Help me PriusChat, you're my only hope (to identify these screws...)
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by UltraJetRefill, Feb 19, 2018.
  1. UltraJetRefill
    156
    93
    Tucson, AZ
    I've had the car since Dec 2017, and never noticed them (ahem, maybe I should vacuum more...). Two screws were sitting next to the carpet on the driver's side (yellow circle in pic). Does anyone know where they might have come from? They almost look like they would screw into plastic.
    My original thought is that someone removed the inside door cover when installing the window tint and forgot to reinstall them. I watched this video on the door panel removal (fascinating, BTW!), and the screw with the larger head might be the one under the cover of the interior door latch (#2 in the first video). He only removes three though, and none look like the small one in my pics.
    Door panel removal.
    This guy does it much slower, and screw #1 and #3 don't seem to match mine. Maybe #2...
    I guess I just need to pull the panel off and see if anything's missing, but I thought I'd check in first. I do have the plastic body panel tools, so I guess that's good. I always get a little nervous with plastic tabs though. :eek:
  2. Mendel Leisk
    41,000
    They're two distinct screws, look like self-tapping tips, and both those factors say to me they are not stock. Maybe something spilled out of an installer's pocket??
    If you're not hearing anything untoward, I would do nothing, certainly don't start prying panels off. I've never heard of tinters needing to open up door panels.
    kithmo, RCO and UltraJetRefill like this.
  3. UltraJetRefill
    156
    93
    Tucson, AZ
    I'm hoping you're right. I'm not very familiar with how the window tint is put on, but it seems like it would be quite difficult to press it on near the front-bottom of the window without removing the door panel since it's kind of hidden. I agree though, I really don't want to go pulling the door panel off since it will undoubtedly mean I have a squeak after (a la Murphy...).
  4. bisco
    51,553
    agree with mendel. put 'em in a jar with a label, but ignore them until something becomes obvious.
    kithmo, RCO, Tande and 1 other person like this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    They look like self-drilling metal screws (which are great for drilling plastic too. As suggested, could have come from anywhere. Someone else had the same last year, think they worked out it belonged to a temporary security system installed by the dealer while their car was on the lot - removed at sale, but screw was left on floor.
    If it was from the door panels, a tint installer might have been like you "can't find that screw" and grabbed another two from the bench dropping one of them in the darkness too.
    RCO likes this.
  6. padroo
    padroo Senior Member
    2,763
    2,252
    It's not unusual to find a few loose screws in new cars. Those are the self tapping variety with the washer head.
  7. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    I would definitly use the top picture one to secure a wood stove or pellet stove chiminiea pipe in place, the bottom one is also a canidate but for some sort of cast iron flange, Toyota uses plastic screws for plastic trim, if you have an illiminated door sill plate that's black and is missing iron screws, na, they would be aluminum.
  8. alanclarkeau
    7,045
    7,592
    Check with a magnet - it could be aluminium).
    UltraJetRefill likes this.
  9. UltraJetRefill
    156
    93
    Tucson, AZ
    That's a definite possibility. My previous car had something like that installed. I'll have a look under the steering wheel area and see if there are any holes missing a screw. I'm really just curious at this point.
    RCO likes this.
  10. UltraJetRefill
    156
    93
    Tucson, AZ
    Both are attracted to neodymium magnets.
    Prodigyplace and alanclarkeau like this.
  11. alanclarkeau
    7,045
    7,592
    If you don't find anything easily, I wouldn't worry too much - could have fallen out of the pocket of any of the people who drove your car in transport transfers, or a mechanic doing a pre-delivery.
  12. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    FWIW, so am I. :sneaky:
  13. Prodigyplace
    12,463
    11,708
    Central Virginia
    Too much iron in the diet? ;)
    RCO likes this.
  14. alanclarkeau
    7,045
    7,592
    Are you sure it would pick up an aluminium screw? Not from what I read.
    I've got some very strong magnets from out of a microwave oven, and they won't pick up anything aluminium. BUT - they will cause micro-movement of aluminium foil.
  15. UltraJetRefill
    156
    93
    Tucson, AZ
    Sorry, I should have clarified. They are strongly attracted to these magnets. I think they're definitely not aluminium.
  16. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I wished! It's mostly oxidised to trust now. :ROFLMAO:
    kithmo, pilotgrrl and Prodigyplace like this.
  17. Prodigyplace
    12,463
    11,708
    Central Virginia
    auto-correct strikes again! :LOL:;)
    kithmo and RCO like this.
  18. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Doh! :mad:
    kithmo and Prodigyplace like this.
  19. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    I think some on here have a few loose screws (me included) :LOL:
  20. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Aluminium is diamagnetic i.e. slighly repels a magnetic field. The magnetic field will go around it, rather than through it.
