A majority of auto executives still think battery electric cars will fail, survey says
Discussion in 'Prime Main Forum (2017-2022)' started by HPrimeAdvanced, Jan 8, 2018.
  1. bwilson4web
    16,122
    Source?
    The reason I ask is "efficient way" needs to be quantified. Hydrolysis is notoriously inefficient and fuel cells not that great either. In contrast, round trip through batteries is relatively better. So I'm curious what is claimed.
    HPrimeAdvanced likes this.
  2. Lee Jay
    Lee Jay Senior Member
    5,850
    4,033
    Westminster, Colorado
    Here's how.
    FC =800-1000Wh/kg while batteries are 200-250Wh/kg.
    40 mile plug in hybrid results is 2/3-3/4 of all vehicle miles traveled on batteries.
    Battery efficiency = 85% FC efficiency = 35%.
    2/3 of all losses are rolling friction and acceleration losses (i.e. mass related).
    450 mile total range.
    The battery ends up weighing way more because they have such poor energy density. All that rolling friction and acceleration loss gets added to all miles driven by the ev. Meanwhile, all those FC losses are only added to 1/4 to 1/3 of all miles.
    You end up at about a tie - rolling and acceleration losses for all miles is about the same as round trip losses for 1/4-1/3 of all miles.
  3. Oniki
    Oniki Active Member
    652
    499
    Colorado
    Funny
    For starters, the combined city/highway EPA MPGe of the LR Tesla Model 3 is almost double that of the Honda or Toyota FCVs.
    Then you should take into account the losses from converting PV for wind electricity into H2. Oh, about 2/3rds.
    Quick arithmetic ... .... you are about 6x off.
    #83 Oniki, Jan 9, 2018
  4. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Another thought: producing a car that uses 2 underdeveloped infrastructures is probably a hard sell!
    El Dobro and Prodigyplace like this.
  5. tpenny67
    tpenny67 Active Member
    464
    403
    Massachusetts, USA
    What I find interesting is the assumption that the CNG ICE has an efficiency of only 16%. Isn't the Prius something like 40% peak efficiency? If we assume average efficiency of a CNG Prius is 32%, because the ICE isn't running where it would be very inefficient, we can double the range and go 350 miles. ICE hybrid for the win!
  6. Prodigyplace
    12,462
    11,703
    Central Virginia
    Producing a car that the oil companies cannot profit from is a hard sell politically.
    pilotgrrl and HPrimeAdvanced like this.
  7. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    did look it up.. why don't you? the site to use is Google
    quick workup from quora
    Let's do the math.
    The US burned 133 billion gallons gasoline in 2012. I'm going to ignore diesel vehicles because the majority of diesel burned in the US is in heavy vehicles where battery-electric drivetrains are not a practical option.
    How much gasoline does the United States consume?
    The average thermal energy content in gasoline is 33.41 KWh/gallon.
    Gasoline gallon equivalent
    This gives 4,443 TWh of thermal power going to gasoline road vehicles in the US per year. If we assume electric vehicles use energy with 4x the efficiency of gasoline vehicles (a reasonable round number) then it would take 1,111 TWh of electrical energy to replace that gasoline energy.
    US electricity consumption in 2011 was 3882 TWh.
    International Energy Statistics
    So the increase in yearly electricity demand would be ~29%.
    #87 SteveMucc, Jan 10, 2018
  8. Lee Jay
    5,850
    4,033
    Back to second grade for you, if that's your arithmetic.
    Do the actual math, if you can.
  9. SteveMucc
    391
    268
    Kentucky
    How much electric supply capacity is needed to keep U.S. electricity grids reliable? - Today in Energy - U.S. Energy Information Administration (EIA)
    there's not a lot of spare capacity in the grid. certainly not %30.
    and it doesn't matter when you charge... that's a total energy use required. the grid would have to grow %30 bigger if we went all electric.
    certainly it can happen, but building power plants takes decades once you get passed all the permit challenges, etc.
    Hydrogen is ultimately the way to go.
  10. Lee Jay
    5,850
    4,033
    It's not Google, it's EIA.
    U.S. Energy Information Administration (EIA) - Data
    Net generation (million kilowatt hours): 4,076,827 (2016)
    SAS Output
    Generator nameplate capacity: 1,177,183.3 (2016)
    Capacity factor = 4076827 / (1177.183 * 8760) = 39.5%
    So, the generation in the US is being used at an average of 39.5% of its capacity. Now, it could never reach 100% but 60-70% is not out of the question if demand side management is employed to control when the energy is consumed (i.e. when you charge your car). The difference between 40% and 70% is about the amount of energy it would take to move every light vehicle in the entire country over every mile it covers.
    And that's with today's installations.
    As for transportation.
    U.S. Product Supplied for Crude Oil and Petroleum Products
    Finished Petroleum Products: 17,147
    Motor gasoline: 9,317
    Distillate Fuel Oil (15 ppm and under Sulfur also known as Diesel fuel but also including fuel oil): 3,692
    Hmmm...I guess heavy trucks aren't using the vast majority of the energy.
    #90 Lee Jay, Jan 10, 2018
  11. Lee Jay
    5,850
    4,033
    You don't know what you're talking about. Spare capacity (as I just showed above) is more like 75% and it does matter when you charge - a lot.
    How many utility control centers have you visited? How many electricity dispatchers have you talked to about their job? How much minute-for-minute energy analysis have you done? I've done tons and tons.
  12. Oniki
    Oniki Active Member
    652
    499
    Colorado
    It is. I never said the exercise required anything but trivial arithmetic.
  13. Lee Jay
    5,850
    4,033
    It requires more than you did, because you did it entirely wrong.
  14. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Famous Last Words:
    Said the Auto Executive Lemming to the Other Auto Executive Lemming, "I hear there's a cliff up ahead. What should we do?"
    Reply, "Keep marching!!"
  15. Oniki
    Oniki Active Member
    652
    499
    Colorado
    Uh huh.
    While you have been jawing, I found reports of electrolysis efficiency of ~ 67%. So perhaps your preferred FCV is only 4x worse than a BEV, although I don't know what other energy costs are involved.
  16. Prodigyplace
    12,462
    11,703
    Central Virginia
    benagi and HPrimeAdvanced like this.
  17. Lee Jay
    5,850
    4,033
  18. wjtracy
    wjtracy Senior Member
    11,363
    3,607
    Northern VA (NoVA)
    Be careful, MPGe is not a good metric...more something to make BEV sound good. I personally feel if we knew how much CO2 BEV's made, which Tesla and GM may know from the their internal secret data, it may not look so good especially in Northeast.
  19. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    A word(s) now from Roseanne Roseannadanna;
    "It's always something!!"
    benagi and bisco like this.
  20. Oniki
    Oniki Active Member
    652
    499
    Colorado
    #100 Oniki, Jan 10, 2018
