Tekonsha Prius Trailer Wiring 118701
Discussion in 'Gen 4 Prius Accessories and Modifications' started by kromerok, Mar 13, 2018.
  1. kromerok
    kromerok Junior Member
    26
    Los Angeles
    2019 Prius Prime
    Has anyone done the trailer wiring on a Gen 4 Prius? I was able to install everything but cant figure out what the red wire attaches to under the car. Im wondering if it could be behind the rear driver light and not underneath.
    davev1pa and Sequestre like this.
  2. vacavillebob
    vacavillebob New Member
    Fairfield, ca
    I have spent 10 hours trying to find that plug they talk about in the directions. I have remove the back of the car and the tail lights and no plug. I am starting to think that the 2017 Prius discontinued that plug. Now what to do?
  3. vacavillebob
    Fairfield, ca
    OK I found the plug. it is on the back of the lower part of the tail light on the drivers side. It is the clear plastic lens of your tail light. Unplug the light blub that is your brake light and that is the plug. Why didn't they just say that in the directions. I looked all over for a wire plug where they said and even their picture is not the right picture. Good Luck with yours. Bob
  4. kromerok
    26
    Los Angeles
    2019 Prius Prime
    I had to have someone else do it for me. Curse of being a big guy with big hands. Funny thing is i called the company that made it and no one there knew how to do it either. Crazy times but its done. All I have left to do is run the power from back to front.
    davev1pa, Sequestre and vacavillebob like this.
  5. kromerok
    26
    Los Angeles
    2019 Prius Prime
    Did you bring the wire to the battery inside the car or under? If inside how did you get it into the engine compartment?
    davev1pa likes this.
  6. vacavillebob
    Fairfield, ca
    I brought my wire to the battery under the car, but inside of the plastic panels to protect the wiring from damage.
  7. kromerok
    26
    Los Angeles
    2019 Prius Prime
    I ended up doing mine along the inside of the car under the plastic and through the grommet.
  8. 16eco
    16eco New Member
    PHX
    Two Eco
    I know this is an old thread. But did anyone of you ever get it working? Mine doens't seem to work with the brake lights. verified trailer brake lights work with my truck. Is because the 12v isn't outputting to the LED brakes? I noticed the Curt wiring plugs in on the large pin behind the bumper.
  9. Willl
    Willl Junior Member
    34
    Orlando
    I just tried installing the Tekonsha 118701 kit today on my 2019 Prius LE.... Fml
    I cannot find the place to connect the red plug!!
    I looked underneath the car and in the center towards the bumper, there is a plug that is for the rear brake lights, this is the plug that they use in the installation video for the CURT brand wiring kit, but the adapter that the Tekonsha kit comes with for the red wire is wayyy too small to fit this plug.
    I read the previous comment here that the red wire plug from the Tekonsha kit should plug into the driver side brake light, but we literally spent hours trying to figure out how to get the lower brake light assembly out of the car, and can only conclude that it is impossible. The upper reverse light part is separate and easily removable, but the lower brake light piece does not come out no matter how many plastic clips I break trying to pry it out...
    Then I also read elsewhere that even if I was able to get everything plugged in correctly that the brake lights will most likely still not work correctly because the pin out on the wiring connectors is wrong for 2019+ and it might interfere with the rear sensors
    If anyone has SUCCESSFULLY installed the Tekonsha 118701 wiring kit PLEASE FOR THE LOVE OF GOD help me
  10. Sina Drums fan
    Sina Drums fan Junior Member
    2018 Prius
    Just wired up the tekonsha 118701 trailer wiring kit to a 2018 Prius 3. I found the wire for the brake light to be the hardest to connect. the best way is to remove the upper driver side rear light housing and then reach down inside to access the wire on the b ack of the brake bulb.
  11. davev1pa
    davev1pa Junior Member
    32
    Lincoln,NE
    Two Eco
    I agree the hardest part is the red connector. I removed the top drivers taillight exposing the lower driver’s taillight. I then removed the top two screws on the lower tail lights of the driver’s lower side. I found that un doing the driver bumper cover provided some access to the plugs but not completely necessary. I ran the wires through the grommet of the drivers side lower light plug. The tekonsha instructions are wrong on the red plug. I haven’t tested the 4 flat yet but nothing “isn’t “ working as of now… I will test tomorrow. Running the power wire isn’t hard but I did spend an hour or more trying to force it through the underside plastic but I ended up just removing several pushpins and a 10 mm bolt to release the edge of the driver side plastic and then ran the power wire up the middle of the plastic out of harm’s way. Again the bad instructions on the tekonsha red wire are a complete joke and annoying as hell. Every video I watched was wrong. My 2016 eco base was not harmed during the trial n error. I’ll repost after testing
  12. davev1pa
    32
    Lincoln,NE
    Two Eco
    All went well. The instructions are completely wrong on the grommet and actual light that the red plug goes into. It is the drivers side LOWER REAR LIGHT PLUG. Follow the rear lower plug wire to that grommet for passage of the red wire set . Other than that GROSS instructional mistake the system works flawlessly. I also added a 4 to 5 flat plug to power the trailer air compressor. Its 15 amp fuse at the battery and usually draws 7-8 amp. The power line to the battery is 12 g so thats enough. However the power converter on the tekonsha 118701 is equipped with 16 g and technically will handle it with a short to a short length of 16g My length is less than 5’. I split the 16 g to handle the 12 g from battery and used a splitter to converter and 5 flat…all 16 g. It works great and no issues! I’m just upset that the instructions for the 2016 base Prius are completely wrong on the red wire set up. Shame on tekonsha. I bought it from etrailer but they only have Curt and another trailer wiring for the 2016 Prius. I had to ask them for the tekonsha and he said it would work as well they just don’t list it and he didn’t know why….. now I do!!!!
  13. davev1pa
    32
    Lincoln,NE
    Two Eco
  14. davev1pa
    32
    Lincoln,NE
    Two Eco
    I obviously see this is an older post but yes…. I did it “successfully” install but with consternation …again I’m happy to have used tekonsha 118701 as it was under $60@ etrailer but it did cost me in the mental gymnastics. Thankfully I don’t have too much to lose in that department
