Best Spark Plug Replacement for Gen4?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Mavi, Feb 20, 2018.
  1. padroo
    padroo Senior Member
    2,763
    2,251
    Here is is a Bosch video showing the where the iridium is located on the spark plug. A different design than the Denso.
    http://www.youtube.com/watch?v=R5_vtsFuNfk
    j12piprius likes this.
  2. David E. Edwards
    David E. Edwards Junior Member
    25
    Sugar Land, TX
    The best advice is to install exactly the same brand and model that came in your Prius. This goes for
    almost all new cars today. They are built to different specs. that the older ones were and onlythe very best
    is needed to preform up to our expectations.
  3. kithmo
    kithmo Couch Potato
    2,404
    2,774
    47
    South Yorkshire, UK
    Can Gen 3, Denso SC20-HR11 plugs be used in the Gen 4, instead of Denso FC16-HRC9 ?
  4. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    I'd be saying NOPE.
    It is a quite different plug, FC vs SC indicate they're different in shape; plus different heat range, different gap (which on Iridium can't be altered), and the HRC9 indicates a different shaped ground electrode.
    DENSO SPARK PLUGS
    RCO and kithmo like this.
  5. wjtracy
    wjtracy Senior Member
    11,359
    3,606
    Northern VA (NoVA)
    Iridium is a very rare and extremely valuable substance.
    I would tend to wait for recommended interval (125k?) to replace (actually I waited to about 135K miles).
    I still cannot bring myself to toss out my old plugs.
    amos likes this.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,774
    47
    South Yorkshire, UK
    According to the chart below, there are some subtle differences but they appear to be very similar. The on the Gen 3 plugs, SC20=HR11, the S denotes that the electrode is thicker 0.7mm compared to 0.55mm, the 20 indicates the next heat range not sure what is different about the C in HRC on the Gen 4 plugs, it just says shape and the end number is the electrode gap, 11 = 1.1mm on the Gen 3 plugs and 9 = 0.9mm Gen 4.
    I was wondering if the differences were radical enough not to use them, e.g. would a 1.1mm gap overload the coils on the Gen 4, would the difference in the shape of the electrode make it possibly foul the pistons etc.
  7. Mendel Leisk
    40,524
    That got me drooling, here's a link to the pdf:
    http://www.globaldenso.com/en/products/aftermarket/plug/catalog/europe/pdf_m/pdfcatalog_eu_mo_all.pdf
    kithmo likes this.
  8. alanclarkeau
    7,045
    7,589
    Expensive experiment if it fails - I'd hate to imagine the co$t of an ignition module etc on a PRIUS.
    My reading of it is - there's not much the same. You might bet away with it in a lawn-mower, but a PRIUS (or any modern car).
    You could send an email to DENSO and ask, they might respond.
    And if they don't work, you've got some expensive plugs you'll have to try to sell.
  9. kithmo
    kithmo Couch Potato
    2,404
    2,774
    47
    South Yorkshire, UK
    Thanks Alan, I think you're right, it's not worth the risk.
    I doubt I'll get to the 100K miles due change anyway, at 3K miles per year its gonna take me another 31 years :LOL:
    Oh well, 1 set of Gen 3/Prius+ plugs to go on Ebay.
    RCO likes this.
  10. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    So has anyone actually gotten enough miles to change them yet? Even here in the middle of 2019, I had to pull hen's teeth at the dealer just to order them, as they're not stocked... And the Bosch fit a 5/8" plug socket, which will NOT fit into the tubes in the head.
    I'm still not even sure if the right plugs are on their way, as the part number on the bill is 90919-01265, which by any Google search I do screams Prius C compatibility. This after they matched the part number via VIN. :rolleyes:
  11. alanclarkeau
    7,045
    7,589
    How many miles have you done?
  12. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    I'm at 96,500 as of typing this post, and while I know the plugs are rated for 120,000, I've been doing heavy towing, so I'm thinking my current drop in fuel economy (about 12-15% from baseline while deadheading) is indicating a need for new plugs.
  13. amos
    amos Active Member
    362
    281
    los angeles
    did you get to 120k or not yet?
    did you change those plugs, mine is 2016 and 105k mi now.i wonder is it easier to relace than the gen 3 or still same issue with wiper assembly and crawel bar needed to be disassembled to get an access to them. Planing to change this coming weekend
    i bought those toyota plugs. hopefully im not wrong manual says right p/n is FC16HR-C9 @Mendel Leisk ?
    90919-01275
    SC16HR11
    IRIDIUM
    #33 amos, Jul 15, 2019
  14. Prodigyplace
    12,398
    11,676
    Central Virginia
    @Elektroingenieur has access to the official documentation.
    amos likes this.
  15. Mendel Leisk
    40,524
    Those I think are the revised (slightly hotter) third gen plugs.
    They're Denso plugs btw: I don't believe Toyota makes plugs, and not sure if they would assign them a part number. Maybe they do assign them a part number, but they spec them in Owner's Manuals by the manufacturer's designation, and it's simplest to stick with that.
    From 2010 Owner's Manual:
    From 2016 Owner's Manual:
    Prodigyplace and amos like this.
  16. Prodigyplace
    12,398
    11,676
    Central Virginia
  17. Mendel Leisk
    40,524
    Which looks to be the Denso plug spec'd in the Owner's Manual, with a Toyota part number assigned.
    amos likes this.
  18. Prodigyplace
    12,398
    11,676
    Central Virginia
    It may be. I am not going to pull mine out to look.;)
  19. Mendel Leisk
    40,524
    All the info is in your Owner's Manual. ;)
    Anyway, @amos likely has 3rd gen plugs in hand: I wouldn't gamble that they're compatible.
    amos likes this.
  20. Prodigyplace
    12,398
    11,676
    Central Virginia
    Not in the Maintenance Manual - I looked.
