Prius C Subwoofer Box Fabrication/Install (kinda pic heavy)
Discussion in 'Prius c Audio and Electronics' started by G-Echo, Feb 17, 2018.
  1. G-Echo
    G-Echo Junior Member
    Phoenix
    2018 Prius c
    Since I have the fiberglassing skills, I decided to finally get around to making subwoofer box for my Prius (until I decide which way I want to go in my SQ stereo setup, but it'll all be hidden). I had a cheap 8" Boss subwoofer and an Alpine amp sitting around I got from a friend a few months ago, so I figured I'd use those to keep my costs down.
    The goals: to limit my loss of space, to get around .5 cu ft (ended up .45 based on a water measurement), and make an easily removable subwoofer box without affecting my ability to get to the spare tire.
    I decided to tuck it away in the corner and hide the amp under a seat (no pics of that). I started by masking the area I was going to use:
    After I had the area taped off, I pulled the panel from the vehicle so I could work on it with less hassle. I taped off all the 'holes' and sprayed it down with PVA (it's a mold release agent) then I used some high build primer to start making the base (for easier sanding later) :
    After that, I laid the fiberglass to complete the 'form'...
    The cured fiberglass popped right out of the panel. PVA is water soluble, so it sprays right off...after cleaning, the panel is in the same shape as it was before I pulled it out.
    Then some trimming and the test fit, hoping nothing warped (it didn't)
    Made a mold and popped the plug out (not usable after making the mold, which is typical).
    After that comes the easy part, making the actual sub box...
    Then final sanding and finishing...I use a truck bed liner for durability.
    Installed with the temporary sub until I figure out what direction I want to go in the future (10" or 12"). I used the factory bolt to bolt it in and a couple areas of high strength velcro on the back side...it isn't going anywhere without some serious yanking. You may notice the light above the box, it's from a light I got from a Pontiac Aztec and wired in on each side...put some bright LEDs in there and it really lets me see at night.
    All-in-all, I'm pretty pleased with how it turned out and it really fills in the lowers frequencies that the factory stereo just can't get to. If I were to do it again, there's a few things I would change, but since this is temporary (for the next year or so) it's not really worth the time.
    BlackBetty, djdawn, Xterra72 and 2 others like this.
  2. SamanthaC0716
    SamanthaC0716 Active Member
    333
    115
    Wow!
    iPhone ?
  3. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
  4. audiodave
    audiodave Active Member
    799
    270
    US
    I had a fiberglass box made for the left corner of my 2004 for a 10. Paid a lot and had to beef it up, just to thin and flimsy. I'll add a pic later.
  5. audiodave
    799
    270
    US
  6. audiodave
    799
    270
    US
  7. audiodave
    799
    270
    US
  8. G-Echo
    Phoenix
    2018 Prius c
    Very nice...I’m going to go with a 6 channel amp and put some mids in my pillars, separate amp for a sub as well along with DSP, etc,etc. All long-term (over a year) plans
    audiodave likes this.
  9. audiodave
    799
    270
    US
    Front separates are pricey old Alpine. Tweets in the stock location. There bi amped off the 4 channels, 5 channel for the sub. Efficient class D amp that sounds excellent and good for the little 12 volt aux Prius battery. Processor is a Alpine PXA 600. Time correction and parametric EQ. Dual 20 bit D-A converters. Deck and changer both have digital outs going into the processor. Old gear but still sounds great.
  10. audiodave
    799
    270
    US
    Lot of dynamat in the car. Doors are solid. Only area is the roof without any. Car not a tin can anymore. Lol
  11. Prius7Prime
    Prius7Prime Junior Member
    58
    Long Beach
    2012 Prius Alpha
    Not a bad 'temporary' setup!
  12. Stever56
    Stever56 Junior Member
    US Crestwood, illinois
  13. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    Amazing. Hats off.
  14. djdawn
    djdawn Active Member
    256
    116
    Escondido, CA
    2014 Prius c
    If you ever decide to make a bunch and sell them off, I'm sure some folks would be interested. Myself included. I have a bazooka sub installed at the moment and wouldn't mind reclaiming some of that space.
  15. audiodave
    799
    270
    US
    I bought this off Ebay. I made it stronger and modified it. But not the maker.
