Should I change trans fluid......
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by aprius, Mar 25, 2018.
  1. aprius
    aprius Junior Member
    26
    I
    I have an 08 Prius - been a great car and have decided to do trans fluid (normally do take care of it) and I have over 300K miles and running strong. I asked a few mechanics about changing the trans fluid and they all say I will incur more problems than good if I change it at this point/time. It has not been changed that I know of (had 150K when got it)....suggestions/thoughts?? Thanks!
  2. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Change it now.
    Raytheeagle likes this.
  3. Erik Owens
    Erik Owens Member
    162
    59
    You will be fine. Just get yourself some WS and its like a differential. You drain out and then you refill until it trickles out. Easy. Make sure you are on level ground and it takes approximately 4 quarts.
    Aaron Vitolins likes this.
  4. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    That recommendation to not change it is in regards to automatic transmission. They dont know anything about a prius. Thankfully a prius doesn't have a transmission. So go ahead and change that fluid! It's a cheap and easy job.
    The prius uses two electric motors and a plantary gear set instead of a actual transmission .
    paprius4030 and Raytheeagle like this.
  5. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    661
    263
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Change it, the car will be happier.
  6. Mendel Leisk
    40,469
    More specifically: make sure the car is level. Maybe a fine point.
    Use Toyota ATF WS, nothing else.
  7. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    No lubricant lasts FOREVER! You are beyond overdue.
    If engine oil changes were NOT listed in the maintenance schedule, would you forgoe engine oil changes?
    Read Post #473
    ATF fluid changes ARE Required. | Page 24 | PriusChat
    Upgrade to a hefy magnetic drain plug.
    Read the transaxle oil analysis by Prof Eddenberg and Bob Wilson; link contained in Post #473.​
    Frodoz737 stated it best: Manufactures maintenance schedule are a bare bones minimum, to give the appearance of low cost of ownership.
    Brake fluid also needs to be replaced periodically. This too is not listed for the Gen 2.
  8. Mendel Leisk
    40,469
    Toyota Canada maintenance schedule (for all vehicles) includes brake fluid change tri-yearly or 30K miles, as of 2012 IIRC.
    SFO likes this.
  9. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Most (all?) conventional automatic transmissions have a series of tiny twisty passages called Hydraulic logic that control shift points. the worry is that these will get blocked, limiting the ability of the transmission to shift.
    As the Prius eCVT transmission never shifts at all, it has no hydraulic logic to get clogged.
    Here is a picture of the twisty passages your car does not have:
    Nothing like this exists in a Prius, the logic is all electronic.
    Aaron Vitolins and Raytheeagle like this.
  10. Mendel Leisk
    40,469
    Even with a conventional automatic transmission, I can't see the harm in a fluid change, regardless of when, if it's done right, and proper fluid used.
    xerox6135 and Aaron Vitolins like this.
  11. fotomoto
    fotomoto Senior Member
    5,626
    3,802
    So. Texas
    Important tip: Open/break loose the fill bolt first. You don't want to drain via the lower bolt first and then find out the upper fill hole bolt is seized/rusted/etc.
    Overall, I find the job easier than an oil change. Just need a short length of tubing so you can fill/pour from above the engine.
  12. Mendel Leisk
    40,469
    I figure it's a wash. If you open the drain bolt first, and then find you're having trouble with the fill bolt, you will eventually be sucessful: you will be MOTIVATED.
    farmecologist and Raytheeagle like this.
  13. edthefox5
    edthefox5 Senior Member
    10,096
    4,830
    Clearwater, Florida
    That fill bolt is really socked on there. It will require a breaker bar.
