What is this for
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by douglasjre, Feb 19, 2018.
  1. douglasjre
    douglasjre Senior Member
    2,147
    711
    Null, NL
  2. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,517
    Bay Area, California
    2019 Prius Prime
    It’s actually a drain spigot that you can hook up to some of the oil filter housings;).
    Not needed on the Gen3 Prius (at least the ones I have looked at), but on our 2017 Lexus RX450h the oil filter housing is designed to have a central drain removed and the plastic spigot installed. I tried it and it didn’t work so well, as there still was oil In The housing upon removal :(.
    It came with your oil filter purchase:whistle:?
    NutzAboutBolts and tankyuong like this.
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,692
    1,736
    Bay Area
    Those are used for those A3 cartridge filters for Toyota and Lexus vehicle’s. The Prius uses an A1 cartridge filter, so they don’t use that. Honestly, that piece is the most useless piece ever, not worth your time doing it that way. Just my opinion.
    Raytheeagle likes this.
  4. douglasjre
    2,147
    711
    Null, NL
  5. Raytheeagle
    11,265
    15,517
    2019 Prius Prime
  6. NutzAboutBolts
    1,692
    1,736
    Bay Area
    Disregard, the Prius uses A6, bigger engine uses the A1.
