Prius Prime Diag & Service Menu 11-in display
Discussion in 'Prime Technical Discussion' started by zeepy_aviation, Mar 21, 2018.
  1. zeepy_aviation
    zeepy_aviation New Member
    Cave Creek AZ
    I searched a few times but wasnt able to locate this in the forums for 2017+ Prius with the tablet style display.
    ****Do not recommend making any changes or attemptong to access unless you know what you are doing, disclaiming all risk if this bricks your vehicle or display****
    Nice to be able to attain the battery status and some other goodies. I prefer the service menu because it appears to give you access to diagnosis mode while diagnosis mode does not give you access to service mode.
    Have lights set to off/DRL off
    Then>> While in accessory mode
    a) service menu
    1) press and hold home button
    2) flick lights off to tail off to tail off to tail off to tail
    3) wait few seconds
    b) diagnostic menu
    same as above except hold “menu” button with the little circles instead of home
    to exit, turn off car all the way (1 or 2 more presses of the car on/off button). I have a feeling there may be other ways to exit the service menu. Once I did this and started the car as normal, I did see a popup about “leaving service mode” or something similar on the map on the display
  2. bb4srv
    bb4srv Active Member
    140
    107
    2018 Prius Prime
    Technology
    Can you elaborate this a little more? Flick what lights? To what tail? Thank you!
  3. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    too bad it doesn't have the ability to disable gps entry. (like the old gen 2 early model up/down/up/down/up touch hack)
    I mean really... it lets me go in and book movie seats and get table reservations while driving, but not enter gps destination.
    (mind you i'm not advocating for doing this... I never do this myself, but if I have my wife with me it would be nice to allow her to enter).
  4. Mark57
    2,945
    2,738
    OK
    Just to add clarification in case the term "tail" is confusing, you can use any two positions on the stalk. Off to Auto or off to DRL or the other selections as long as you do it 4 times.
    Wuzki likes this.
  5. Wuzki
    Wuzki Member
    101
    34
    los angeles
    Time to get our hands wet.
  6. bb4srv
    140
    107
    2018 Prius Prime
    Technology
    Got it. Thought it was this:
  7. Diemaster
    Diemaster Active Member
    293
    260
    so. cal
    why do you always have to make everyone the butt of your jokes?
    walterm likes this.
  8. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    Is it possible to turn on the video feed option via service mode? Currently we do not have the video feed option enabled for phone mirroring to work.
  9. wzakaras
    wzakaras Junior Member
    using this method, is it possible to put the "grille shutter system" in maintenace mode? or is the only way with Techstream?
    thanks
  10. Elektroingenieur
    2,515
    3,281
    Three Touring
    No. The Navigation Receiver Assembly’s diagnostic mode is only for the navigation and rear view monitor systems; as I wrote before, it is not a general diagnostic or indicating system for the vehicle.
    The only way to enter Maintenance Mode mentioned in the Repair Manual (more info) is to use the Body Electrical > Grill Shutter > Utility > Grill Shutter Control Mode Switching function of a Toyota Techstream diagnostic system. Once the Grille Shutter System is in Maintenance Mode, driving will restore it to Normal Mode; Toyota writes, “The grille shutter control mode will be changed and initialization will be performed automatically when the vehicle speed exceeds 5 km/h (3 mph).”
  11. illumiN8i
    illumiN8i Active Member
    184
    142
    Grand Rapids, MI
    2018 Prius Prime
  12. LightningBolt
    LightningBolt New Member
    27
    Rhode Island
    2020 Prius Prime
    Can you get the 12 volt battery status from either of these menus?
  13. Elektroingenieur
    2,515
    3,281
    Three Touring
    Under Service Menu > Function Check/Setting > Vehicle Signal, there is supposedly a “Battery” voltage readout, but I believe this actually shows the DC input voltage at the Navigation Receiver Assembly—as you’d expect, since the Service Menu is for diagnosing the multimedia system, not the rest of the car.
    When the car is in READY, the 12-volt bus is usually energized by the DC-DC converter, not the auxiliary (12-volt) battery. Even in ACC or IG-ON modes, with the DC-DC converter off, the reading is likely to be lower than the voltage at the terminals of the battery under the hood, due to the voltage drop in the wiring.
    If you want to know the battery voltage, I’d suggest measuring it directly. I keep a Hioki pencil-style digital multimeter (in the special 3246-70 grade with the see-through case, of course) in the car for this purpose, but a Toyota Electrical Tester Set or a $12 multimeter would likely serve just as well.
    To check on the auxiliary battery management system, you’ll need a Toyota Techstream diagnostic system or equivalent. Related items on the Powertrain > Hybrid Control > Data List page include:
    • DC/DC Converter Operation Status
    • DC/DC Converter Output Voltage Control Mode
    • DC/DC Converter Drive Request
    • Target DC/DC Converter Voltage
    • Auxiliary Battery Voltage
    • Auxiliary Battery Current
    • Smoothed Value of Auxiliary Battery Temperature
    • Auxiliary Battery Voltage Low Times
    • Auxiliary Battery Voltage at Low Voltage Checking Initiation
    • Auxiliary Battery Charging Integrated Current
    • Auxiliary Battery Discharging Integrated Current
    • Auxiliary Battery Capacity after IG ON
    • Auxiliary Battery Capacity after IG OFF
    • Auxiliary Battery Integrated Thermal Load
    • Auxiliary Battery Average Current during IG OFF 1 (2, 3, 4, 5) Trip Before
  14. Salamander_King
    Salamander_King Senior Member
    11,010
    8,940
    New England
    I use a Bluetooth battery monitor that is connected to the 12v battery post. It monitors 12v battery status 24/7/365, and notifies you via phone app when they need a charge. No need to turn on the car, not even popping the hood open. It uses a very little negligible amount of battery power. During the COVID-19, it has served me very well to make sure the 12v stays healthy.
