Black Headlight Assembly 2012 Prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Lladnyk, Jan 13, 2018.
Tags:
  1. MagnusAG99
    MagnusAG99 Senior Member
    673
    521
    Norway
    Wait.. so u replaced the orignal lenses and like the whole projector and stuff to a retro fit one like this? Like a new kit with the whole light assembly? 3": STi-R - Clear Lenses from The Retrofit Source
    and I see, really big difference in illumination right infront of the car and on the sides.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I replaced the entire RHD HID projector with a LHD LED projector
    iPhone ?
    MagnusAG99 likes this.
  3. MagnusAG99
    673
    521
    Norway
    ahhh, does the right side illuminate up as good tho? as a normal left hand drive car?
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Yep.
    iPhone ?
  5. Lladnyk
    Lladnyk Member
    48
    57
    Finally installed them today. Everything fit perfectly, really happy with the way it came out.
    Before:
    And after:
  6. Grit
    Grit Senior Member
    6,575
    4,228
    Wilkes Land
    Nice work, looks great also. What pa/rking bulbs did you go wiht?
    Lladnyk likes this.
  7. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Looks good. When u can, plz get a pic up against a flat wall from ~25ft.
    Curious about the cutoff
    iPhone ?
    xliderider and Lladnyk like this.
  8. Lladnyk
    Lladnyk Member
    48
    57
    I got these for the upper parking light (6K because it matches the low and high beams) and these for the side marker lights under the reflectors.
  9. Lladnyk
    Lladnyk Member
    48
    57
    I'll post a pic once I get a chance to.
  10. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    What a difference those lights made. went from borriong ol prius to a demon after
    Lladnyk likes this.
  11. StarCaller
    StarCaller Senior Member
    1,279
    730
    Cedar Crest, NM, USA
    how's the material quality & the fitment?
  12. Lladnyk
    Lladnyk Member
    48
    57
    The headlights fit perfectly onto the car. The LED bulbs I got were a little more difficult to correctly fit, but eventually I got them installed right. Not sure if this is because of the housing or the actual bulbs, as neither are stock.
  13. Lladnyk
    Lladnyk Member
    48
    57
    Here's the low and high beams in the black housing. I haven't adjusted the aim yet so this is just how they came.
    sfv41901, James Powers and MagnusAG99 like this.
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Love the color output but the cutoff leaves a lot to be desired. Was hoping it looked similar to this
    iPhone ?
    #54 sfv41901, Feb 5, 2018
  15. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Lol, not fair. Razor sharp cutoffs are only possible with clear lenses. They'll be more diffuse with frosted lenses.
  16. Spooled
    Spooled Member
    142
    26
    Concord, CA
    these are gorgeous lights! nice job
    pm me if you do this for hire!
    Burna J likes this.
