Engine light on only
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by John T. Lytle, Feb 26, 2018.
  1. John T. Lytle
    John T. Lytle New Member
    Sacramento
    This morning I use my 2004 Prius and it was fine. Then this afternoon, I tried to start it but only Engine light came on, nothing else. I can't use my car right now. Anyone know about this?
  2. JC91006
    JC91006 Senior Member
    16,656
    8,504
    I can see a new battery in your future
  3. Stevewoods
    Stevewoods Senior Member
    652
    1,062
    Seattle, WA
    The hopefully, simple answer would be the 12v battery is weak.
    They are anywhere from around $150-$250 for a Gen II. I know not what they cost for a Gen I.
    I also do not know how involved it is to install in a Gen I. I would imagine a bit of a PIA, but not impossible.
    Anyway, that would be the first thing I would consider.
    Of course, you could always get the code read, but if you or a friend have a multi-tester/voltage meter, checking the 12v should be easy enough. Again, I am not acquainted with how the Gen I is put together.
  4. JC91006
    16,656
    8,504
    The 2004 is a gen2
  5. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    For the lights that are illuminated on the dash, there will be stored codes;).
    Do you have a way to read them?
    Keep us posted (y).
  6. Mendel Leisk
    40,482
    The presence of the Engine warning light will mean there's a code stored. Assuming you can't read the codes, and unless you can get some dealership mechanic to make a housecall, it'll likely require a tow, and for somewhere hopefully under a $100 more they can check with Techstream what that code is, propose a course of action and give a quote.
    All that aside though: check the low-hanging fruit first, the 12 volt battery condition, oil and coolant levels.
    If the 12 volt is fine, and just for giggles: try disconnecting the 12 volt negative lead, say for 30 seconds, then reconnect and try starting again. If it does start after that, I'd maybe go directly to the dealership. The only downside, the disconnect, would the disconnect have wiped stored codes??
  7. John T. Lytle
    Sacramento
    I tried that today and no changes! damn!
  8. bisco
    51,032
    check the gas cap.
  9. Mendel Leisk
    40,482
    Do you have access to a ScanGauge. That's one gizmo I know that will read codes so you can look them up, and can also dismiss them, see if they come back. There's other gizmos I'm sure, that the one I'm semi familiar with.
  10. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
  11. John T. Lytle
    Sacramento
    New 12v Battery has replaced last week. The car was fine for a week.
  12. John T. Lytle
    Sacramento
    Right now I can't use the car. No dashboard lights or running engine.. Only "Check Engine" came on.
    Raytheeagle likes this.
  13. JC91006
    16,656
    8,504
    1. Charge the 12v battery if it's drained
    2. Check what's draining the battery
    3. When you're able to start it again, check the voltage when it's READY. should be over 13.8v. If not, your battery is not being charged
  14. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    A check engine light only speaks to emissions related issues. The Prius should start unless the 12 volt is too low in voltage to get the computers to the “ready” state.
    Does the dash display the green ready light?
  15. JC91006
    16,656
    8,504
    Can you post a picture of the light that's on?
