Getting ready to replace the Spark Plugs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by iskoos, Mar 12, 2018.
  1. iskoos
    iskoos Active Member
    403
    251
    Orlando, FL
    I am at 145k miles (3rd owner) and per the service records plugs never been replaced.
    I am not having any issue but as a preventative maintenance, I plan on replacing them soon.
    Can you guys recommend the type and especially a reliable online store to order them?
    I normally order my car parts from autohausaz.com
    They do have 2 types in stock currently:
    1- BOSCH Fine Wire Iridium ($8.28 each)
    2- DENSO Iridium ($9.91 each)
    Is any one of the above preferred plug for Gen3 motor?
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Hey! Sounds like a good plan, definitely go with the Denso. We've had a good amount of people repot mpg loss with other plugs, like Bosch over the years. Denso are fantastic and will last for a very long time (as in your case)
    Bay Stater and bisco like this.
  3. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    denso or ngk
  4. bisco
    51,025
    agree with both above. the oems are great plugs, and inexpensive.
    Aaron Vitolins, Bay Stater and Tande like this.
  5. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,501
    1,597
    Bay Area
  6. iskoos
    403
    251
    Orlando, FL
    Seems like I am getting Denso Iridium plugs. Though after checking different sources (ebay), I found the same plug much cheaper under the same exact brand (Denso) and part number (SC20HR11).
    ebay sells them (set of four) for around $27 (shipped).
    autohausaz lists the same plug for $9.91 each (plus the applicable shipping).
    The only difference I see is the autohausaz Denso SC20HR11s labelled as "Long Life". The ebay Denso SC20HR11s are Genuine Toyota/Lexus/Scion branded.
    Are there two different types Denso SC20HR11s out there one being the Long Life as claimed?
    Aaron Vitolins likes this.
  7. Mendel Leisk
    40,470
    Hate to open this can of worms, but was there a notice from Toyota, to go one step hotter? IIRC the 20 in the Denso plug number goes to 16?
    The dry thread torque spec is 15 ft/lb, and if you use any amount of anti-seize maybe 12-13? Or just stick with dry threads?
    Socket size is 9/16" or 14mm.
    RightOnTime likes this.
  8. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    Post close up photos of the old ones here, carious minds would love to see them at 145k.
  9. iskoos
    403
    251
    Orlando, FL
    Sure, once I remove them I will post the pictures here...
    Raytheeagle likes this.
  10. iskoos
    403
    251
    Orlando, FL
    I will check the manual for the recommended plug type before ordering. Maybe I should have already done this...
  11. Mendel Leisk
    40,470
    You were on the money, this is from the Owner's Manual:
    But there was some edict, maybe Toyota found they were fouling a bit, the engine running cooler than anticipated, so they revised the 20 to 16? maybe. For starters if you phone a dealership service department, and ask, they might be able to shed light. And also will give you a price. It'll very likely be higher than most anywhere else, but it doesn't hurt to ask, and you can hopefully clear up if there has been a heat range revision.
  12. Mendel Leisk
    40,470
  13. iskoos
    403
    251
    Orlando, FL
    Thanks Mendel. I confirm the SC20HR11 from my owner's manual (P. 562) which printed in 2010. If there is an update it surely won't show it. I got home too late to check with the dealership parts dept. tonight. I will check with them tomorrow and let you guys know the outcome.
    I will actually check with two different dealers to be sure...
    Mendel Leisk and Raytheeagle like this.
  14. 12voltman
    12voltman Member
    124
    93
    Just got new plugs directly through the Toyota dealer . (I forget the actual Toyota part #) .
    The new correct plug number is SC16HR11.
    I doubt the Toyota dealer would even have the SC20HR11any longer , as they have been superseded to the SC16HR11.
    The dealers should have exhausted the SC20HR11's by now, and probably only have the SC16HR11's on the shelf for sale .
    I knew about the new part number before I called the local Toyota dealer , but didn't even have to bring it up . They already have the new ones in the system .I just asked for new spark plugs for my 2011 gen 3, and I was sold the SC16HR11
    j12piprius and Mendel Leisk like this.
  15. iskoos
    403
    251
    Orlando, FL
    Well then that's what I am gonna hear from them tomorrow. Mendel you are right it seems:)
    12voltman, how much the dealer charged you for the set?
  16. Mendel Leisk
    40,470
    I would ask dealership for price, but i find without fail other places are cheaper. Last time I was plug shopping a (Honda) dealership was around $24 per, and a small automotive retailer got them for me for around $18. Canadian prices btw, always higher.
  17. iskoos
    403
    251
    Orlando, FL
    Checked with two dealers in town today. Both confirmed the updated part number as 90919-01275 (SC16HR11).
    Dealer price is about $13 each. I found them for half the price online and ordered them. They should be here within a week.
    The price of SC20HR11 is much lower than SC16HR11. And I think the reason is because no demand for SC20HR11 anymore. You could get a set of four for as low as $15 (s&h included). SC16HR11 sells for twice as much.
    It is funny that we people are so freak about getting the most up-to-date part that we don't mind paying more.
    I have no doubt in my mind that if I were to get SC20HR11 and put them in, my car would run the way it is now and I wouldn't see any difference.
    In fact, the plugs in them right now most likely SC20HR11.
    But I am one of those freaks that want the most up-to-date part:)
  18. Mendel Leisk
    40,470
    If you've got Denso SC20HR11 (pretty much guaranteed) and they're not fouling, you'd continue to be fine with them. I've had ours out, around 60K kms, just for a look. Can't recall, but I'm pretty much certain they were the 20.
  19. 12voltman
    12voltman Member
    124
    93
    I dont have the invoice in front of me, but I think the plugs were $12. and change from the Toyota dealer .
    Yes, more than one would pay at an auto parts store for spark plugs , BUT , these are the correct Denso iridium factory plugs AND only the Toyota dealer had the correct superseded Denso plugs in my area . MOST of the spark plugs you find at the autoparts stores are not technically the correct plugs for the gen 3 . Most iridium plugs (that were not even correct for the gen3) at the autoparts stores were not exactly cheap either .
    I felt a little better getting the correct plugs from the Toyota Dealer , even at the slight dealer mark-up in price.
    On the gen 3 , there is a lot of stuff to remove to get to the plugs .....I only wanted to do it once !
  20. iskoos
    403
    251
    Orlando, FL
    I would love to check them out but I cannot convince myself to do all that work just to see how they look.
    Once they come out, the new ones must be going in:)
    But as I promised I will be posting the picture of them here...
