Uncomfortable drivers seat
Discussion in 'Newbie Forum' started by Britgal54, Feb 4, 2018.
  1. Britgal54
    Britgal54 New Member
    Kingston, WA
    I purchased a 2017 Prius Four in August last year. Since then I have been having pain in my lower back and seat (my seat). The pain is also going down my leg. It may be a coinsidence, but this has been going on since I bought the car. I put in at least 20,000 miles per year as I use the car for business. Don't know what to do. I love the car, but not the seats. My last car was a 2009 Prius, basic model and I had no problems. Does anyone know if it is possible to replace the seat? I do not have the same trouble driving my husbands VW Passat. Can seats from other manufacturers be installed in my Prius?
    RCO likes this.
  2. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Your car has lumbar control, it's an air pump that gives you lumbar support, and it's an electric seat, have you tried the various adjustments.
    The gen2 had no lumbar adjustment but the 3 and 4 do, if it's inadequate, there are lumbar support cushions available.
    RCO and bisco like this.
  3. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    I'm not a doctor, but it sounds like you might have sciatica. Is the pain going down the leg you press the pedals with?
    You might also want to try adjusting the seat height and how far back you are from the steering wheel.
    I have had some issues with sciatica since I broke 2 vertebrae in my lower back (T12 & L1) after totaling my Gen 2 Prius in an accident. Moving the seat position helped, since my US Gen 4 doesn't have the lumbar support option yours does.
    Hope you're feeling better soon!
    RCO likes this.
  4. bisco
    51,836
    changing the seat would require some customization.
  5. pilotgrrl
    891
    1,797
    Chicagoan in TX
    RCO likes this.
  6. Britgal54
    Kingston, WA
    Lucifer, bisco and pilotgrrl, Thank you for your input. I herniated L3 and L5 in 2004, since then periodic back pain has been an ongoing problem. I have the lumbar support as far as it will go, also have been trying different seat positions, plus one of those wedge seat cushions. Maybe I have not found the right combination yet.
    I am certain I do have sciatica, and yes it is the same side as the pedals!! I will follow the links pilotgrrl and see if there is any usful info. Thank you all for your input. Appreciated
    RCO and pilotgrrl like this.
  7. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Hello and welcome to Prius Chat from Gt. Britain - well, Cornwall anyway! I have found it can help to shuffle around on your seat before you drive of can ease the discomfort of an awkward seating. Once done, the rest of the drive for me had been OK. I even shuffle while driving, if it gets painful. My UK spec gen 4 had cloth seats with electric lumbar adjustment. USA may be different. Changing the seat completely sounds too radical for me. Perhaps you could try setting a cushion behind the small of your back. Only trial and error but could be cost effective. Good luck, and hope your pain eases soon.
