Does your gas button glow when turning on headlights for Prime?
Discussion in 'Prime Main Forum (2017-2022)' started by lexusaurus, Feb 26, 2018.
  1. lexusaurus
    lexusaurus Junior Member
    Los Angeles
    Just noticed that mine doesn't light up like all the other buttons. Had a hard time finding where it was at night when I had my headlights on. Wondering if this is a defect or was it just made like this. Doesn't seem to make sense having one button not light up like the rest. Thanks in advance fam!
    HPrimeAdvanced likes this.
  2. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    mine is not lit either. I think that's normal. I agree it could have been in a better place. On the floor by the seat leg like on the Camry would have been better.
  3. bisco
    52,763
    not all the buttons in toyota's light up. it has been a head scratcher for my nearly 20 years of ownership.
  4. Dudley1030
    200
    139
    Lawrence, KS
    I really wish the window and door locks always lit up on all the models.
  5. Prodigyplace
    12,710
    11,848
    Central Virginia
    You mean the controls on the doors? They light up on my Gen 4.
  6. Skapruisprime
    Skapruisprime Member
    122
    49
    MA
    i guess they want us to open the gas door when we’re outside the car???
  7. Prodigyplace
    12,710
    11,848
    Central Virginia
    Then why put the button inside?:rolleyes:
    Wuzki and HPrimeAdvanced like this.
  8. DavidA
    2,349
    1,825
    Chicago western burbs
    I was astounded that all the buttons inside the door are not lit in the Prime. Same with the bottom left buttons on the dash by my left knee. Don't know what they're thinking. Shouldn't Toyota be about driver safety? Why make us hunt for these any longer than necessary?
    bisco and HPrimeAdvanced like this.
  9. Skapruisprime
    122
    49
    MA
    Haha, that is why Im not an engineer
  10. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I do not know about the answer to your question, but don't worry since there are many folk here in PriusChat who will be able to help you out, however your question scans in a way which reminded me of this song from when I was a nipper, growing up in Blighty:
  11. Tideland Prius
    16,668
    To be fair, that gas button isn't going to be used often. And when it is used, the gas station is pretty damn bright.
    It's not lit on the 2016 either.
    Mark57 and HPrimeAdvanced like this.
  12. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Don't worry, Nissan has Toyota beat in this regard. They use the same parts on lots of vehicles and purposefully degrade them for different cars. For example my top of the line Leaf on the driver side door the window up/down and door lock/unlock don't light up at all. But the PCB inside is the same as in the Altima and other vehicles and there is an LED that is there to light it up. Even the plastic has the proper see-through plastic. But Nissan saved 6 LEDs, about a nickel worth of parts, and now my panel doesn't glow. The solder pads are there, just no LEDs.
  13. DavidA
    2,349
    1,825
    Wondering what is involved with lighting up the door buttons in the Prime. Might the assembly below it already have wiring for an LED?
  14. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    AND the "remote garage door opener" buttons on my Advanced fancy schmantcy inside rearview mirror don't light up either, so you've got to do the "Button Grope" in the dark before you run into your automated garage door!
    AChoiredTaste.com
  15. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    My Prime doesn't get gas; it nibbles on electrons!!
    AChoiredTaste.com
    benagi and Tideland Prius like this.
  16. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Mr. DavidA,
    All the buttons on the doors of my Advanced light up at night. These are the window, etc. buttons. The trunk light in my car was turned off when I bought the car; didn't even know it was there! Turning it on, allows opening of trunk to turn on the light. So much stuff on this car!
    AChoiredTaste.com
  17. DavidA
    2,349
    1,825
    Once turned on, does the rear hatch area light turn itself off when the hatch closes?
  18. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Yes sir!
    AChoiredTaste.com
    Dudley1030 likes this.
  19. DavidA
    2,349
    1,825
    Cool. I've got to try that. I might worry, though, that if it is really off, like in refrigerators? A mistake like this once killed my 12v in a previous car.
    HPrimeAdvanced and Dudley1030 like this.
  20. Prodigyplace
    12,710
    11,848
    Central Virginia
    So, leave the cargo cover off & look!:rolleyes:
