Battery Power for Lawn equipment -- is it time?
Discussion in 'Fred's House of Pancakes' started by Stevewoods, Jan 24, 2018.
  1. Stevewoods
    Stevewoods Senior Member
    659
    1,125
    Seattle, WA
    Way back in the dark ages -- the 1980s, I bought a Toro string trimmer -- battery power. It was one of the biggest pieces of #$@#@ ever.
    Skip forward. I am looking for a new leaf blower. I had a two-cycle gasoline mix Husky 125b that worked well for several years and then seized. I bought another one. Worked well for about 18 months and died. Bought another one, worked for about 14 months....The reviews on this Husky seem to follow my experience. It was good originally and now -- maybe not so much.
    So, I have a couple of acres of gentleman farm. Bit the bullet and bought a backpack Stihl blower a couple of months ago that blows my German shepherd dog across the yard, but I need a small machine to do minor stuff around the house, as well as blowing debris off the roof.
    I prefer not to have electric cords to tangle up in as I walk across the roof. The Stihl is a bit too big to haul up to the top of my two-story place. Thinking a battery unit would be perfect.
    Any thoughts? If battery is not the answer, I think I will go with a low-end Poulan or something -- some gasoline model without a cord.
  2. fotomoto
    fotomoto Senior Member
    5,632
    3,810
    So. Texas
    I've been using an el cheapo' 14.4 volt Black & Decker blower for about 6 years now and it works great for light to moderate use like your needs. Excellent benefits included: quiet(er), smaller and lighter along with no fuss or maintenance. The batts also work with a matching small circular saw and string trimmer but the batts are getting too weak now for any real use with the saw and are at best performance with a fresh charge (no sitting).
    I'm torn with between getting new batts or just upgrading to the newer higher voltage LiOn offered now. Pricing was better at Christmas.
    Stevewoods likes this.
  3. Trollbait
    12,507
    If you can solder, you can replace the cells in the battery pack for less cash.
    fotomoto likes this.
  4. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    668
    267
    Dodge Co. Wisconsin
    2017 Prius v wagon
    If you stay with gas, make sure you use real gas, NO Ethanol.
    nssdiver likes this.
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    I have a Snapper 60V that works good for small jobs.
    When I lived on a real farm, my "leaf blower" was a 60 inch riding mower with a 40 horse Kohler twin. (y)
    In my opinion it is foolish to rake up leaves. Chop them up and spread them around.
    douglasjre and Andyprius1 like this.
  6. Stevewoods
    659
    1,125
    Seattle, WA
    No ethanol. Been that way for many years!
  7. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    For lighter work around the house, have you looked at the EGO brand electrics?
    The battery packs are interchangeable between all their products.
    Collections | EGO POWER+
    I have the lawnmower which works great. But I don’t know how it would handle your needs.
    The rest of their line may be more applicable.
  8. bisco
    51,848
    the problem as i see it is hype. when you look at a product, there are claims of run time, air velocity and etc.
    home depot had a ryobi electric lawn tractor for sale in the spring, then it disappeared. i suspect too many returns.
    for string trimmers, leaf blowers and etc. as long as you have enough batteries, you're good to go.
  9. Trollbait
    12,507
    As long as you can find it. With it, I've found you just need to be more diligent with maintenance.
  10. ChapmanF
    18,080
    For about ten years I've wanted it to be time, and the first such tool I bought (a toy-sized string trimmer with a lead-acid battery you could sling off your shoulder) was an irredeemable piece of dreck.
    A few years later, I bought a Toro system (both a string trimmer and a blower, using the same Li-ion battery), and those were sort of ok. The trimmer could actually trim things, and the blower would blow stuff. However, when it finally came time to replace the battery pack, I found they had reassigned the same part number, unannounced, to a smaller, lower watthour pack. I have no patience for that kind of game, so the pack was sent back for a refund, Toro was struck from my approved-vendor list with extreme prejudice, and I went shopping again.
    I've been using the Ego Power+ tools from that last shopping trip for a few years now, and I think it really is time. I have one battery pack and three tools. The battery I got is their 140 watthour, and they offer several larger than that. On my small lot, the 140 Wh is usually all I need. The charger is actually fast, so if I take a break for recharging, it doesn't have to be a long one.
    The blower in this collection will, if I'm not careful, blow the grass out of my lawn. Naturally, you think I'm kidding, and there are some spots in my lawn right now that would look better if I were.
    -Chap
    nssdiver and Zythryn like this.
  11. Sam Spade
    2,036
    1,023
    2017 Prius c
    AND cheap design shows up more quickly.
    If you pay $49 for a gas powered lawn tool, you should not expect it to have a long and happy life.......no matter what kind of fuel you put in it.
  12. Zythryn
    6,408
    4,407
    And at the same time, you can shorten your own :p
  13. bisco
    51,848
    we have been using the ryobi one system for years with good success. an hour of trimming is not an issue with the larger of the two optional battery sizes.
  14. Sam Spade
    2,036
    1,023
    2017 Prius c
    Say what ??
  15. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Last year I read about California going electric concerning commercial landscapers, I find nothing now, getting rid of 2 cycle motors is a great idea, commercial electric mowers subsidized by the state would trickle down to the homeowner, another good thing.
    Summers I spend many hours maintaining fences and my lawn, I'd love to do it almost silently, true sheep are silent but to much maintainence, and messy, and noisy, and they pull the roots out, llama are browsers, no telling what shape the needed areas would be in at the end of the summer, and messy, and they kill all trees they are allowed near. Pigs...na
  16. Zythryn
    6,408
    4,407
    Sorry, that wasn't well laid out was it?
    For an in depth explaination...How bad for the environment are gas-powered leaf blowers? - The Washington Post
    In short, 2 cycle lawn equipment engines tend to pour out as much, if not more pollutants than heavy cars.
    Sitting/standing next to a tailpipe while walking around the yard is not my idea of healthy ;)
    Battery powered lawn equipment have been lacking not so many years ago. They have become very good as of late, and right now, for many, they are vastly superior.
    Like EVs though, for some, gas powered is still the way to go.
    pilotgrrl likes this.
  17. mikefocke
    3,988
    1,801
    Sanford, NC
    Ego via Home Depot or Amazon. ~$200 Essentially 3 speeds. I use it and blow leaves off the small lawn I have. Out of the garage, off the decks. Got my son one and he loves it. Neighbor uses it to blow leaves off her roof. Probably a dozen in the neighborhood. I even bought two more batteries (not cheap) that I cycle through the charger so I can blow for several hours. I've had one battery failure. Handled under warranty and was a positive experience.
    Son and neighbor have Ego mowers for their very small lawns. Fold up into a suitcase size.
  18. bisco
    51,848
    i use a corded leaf vac, batteries aren't powerful enough for suction yet.
  19. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    For those with hot summers, has anyone been taking precautions with battery storage?
    Battery powered blowers, trimers, and lawn mowers are becoming powerful enough to get the job done well, but suspect a couple hot summers in a shed or garage could be a costly battery degradation experience.
    Guessing one would need to remove the batteries and store them in the house during the summer, a time when they would be used the most, subtracting a good bit from the convenience of battery operation.
    Trollbait likes this.
  20. bisco
    51,848
    i keep ours on charge in the barn. it can get into the 90's in there, but never seen it go over a hundred.
    no idea if it is shortening the life or not. i do know that the charger won't charge them if it's too hot.
