2017 Prius Button Question...
Discussion in 'Gen 4 Prius Main Forum' started by Yuki, Feb 20, 2018.
  1. Yuki
    Yuki Junior Member
    Columbus OHIO
    What is this button for?? Anyone know?
    I press it and nothing shows up,,,,
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    DRCC distance. It's explained in the manual:
    kithmo likes this.
  3. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Like Alan said, is for the dynamic cruise control range, but before you use it you'd better read the manual. I'm assuming your Toyota salesman didn't tell you much about the radar in your high tech new car. You likely will not have had anything like this before.
  4. TinyTim
    TinyTim Active Member
    376
    229
    Seattle
    Yes laser cruise control is only for experts.
    kithmo, pilotgrrl and Prodigyplace like this.
  5. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Laser? You sure about that??? Mine obviously lacks the necessary flux converter! :ROFLMAO:
  6. Prodigyplace
    12,462
    11,703
    Central Virginia
    How often do you confuse Radar & Laser? :eek:
    Sounds dangerous, potentially.
    pilotgrrl and RCO like this.
  7. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Actually for those who don't know, early adaptive cruise systems did use lasers. However it didn't work in rain or snow and it was also affected by the reflectivity (or lack thereof) of the vehicle it was tracking. Also the laser box had to be out front on the grille, it couldn't be hidden behind a $500 emblem like radar sensors can :cautious:
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Could it be more blindingly obvious? :ROFLMAO::cool:
  9. RRxing
    RRxing Senior Member
    2,537
    1,810
    NEPA
    As with all things Prius, it really helps to read the manual, however bloated it may seem. There are plenty of parts you can skip over (I'm looking at you, Tire Information...), but I, for one, like to know how to operate all of the gewgaws and whirligigs...
    kithmo, RCO, pilotgrrl and 2 others like this.
  10. Yuki
    Yuki Junior Member
    Columbus OHIO
    Thanks.
    But I press it.
    Nothing changes/ nothing shows up.
    Is it possible I got a defective bottom?
    I mean when you press it, it suppose to change something right?
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Yuki, you have to be using the the cruise control with car in forward motion and a target speed set BEFORE you press the button for it to work. I'm not gonna lead you by the nose through extracts from the manual, but strongly recommend you actually read it for yourself. There are important safety notes in there that Toyota want you to be aware of, and I'm not qualified to teach them to you. (y)
    #11 RCO, Feb 22, 2018
    Yuki, pilotgrrl, RRxing and 3 others like this.
  12. SneezyKevinA
    SneezyKevinA Junior Member
    26
    47
    New Yuck
    2018 Prius
    Actually, Tire info is one thing you should NOT ignore!
    RCO, pilotgrrl and krmcg like this.
  13. RRxing
    2,537
    1,810
    NEPA
    I only need to know tire size, tread depth, and pressure. Everything else is 'nice to know', but not essential...
  14. Prodigyplace
    12,462
    11,703
    Central Virginia
    Load rating of the tire is nice to know? For safety it is essential.
  15. alanclarkeau
    7,045
    7,592
    Yeah, but not till it comes time to replace them - which will hopefully be someone else's worry.
