the second post I mentioned the codes need to be read by a dealer or somebody else with software to read Prius codes.
    The OP has not posted any trouble codes. Without that detail, we cannot really assist meaningfully.
    ANDRAS RIMELY likes this.
  17. fotomoto
    5,638
    3,814
    So. Texas
    To add to what dolj said, a/c systems need both lubrication and refrigerants to operate but the high-voltage electrical a/c systems used in hybrids need a special non-conductive lubricating oil. If traditional oil/freon is used in the system, it can cause voltage issues that can brick the car (and cause a/c problems too).
    Unless the OP is in the southern hemisphere where it's summer right now (and the last time I checked Kansas isn't), this is a long shot and more common issues should be checked first.
  18. valde3
    2,002
    749
    Finland
    I meant your post as a first post. That is the first post to this topic if you don’t count the OP’s message as one. I probably should have written reply instead. I now edited my post.
    Yes I did mean exactly that we can’t assist OP without the codes. We can only guess.
    jerrymildred and Prodigyplace like this.
  19. jerrymildred
    11,517
    14,152
    Tampa, FL
    I know. It's kind of like the NFL pregame shows. :LOL:
    I've seen several threads where the OP posts a question, we all ask for more details so we can help, and the OP never comes back. Or at least never gives more info. Hopefully, this is not one of those cases and @Samantha33 will soon be back with the codes. (y)
    Brian1954 likes this.
  20. Vonne7z
    Vonne7z New Member
    Houston, TX
    Hello, All,
    I am new here so I'm unsure if this is okay, but I'm hijacking this post because I'm having a similar issue.
    November 2017 I bought a used 2006 Toyota Prius (Her name is Daisy..) from a private dealer. Since January I have driven to Miami from Houston and back and about 50 miles twice a day (100 total) for college classes at least five times a week. My baby is sitting at 198,00 miles and wasn't giving me any problems until:
    My A/C went out in Miami in early June, got it replaced, blowing arctic
    Drove back to Houston August 12, oil light dinged (with flash of red triangle) while on the road, put more in and no more problems (used a brand and weight suggested on PChat; NOTE: no prior issues but began monitoring w/ no issues or losses since *Shrug*)
    A/C was out again by August 24, never came back, classes were starting so no time (or funds) to get to shop immediately but was cool enough to stand
    Driving home from campus around September 1, stopped about 10 miles into trip at a gas station because oil light dings again, put in oil (Same weight and brand as before), but when I try to start Daisy up all the warning lights and the red triangle are lit up. Tried a few more times but same thing and only goes to Neutral, not drive or reverse
    Had her hauled back to the house and she's been there ever since.
    Here's what I have tried:
    Replaced position sensor - Pin readings were null, Daisy starts up, lights are all gone, no red triangle but then five minutes into running dies again. EPS warning light is ONLY light lit up including red triangle
    Changed Aux battery (in the back) - last one was very dead after all the shenanigans (had to open the doors and trunk manually...) and Daisy started right up AND drove TWICE around the block. Parked, put everything back together, took her out for the hopeful victory lap and the red triangle comes back on at a stop sign, EPS warning light and the triangle are back, Daisy dies again in the driveway
    I tried to make this as informational but succinct as possible. I apologize if I failed. Could someone please offer some advice, I really need her up and running ASAP. I graduate in two weeks and have to drive back to Miami and I've been so bogged down with exit courses that I haven't really been able to love on her.
    Thanks in advance!!
    VZ
    edthefox5 likes this.
