2019 Avalon Hybrid
Discussion in 'Toyota Hybrids and EVs' started by Spindifferent, May 10, 2017.
  1. Prodigyplace
    12,569
    11,782
    Central Virginia
    They used Li-Ion in the 2018 Camry LE Hybrid but NiMH in the higher trims.
    The mpg of the LE matches the Prius Liftback. The other trims are quite a bit lower, IIRC.
  2. Trollbait
    12,543
    It is likely more about the weight than size; a Ni-MH pack already fits under the Prius seat. The weight savings of the Li-ion likely weren't worth it on the heavier Avalon.
    The LE also has smaller, lighter wheels; actually steel ones that are smaller than the non-hybrid LE's. Li-ion can give an edge in performance, but the weight savings from Toyota's pack vs the NiMH also can provide an advantage in testing parameters.
    Prodigyplace likes this.
  3. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    The other thing is that the NiMH pack works in colder temperatures than the Li-ion pack - I believe it's -30 °F that's the limit for the Li-ion pack.
    Avalon buyers are traditionally not the kind of person who wants to worry about whether their car will start in the middle of nowhere Minnesota in the dead of winter.
  4. Tideland Prius
    16,559
    Also, the Avalon will be a lower volume seller than Camry. Might as well use the NiMH battery for lower cost.
  5. amped
    amped Senior Member
    3,892
    694
    Columbia River Gorge, Oregon
    After watching the reveal and reading the press release, I can see why Lexus dealers aren't happy.
    The Touring model looks amazing (except for the bowhead whale grille) with real-time variable suspension, LED/laser adaptive headlights and DRL's, 1,200-watt JBL system, paddle shifters and cabin acoustic enhancements available.
    I question the tiny HVAC and other buttons along the bottom of the center stack. It seems the Avalon demographic may not want to fiddle with them without their reading glasses. /s
    Android owners won't be happy with the exclusive CarPlay-only connectivity as it spreads throughout the Toyota fleet.
    I hope it sells well for them. Within a year or sooner after release, it should have deep discounts making it a buy for the segment.
    bisco and Tideland Prius like this.
  6. Tideland Prius
    16,559
    I understand it's PriusChat and not AvalonChat but I thought the Avalon had several nice features in its design. Granted, we haven't had a full size car this sporty since the Bonneville SSEI.
    Mechanical:
    • 3.5 litre 2GR-FKS engine with D4S and VVTi-W. That means port + direct injection and Otto + Atkinson cycle
    • 2.5 litre A25A-FXS Dynamic Force engine with VVT-iE
    • NiMH battery under the rear seat
    • 8-speed Direct Shift AT (Same as Sienna, Highlander and Camry)
    • PSD on Hybrid models. 6-speed virtual gears on XSE Hybrid with Paddle Shifters
    • 3 modes (5 on Touring models including a Sport+ and Custom setting)
    • Adaptive Variable Suspension (from Lexus) on Touring models
    • Intake Sound Generator (ISG) on Touring. Older crowd won't care. Younger crowd will like the sound
    Exterior:
    • LED Vision Tech DRLs on Limited and Touring models... Looks like the Lamborghini "Y" shaped lights.
    • Dynamic cornering lights and sequential turn signals on Limited and Touring models
    • Switchblade design machine-finished alloy wheels on Touring with help from Five-Axis custom builders
    • Aero-fin taillights
    • A really sculptured trunklid with concavity
    • Quad exhausts on XSE and Touring models
    • A really cool use of environmental lighting with the lower door sculpting that gives a darker lower body, visually lowering the height of the car
    • Air curtains for the front wheels
    • Honestly, the front of the car reminds me of the Toyota Crown, which in parts of Asia, is the model that says "you made it". (although the newer generation might think it's the Lexus LS rather than the Crown)
    Interior:
    • Apple CarPlay is standard
    • Alexa-in-the-Car is standard
    • 9" MID with physical buttons & knobs
    • 7" LCD Instrument Panel with analogue speedometer
    • 10" Full Colour Head-Up Display with speed, audio, navigation, phone and warning/alert displays
    • Real Yamaha-sourced wood or real aluminium trim
    • Quilted leather door panel inserts on Limited
    • Perforated ultrasuede door panel inserts on Touring
    • Heated/Cooled front seats
    • Heated rear seats
    • Heated steering wheel
    Data Daedalus and amped like this.
  7. Tideland Prius
    16,559
    Yup. It used to be that the ES was the mini-LS.... now it's looking like the Avalon will take over that role (at least until the 2019 ES is revealed).
    I believe the headlights are LED not laser. You may be thinking about the "LED Vision Tech" DRLs... something about light being able to penetrate the metal design that they have? I'll have to read up on that. But the LED DRLs on the Touring and Limited models look like the "Y" lights on Lamborghinis.
    As for HVAC, they'd rather have buttons than a touchscreen interface. The buttons may be small, but at least there are buttons. (Also, the European cars have tiny buttons anyway so... someone coming from a BMW or MB may not notice it).
  8. bisco
    51,973
    i have a hard time picturing 'the younger crowd' in an avalon, but who knows?:p
    Data Daedalus likes this.
  9. Tideland Prius
    16,559
    We're not talking 20 year olds lol.
    Younger being 40/50 as opposed to 60/70.
    Say, someone that already has a family with teenage or adult children that want something different than a "common" Camry and perhaps already have an SUV or needs to replace the minivan that they've used for the past 10-15 years for something nicer to drive.
    Data Daedalus and pilotgrrl like this.
  10. bisco
    51,973
    agreed, but engine growl in a hybrid? just my personal bias i suppose. i didn't like it when i bought my first prius at 49.
  11. Tideland Prius
    16,559
    No, that's on the Touring V6 only.
    Data Daedalus and bisco like this.
  12. bisco
    51,973
    oh, good. puts it with the mustang.:cool:
  13. krmcg
    2,592
    2,392
    Whittier, CA
    What is this?
  14. Tideland Prius
    16,559
    There's a gap in the front bumper that allows air to flow through the bumper and over the front wheels, creating a "curtain" of air to reduce turbulent flow around the front wheels - similar to what our aerodynamic wheel covers do but using vents in the bumper rather than a plastic wheel cover.
    The Clarity has it for the front and rear wheels. I think the feature is also on Ford products... Mustang and F-150?
    krmcg likes this.
  15. bisco
    51,973
    gotta hand it to ford, they have snookered toyota a number of times over the years.
    amped likes this.
  16. amped
    amped Senior Member
    3,892
    694
    Maybe because Ford poached a few Toyota senior corporate managers and VP's along the way.
    Not taking anything away from Ford, their big truck has dominated not just the segment, but the entire US industry for years. I drove my nephew's new F-150 Platinum last week and other than the height, thought it was as smooth, quiet, well equipped and powerful as a near-luxury sedan, and that new co-developed 10-speed A/T is butter.
    bisco and Prodigyplace like this.
  17. Trollbait
    12,543
    Did the new Avalon grow is size to match the new Accord.
  18. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    I wonder how the decision was made to go with Apple instead of Android...
    Follow the money? Toyota's partnership w/Microsoft in Toyota Connected? Jeff Bezos?
  19. Prodigyplace
    12,569
    11,782
    Central Virginia
    Perhaps Toyota executives have iPhones?
  20. bisco
    51,973
    how many i phone users vs android?
    or maybe they just got a better deal from apple.
    what is the most popular android phone, samsung? maybe japan and sk don't play nice.
