2007 erratic idle issues
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rrey, Jan 18, 2018.
  1. rrey
    rrey Junior Member
    texas
    new to the forums as well as the hybrid community. I recently purchased a 2007 Prius with around 170k miles. When I test drove the vehicle it drove fine. It sat in my driveway a few weeks and when I recently drove it, it would raise the rpms up in idle to around 2500-3k. If you apply gas to the pedal it will smooth out temporairly, then die, then start the process all over again. If I take it out on the road anything below about 20mph the car will continue to rev the gas engine up. I'm not sure of the maintenance history of the vehicle and also replaced the MAF as I found the original one full of dirt. It is not throwing any OBD II codes except the (!) Yellow indicator on the dash. The car also sometimes gets confused as to whether it's in park or not when trying to shift to drive while the car is idling this way. I apologize in advance if this is not the correct forum but I've looked all over and can't seem to find an answer. Thanks for any responses and help.
  2. SFO
    SFO Senior Member
    5,302
    4,244
    Northern California
    Welcome to PriusChat!!
    When cleaning or replacing the MAF sensor you must also disconnect the 12v battery for a few minutes before driving.
    Never let your Prius sit for such a long period of time, sure way to drain one or both batteries (or worse).
    rrey and Raytheeagle like this.
  3. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    If that does not help clean the throttle plate and then reset it.
    SFO and JC91006 like this.
  4. rrey
    rrey Junior Member
    texas
    Thanks, I'll definitely disconnect the battery for a few minutes and try and keep the batteries charged on this car. I'll also look at the throttle plate. What does "resetting" it involve?
    SFO likes this.
  5. fotomoto
    fotomoto Senior Member
    5,626
    3,802
    So. Texas
    Reset means disconnect the 12v. That clears the computers (ECU's) that both read the sensors and control the throttle (and a million other things).
    SFO likes this.
  6. rrey
    rrey Junior Member
    texas
    Awesome, will definitely do. I thought he was talking about physically "resetting" the throttle plate itself. I'll post back later with results
    SFO likes this.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,829
    Clearwater, Florida
    I suspect the hybrid battery is beginning to eventually fail. Only because now every other post is about a failing g2 battery,
    It cannot be a bad engine issue or it would throw a dtc on the dash. Watch the battery monitor closely on the mfd during your troubles you will probably see it spends a lot of its life in purple bars. When the hybrid battery
    Cannot supply enough power to meet your demands it falls to the engine which means a lot of reving.
    Raytheeagle and SFO like this.
  8. rrey
    rrey Junior Member
    texas
    UPDATE: Disconnected the 12V battery, changed the plugs and PCV Valve. Seems to be running smoother but still reving at low rpm. I did notice that the motor only does this when the hybrid battery is showing 8 or 7 bars. I've read elsewhere that this may be the motor trying to spin off an access charge? Does that sound correct, if not any more ideas?
  9. JC91006
    JC91006 Senior Member
    16,642
    8,496
    Have you tried cleaning the throttle body?
  10. rrey
    rrey Junior Member
    texas
    Just the throttle plate itself, is there any other components I need to clean/inspect?
  11. JC91006
    16,642
    8,496
    You can open up the plate and clean the throttle body.
    How did the throttle plate look when you cleaned it?
  12. rrey
    rrey Junior Member
    texas
    Ok thanks for the info, the throttle plate had slight build up but nothing significant.
  13. JC91006
    16,642
    8,496
    Hmmm, then this cleaning probably won't help much. But it's so easy, try it and see. Disconnect the 12v for a minute when you are done
    rrey likes this.
