Are there any high speed techniques for long distance?
Discussion in 'Gen 3 Prius Fuel Economy' started by bentbow, Mar 6, 2018.
  1. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I see Threej has used my Get a haircut/Give blood/Helium balloon diet.
    Threej likes this.
  2. Mendel Leisk
    41,334
    Flip the rear seat down? Someone semi-seriously proposed that as a mpg booster once.
  3. Prodigyplace
    12,533
    11,755
    Central Virginia
    The obvious answer is in @bwilson4web 's avatar. I thought everybody here knew that. :ROFLMAO:
    bentbow, mjoo and WilDavis like this.
  4. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    The title of your thread reminds me of an old joke where an old farmer had asked a young neighbour to help him out by painting a fence in his yard, and after a while was surprised to find the job nearly complete when he checked to see how the young chap was getting on! When he asked him why he was in such a hurry, he was told "Well, I've used nearly all the paint, and I wanted to finish the job before the paint runs out!!!" :D:D o_Oo_O ;)
    mjoo likes this.
  5. frodoz737
    frodoz737 Top Wrench
    4,694
    2,496
    33
    Hey...how 'bout just set the cruise control and be happy you get better mpg than most.
    jerrymildred and WilDavis like this.
  6. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
    Bob must have a virtue of platooning graph around here somewhere...
    Pixel XL ?
    Prodigyplace likes this.
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    In a thread with a lot of spoof answers (as there are no real answers) this one may almost seem sensible.
    Do not draft. If every other driver drove responsibly, you could. I have not met many responsible drivers.
    The A/C cools the battery. If you care at all about battery life, keep it cool.
    Your headlights warn other drivers where you are, they need all the help they can get. Keep them on. (I have to turn mine on every 5000 miles as my mechanic turns them off)
    Measure the time difference between attempting to drive fast and attempting to drive safely. It is very small for hundreds of miles, starts to be significant for thousands of miles.
  8. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    Yep, I agree with everything you wrote. And I wouldn't do any of what I suggested, mostly because if I were to drive faster than the speed limit, then I would also accept the inevitable decrease in mpg. 40+ mpg going 80+mph is still pretty good in my book.
    jerrymildred likes this.
  9. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    It is an illusion or a joke.
    Look up the "placebo effect".
  10. William Redoubt
    William Redoubt Senior Member
    1,228
    1,172
    Coronado Island, California
    Let me fix that for you. "Draft ANY semi." They all speed, at least in California, where the speed limit for trucks and vehicles with trailers is 55 mph. Except in the mountain passes. That's when they run two and three wide, taking up every lane of travel.
  11. fotomoto
    fotomoto Senior Member
    5,632
    3,810
    So. Texas
    Get the best rated LRR tires and crank up the pressures to uncomfortable levels and start making aero-mods: taping off front end gaps, plexiglass covers over grill openings, solid wheel covers, fender skirts, remove mirrors, lower car, lengthen front skirt, etc.
    Or just slow down.
    j12piprius likes this.
  12. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    Lower grill block.
    Never 100% block if engine load is high such as uphills and or blasting AC. Can be easily remove and reinsert as needed.
  13. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    This^^^
    Start reading here and then buy this book. You'll end up with something that looks like this:
  14. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Kind of depends on what you mean by "Getting There Quickly".
    I loved my Prius for long highway drives. I found I could go safe, sane, tangible and real highway speeds routinely and return phenomenal gas mileage.
    Now if you want extended- illegal- sports car like speeds?
    The Prius simply is not function built for that type of driving experience.
  15. Mendel Leisk
    41,334
    That's also one of the quickest ways to give it a drinking problem?
    mjoo likes this.
  16. bentbow
    bentbow Junior Member
    34
    bay area
    i'll be sure to reserve all my driving for those days along with putting up a sail to capture wind
  17. qdllc
    qdllc Senior Member
    1,375
    400
    An all downhill trip plan.
    jerrymildred and Prodigyplace like this.
  18. Prodigyplace
    12,533
    11,755
    Central Virginia
    Yeah, but the return trip could be a challenge... ;)
  19. bentbow
    34
    bay area
    Easy... Downhill both ways.
