Want to be a Prius Owner.. Please advice
Discussion in 'Gen 2 Prius Main Forum' started by jcas, Jul 25, 2006.
  1. jcas
    jcas New Member
    Hi everyone,
    I'm planning on purchasing a used Prius (01-02). I have a few questions before buying:
    1. I wanted to know if there are any known major issues with these (01-02) models?
    2. I heard that maintainence are needed sooner & more expensive then regular cars. Can someone clarify this?
    3. My commute is 100miles per day in Hot california weather & wanted to know what to expect for MPG?
    Thanks in advance,
    JCas
  2. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    For the most part, Toyota's been pretty good about taking care of "major" issues with recalls. That being said, i have and 06, so i don't know much about the 02's.
    For maintainence, i'm pretty sure it's actually a little less. Typically the stock tires suck, but those should already have been replaced, so you shouldn't have to worry about that. The brakes tend to last a bit longer than normal cars (due mostly to the regenerative frictionless braking), and i haven't heard anyone complain about excessive maintainence on the 02's.
    There are several factors that effect mileage. distance per trip, temperature, speed, inclination, and the habits of the driver. Given the long trip length and the higher temperatures, you wouldn't have to worry about the engine warm up wasting any gas. There are some really good articles on here about how to improve your mileage (in terms of optimal speeds and different techniques like pulse and glide).
    So in short, browse around the site and i'm sure you'll get a feel for the car and how much everyone loves it!
    *EDIT*
    here's a link to get you started: http://priuschat.com/New-owner-Want-MPG-he...rst-t15311.html
  3. Tideland Prius
    16,494
    Also note that aside from the lower official mpg than the new Prius, the A/C will take a toll on mileage moreso on the Classic than the new Prius because in the old Prius, the engine has to run to provide A/C even when stopped. You can select ECON mode (economy) which would shut off the A/C compressor at a traffic light but you'll lose the cool air for the length of the red light.
    Maintenance shouldn't be any different from a regular 2WD Toyota. You'll have to replace the brakes less often due to regenerative braking (unless you drive like an Indy 500 driver) and take special care when choosing replacement tyres. The stock Bridgestones are XL rated tyres.
    You'll have no alternator to replace, coolant will be changed at 100,000 miles, no power steering fluid to replace.
    Lastly, welcome to PriusChat!
  4. jcas
    jcas New Member
    What year did they start putting the currently used new engines? Did it change in 05?
  5. eagle33199
    5,122
    268
    2015 Prius v wagon
    my guess would be '04. everything before (in the US) was a first generation, then the '40-'06 is the second generation, most likely to be replaced in the '08-'09 time frame with the third generation.
    of course, there was even a generation before that (Zero, Null?) in Japan that never made it to the US.
  6. Benonymous
    Benonymous New Member
    Toyota began building and delivering the 2004 model in 2003 so you may find one (like I did) which reduced my buy-in by around 4-6K. If you can stretch to it, definitely get the current shape car. The Prius I seems to be a bit of an orphan as far as mods and knowledge base goes.
  7. mcbrunnhilde
    mcbrunnhilde Opera singin' Prius nut!
    619
    26
    <div class='quotetop'>QUOTE(jcas @ Jul 25 2006, 11:00 AM) [snapback]292058[/snapback]</div>
    I don't know if a member named tochatihu will see this thread, but he is a Classic owner who is always very helpful and willing to share information about the car. You could try sending him a PM and I'm sure he'd respond to your questions.
  8. Tideland Prius
    16,494
  9. john1701a
    john1701a Prius Guru
    12,802
    5,286
    57
    <div class='quotetop'>QUOTE(Tideland Prius @ Jul 25 2006, 11:50 PM) [snapback]292420[/snapback]</div>
    Errors in documents live on for years. Corrections & Retractions rarely get noticed. So inaccurate sources still get quoted. Problems like that plague the scientific community. So be thankful don't have to deal with it more often. Unfortunately, we do still have some antagonists that intentionally exploit this situation.
    Prius was SULEV.
    That fact absolutely infuriated certain Honda hybrid owners, since they only had ULEV originally. There is a wealth of supporting evidence available in old forum posts from the "classic" era. The history is pretty interesting.
    Without low-sulfur gas, maintaining SULEV for the entire required 120,000 duration is somewhat of a challenge. Levels of sulfur varied too much throughout the country for any guarantee to be made. So when Honda finally started to build a SULEV version, they abruptly decided against making it available anywhere except the 5 CARB states. Toyota didn't care. ULEV was so much dirtier and only had a rating duration of 100,000 miles. So the special cleansing equipment and system operation was available to everyone nationwide from day one for Prius. I was delighted, since the gas I use had been low-sulfur (despite not living in a CARB state) since way back in 1999.
    I wonder what other hybrid history will be obscured & distorted as time proceeds.
  10. Tideland Prius
    16,494
    Hmm, I just checked. It says ULEV only for the original 2001 brochure. It's SULEV in the 02 brochure.
