Frequent bulb replacements
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by CLVo, Mar 27, 2018.
  1. CLVo
    CLVo New Member
    Raleigh, NC
    I am original owner of a 2012 V and have the car serviced at dealership every 5000 miles (usually every 3-4 months). In the last year, I have had to replace one or more bulbs at least every other service visit. Dealership has replaced free when it is same bulb at next visit. Is this expected? Have not had this experience with the 09 Camry Hybrid I also still own.
  2. rjparker
    10,093
    6,260
    Cheap bulbs, bottom line.
  3. Air_Boss
    Air_Boss Senior Member
    4,190
    1,177
    New Yawk
    Never saw a single lamp/bulb failure on our 2012 v Five while the bulbs were OEM, and have seen no failures since going all-LED (with exception of vanity lamps on sun visors).
  4. PosauneGuy
    PosauneGuy Member
    123
    91
    California, here I come...
    2025 Prius
    You don't mention which bulbs are burning out...but I'll share an experience I had with front headlight and front signal repeatedly burning out on an Accord. Turned out that the plastic underpanel on the bottom front of the car had fallen off and whenever it rained, water was kicked up to the light connections, shorting out the bulbs. Once I replaced the underpanel, no more burned out bulbs.
  5. Mendel Leisk
    41,334
    Yes. @CLVo Headlights, other, which specifically?
  6. mikefocke
    3,988
    1,801
    Sanford, NC
    '12 v 45k miles. No bulb changes.
