Can anyone quantify the effects of winter grill blocking on engine water temps/cabin heat and mpg.
Discussion in 'Gen 2 Prius Technical Discussion' started by Bob64, Jan 18, 2018.
  1. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    I'm in a debate where I'm trying to prove that cabin heat usage in the winter is a substantial draw on mpg (in a gen2 prius) - and that a grill block will improve mpg - particularly in stop n go traffic where the engine is not running at 100% anyway.
    My 2007 Prius is totaled and I no longer have the ability to gather data to prove him wrong. I'm interested in any data regarding coolant water temp vs time when stopped at a light with and without grill blocking.
    If anyone has any data as to the amount of cooling that passive air flow through the engine bay with and without a grill block. I want to prove/quantify that this cooling negatively effects mpg by reducing the amount of heat available to run the cabin heat. Any data regarding the amount of gas used to increase engine coolant temp by 1c would also be appreciated. I've looked through Hobbit/Bob Wilson's site hoping to find some graphs/data but wasn't able to find anything substantial.
    Edit: I just thought of a great test. 1) Leave the car parked and turn on the heater to say 74 without grill blocking. Record fuel use after say 30 minutes. 2) Re-run the test after a day (assuming same outdoor temps) with grill blocking and record fuel use. All other variables are now effectively eliminated.
    #1 Bob64, Jan 18, 2018
    pilotgrrl and SFO like this.
  2. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    That test won’t really show the real benefits of grill blocking. If the car is just parked engine passive cooling is just a same as parking it after drive. Idea of the grill block is mainly to reduce the passive cooling to engine block (and other pars) at speed.
    With no grill blocked engine temperature difference to outside temperature half at maybe a bit less than an hour. With full grill block that might be slowed down to maybe one and half hours. So for example if engine is 70c and outside temperature is -30c after that time engine is cooled down to 20c. At the same time heater use can lose many degrees of Celsius per minute. So heater is the main cooler of engine.
    Grill blocking while driving has the main benefit of engine reaching higher operating temperatures. For example if the engine temperature would reach 70c without grill block and 84c with grill block and engine would be started at 62c you will have a lot longer time before engine is turned on for heat.
    I don’t have any accurate date. I haven’t really seen the need for the data. The benefits are easy to proof and with almost no negative effects or cost I see no reason not to (partially depending on temperature) block your grill when you’re not using your AC for cooling.
    But yes heater use has huge effect in fuel economy on gen 2 Prius. Normally I use the heater on lowest temp setting 16c and lowest fan speed. You won’t really need any warmer than that while driving.
    #2 valde3, Jan 18, 2018
  3. Bob64
    1,540
    93
    Virginia
    Yeah, but the guy I'm talking to is convinced that the drag reduction from grill blocking is accounting for most, if not all of the efficiency improvements. I've tried extrapolating the grill blocking present in the gen4 prius vs the gen 3 to .01 cd reduction (big assumption). But he is set on believing the actual cd reduction is massive and should be closer to a tesla model 3's grill-less cd.
  4. Prodigyplace
    12,372
    11,661
    Central Virginia
    Perhaps @Mendel Leisk has some insights. I believe he uses grill blocking in addition to year round engine block heater, IIRC..
  5. valde3
    2,002
    746
    Finland
    You can clearly see that many people do block the grills on their regular cars just for the engine to stay warmer. And it does help even if they have good/new thermostat.
    And as the gen 2 Prius will start its engine just to produce heat you can clearly tell that it does help.
    Because blocking the grill in gen 2 Prius will increase engine temperature you can tell that the effect of reduced drag reduction is less than effect of less airflow around engine. If it wasn’t grill blocking would cool the engine.
    Prodigyplace likes this.
  6. Prodigyplace
    12,372
    11,661
    Central Virginia
    CAUTION:
    This discussion is NOT for Gen 4 Prius that already have active grill shutters fulfilling this purpose.
    Some people like me browse the different forums so I posted this disclaimer.
  7. bisco
    50,831
    i don't recall any scientific studies being done, but i have to agree with valde, it would only help at speed, the faster the better, and i would think that done correctly, it would improve aero, not reduce it.
  8. Mendel Leisk
    40,265
    I'm not sure, but I don't think the foam tubing style of grill blocking would help with aerodynamics, or not much.
  9. bisco
    50,831
    no testing on that either.
    fwiw (not much) i can't see a noticeable improvement in mpg with grille blocking. or increased tire pressure for that matter. it would probably take controlled testing over long distances.
  10. valde3
    2,002
    746
    Finland
    Grill blocking will help aerodynamics regardless of how it’s done. That’s because aerodynamics of the outside of car are always better than aerodynamics in the engine bay. Texture on the surface of blunt front end isn’t really that important.
  11. Mendel Leisk
    40,265
    I've only got 50% block lower too, any effect basically lost in the noise I think.
  12. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    This winter I was doing my commute without a grill block (was installing LED driving lights behind my grill to come on with my brights, so had them out). When removed I noticed about a 2mpg loss and regained about 2mpg when I put the grill block back. My commute is 35 miles each way, 95% highway done at ~75mph. I use the pipe insulators cut in half and have 100% top grill block (except LEDs) and 50% bottom. Watching my scanguage, the car does seem to come up to temp faster, and requires just a touch less rpm to maintain speed on the highway. I do 42-44mpg going to work and 50-55mpg (in normal conditions - wind, rain, very cold, etc and these drop) coming home on my winter tires at 42-44psi .
    So doing the math, a grill block seems to provide a ~4% increase in fuel economy on a highway commute. I think it's a combination of allowing the car to get up operating temp faster, better aerodynamics, and slightly warmer air reducing engine pumping losses.
    #12 Kevin_Denver, Jan 18, 2018
    Mendel Leisk and Prodigyplace like this.
  13. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    Here's what I've done each winter for the past several years:
    …and yes, I use the same pieces each year (I hate waste!) The ICE warms up much quicker, the interior of the car gets nice and toasty within about ½ mile, and the gas mileage goes down as it usually does in the winter (as the formula changes with the seasons) - the overall gas mileage doesn't change much (see my fuelly figures), part of which might be explained by using the Hybrid Automotive Prolong Charging System (I bought mine back in Jan 2014) - but, as they always say, YMMV! ;)
  14. Bob64
    1,540
    93
    Virginia
    I know it helps mpg, I just want to figure out how much heat it saves for climate control use.
    Eg: if you lose 2c every minute at a stop, that's less heat available for use to heat the cabin. But if grill blocking improves heat retention by 50%, you essentially reduce the amount of gas used to heat the cabin by 50%. The hard part is quantifying this while driving because it also impacts aerodynamics. The guy I'm trying to convince claims the majority of winter mpg improvement comes from lower coefficient of drag, and not from faster warmup/heat retention.
  15. valde3
    2,002
    746
    Finland
    For that 2c heat lost per minute while stationary most of is due to heater use. And for the part that’s not effect of the grill block is still small. Like I said earlier main benefit is for the engine to reach higher temperatures when driving which then means that it will stay off longer before it needs to start to provide heat.
    Probably the best way to test is to test higher speed (where engine is on all the time) fuel economy with fully warm engine. That way you can test only the aerodynamic drag reduction benefits of grill block. Then compare that to normal drive with cold start.
    But doing fuel economy tests on normal roads is hard. And you should you should think about the margin of error.
    If fuel economy improvement is better on normal drive with cold start then that proves that the heat loss reduction has more effect that aerodynamic drag reduction.
    #15 valde3, Jan 19, 2018
  16. Friedenmeister
    Friedenmeister Junior Member
    The site ecomodder is a good resource for your discussion with him. The purpose of grill blocking is two fold - first is to reduce drag on the car, and second is to give you a faster warm up time. The engine bay of a car is much like a parachute in reverse; it's a large concave area that traps a lot of air and does not easily let air escape. Similar areas on a car are the wheel wells. Running the heat in a Prius will be more detrimental to efficiency because the engine will need to run more, but the energy used to actually circulate the heated engine coolant is negligible because the water pump is running any time the engine is turning. In a Prius, the loss of efficiency is more from running the engine rather than running the heat. If the engine is already running, as it does with highway driving, then running the heat will be inconsequential. If the car is sitting parked and running the heat, then yes, the engine is running only to generate heat, and this heat is by definition wasted energy from the engine, the purpose of which is ideally to transport you from one place to another, not to serve as a fireplace to keep you warm.
  17. Prodigyplace
    12,372
    11,661
    Central Virginia
    Reading many threads you would think the purpose of a car is a mobile entertainment system.
