2016 prius 4 brake button question help
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by cdoming4, Jan 18, 2018.
  1. cdoming4
    cdoming4 Junior Member
    los angeles
    hello i recently bought a new 2016 prius 4 approx. 3 weeks ago, the brake button collapsed inside. i took to dealer and they fixed it. it collapsed again today, and concerned! i was surprised how hollow the inside of the parking brake button was. i'm guessing this has to do why it collapses the way it does. any suggestions or questions i should ask when i take it to the dealer. thanks.
  2. krmcg
    2,592
    2,391
    Whittier, CA
    Brake Button? Do you mean Park Button? I don't have a brake button in my Four.
    KilgoreTrout likes this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    There are only 2 brakes on a Gen 4 PRIUS - the footbrake, and the parking brake which is activated by your foot too. Which are you talking about?
  4. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    Yes, logic suggests he means the Park button and I've never heard of this before. If there is no assembly defect at the switch, the only thing is to be very careful when pressing it until the dealer and Toyota USA find an acceptable solution - which might be another car!
    pilotgrrl and Mendel Leisk like this.
  5. bisco
    51,076
    welcome!
    you'll have to go back to the dealer, and request a more thorough investigation of the cause. i don't recall seeing anyone else with this problem.
  6. padroo
    padroo Senior Member
    2,763
    2,251
    I have never used my parking brake. The manual says you release it by pressing it again, no button.
  7. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    I think it's referring to the Parking Mode button.
  8. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    The only thing I can think of is that the plastic tabs - or whatever hold the P(ark) button - have broken. Definitely should be a warranty repair & report to NHTSA, that is unsafe.
    KilgoreTrout and RCO like this.
  9. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    Presumably the parking pawl, or equivalent, will still be activated when the engine is switched off. (n)
  10. alanclarkeau
    7,045
    7,589
    True - I don't recall pressing the "P" Button more than a few times. I haven't really seen a need for it - unlike a conventional auto which you put into PARK when you park, PRIUS engages the parking pawl when you press POWER (off).
    krmcg, kithmo and RCO like this.
  11. CooCooCaChoo
    CooCooCaChoo Senior Member
    953
    533
    Cow-lee-fornia
    2023 Prius
    Just make sure the car is completely stopped before you hit the power button. If its still in motion, it won't happen or if the motion is very slow, it will slam to a stop and possibly damage the pawl.
    pilotgrrl likes this.
  12. Zardoz
    Zardoz Member
    86
    51
    Show Low, AZ
    I thought the pressing of the Power Button was a form of "Emergency Stop" when all else fails. I did not think it was supposed to cause harm. It was my understanding that a sensor kept the pawl from activating at speed.
  13. alanclarkeau
    7,045
    7,589
    From USA Manual 2016
    Raytheeagle, RCO and pilotgrrl like this.
  14. PeZa
    PeZa New Member
    Kansas City
    I looked at a 2016 Prius with the exact same problem; it is the "Park" button that collapsed. Used car dealer said they would fix it, but haven't yet.
  15. kithmo
    kithmo Couch Potato
    2,404
    2,774
    47
    South Yorkshire, UK
    I would return to the dealer and ask them to replace the button with a new one, not "fix" it. Unless you're being very heavy handed, it's obviously broken internally and needs a new one.
    alanclarkeau likes this.
  16. Owll
    Owll Junior Member
    San Diego
    This has been an ongoing problem for me. I know how to remove the bezel, that holds the button in place. The problem is that the wire leads to the button are "very" short, so re-seating the button is a pain. I was hoping that by now Prius would have an extension made, to alleviate the problem.
    A simple fix for the situation would be to apply tape around the button base / wire lead plug or perhaps a zip-tie to keep the button from collapsing. However, since the wire is much too short, there's no way to do this. I think I'm just going to have to splice 3" of wire or so into the circuit. Very poor design by Toyota.
  17. Mendel Leisk
    40,530
    splicing in wire sounds good, and concur about design shortcoming.
  18. alanclarkeau
    7,045
    7,589
    The OP never returned - that was 3ΒΌ years ago.
