Car came with only 1 KeyFob - Suggestions?
Discussion in 'Gen 3 Prius Main Forum' started by Cory19thFloor, Dec 28, 2017.
  1. Cory19thFloor
    Cory19thFloor Junior Member
    17
    Maitland, FL
    Hello, fellow Prii owners. Glad to be a new member of the club!
    Our 2013 Persona edition came with only 1 smart key / key fob. We're looking to purchase a 2nd one and have it programmed. Looking for suggestions. Of course, less expensive options are preferred but I'm looking for low on the 'hassle' meter as well.
    I've looked through threads already posted on the forum sites but haven't gotten the full info I'm seeking. Most refer to Gen 2 Prii.
    Also, I see that there are ones with the 'A/C' button on them which are designed for remote start. Would they work on mine?
    Suggestions? Thanks! :)
    51,024
    a/c is for the plug in prius, and maybe solar roof. you can also try local lock smithy's.
  3. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    Yes to solar. Set the target temp then hold the a c button til the vent kicks in. When target temp is reached, or hv battery dips to 2 bars, vent will stop and Prius powers off.
    HUD will project to windshield during this process if hud was on/enable before powering Prius off.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Maybe Todd at @TampaPrius.com does fobs on the side;).
    Worth a call to him and see as it’s only not about 90 miles away:).
    Should be low hassle(y).
  5. HoustonEvolution
    59
    44
    San Antonio, TX
    2023 Prius
    I'm bumping this as I didn't want to create a duplicate thread.
    I'm in the same situation. Recently bought a used 2014 and it came with only one keyfob. I went online locally and see new fobs from dealerships listed at $128 to 205 (plus additional programming). I understand them charging a little more to program but to tell me it takes a full hour to program seems not real honest. Also the one who is offering at $128 charges the most to reprogram. Essentially they are using an unrealistic low price to get you in the door then they make it up in the end. Also the ONLY one to even mention cutting a key was Auto Nation and they said $150 to cut the key. (Auto nation btw also quoted 220 over the phone for the transmitter when their own web site quotes 127. I asked and they said I could do that and the programming cost would be the same.)
    Name Transmitter+reprogramming=total
    Don McGill Katy 205+25=230
    Fred Haas Tomball 203+68=271
    Joe Meyers Cypress 152+120=272
    Auto Nation Gulf Freewy Houston 127+147=274
  6. Sanjay Goel
    Sanjay Goel Member
    83
    57
    Dallas, TX
    #6 Sanjay Goel, Apr 12, 2018
  7. MelonPrius
    MelonPrius Senior Member
    839
    514
    Las Vegas
    I was hoping that a thread like this was going to be bumped up. I just lost a fob, I still have one left. But I'm in the same boat where I'm looking for low cost way to get an extra fob.
    I called a locksmith in Vegas and he said he can give me a replacement for $220. I think there's a locksmith in Southern California that can do it for $180. For now, I'll take my chances with one fob and then try to get another made for $180 when I'm in LA in a couple of months- until then I won't be able to confirm the price.
    How do these prices compare to what's available out there? Houstonevolution, you should try contacting some local locksmiths and see what they charge. They should be less expensive than the dealers.
  8. kingman
    kingman New Member
    22
    kingman az
    i have a 2014 that only came with one fob. i went with a local locksmith and he charged $100 for new fob and $75 to program and cut key.
  9. MelonPrius
    839
    514
    Las Vegas
    $175 total? That's the lowest I've seen on this board for one stop shopping.
  10. Sanjay Goel
    Sanjay Goel Member
    83
    57
    Dallas, TX
    Well... mine was $75 + $35 with zero stop shopping - ordered both online :)
    Though I still need to visit the neighborhood locksmith to get the emergency key cut.
    Raytheeagle likes this.
  11. HoustonEvolution
    59
    44
    San Antonio, TX
    2023 Prius
    No soubt that's awesome. I really don't want to wait until next time I'm anywhere near Kingman! I'll def take his advice and look to non-dealerships.
    your idea is really tempting BUT the fobs I see all the time are about $100 and even then that's a risk that it will work at all. I've been burned on ebay used before. I'm actually in the computer field so the programming doesn't worry. Just finding good starting materials I don't have to worry about is the trick.
  12. HoustonEvolution
    59
    44
    San Antonio, TX
    2023 Prius
    I do not know about locksmith type people yet. I hope to research this weekend. In my first post today is the prices of some dealerships.
  13. MelonPrius
    839
    514
    Las Vegas
    I read the attached link to the Highlander forum. Unless I'm mistaken (and I hope I am), your method was more involved on our end. We'd need to get techstream, vci cable....and do most of the work ourselves.
    For a situation where we bring our fob to a dealer/locksmith and they do the work, $175 is the lowest I've seen here. I hope I'm wrong and there are lower prices out there.
  14. Sanjay Goel
    Sanjay Goel Member
    83
    57
    Dallas, TX
    [QUOTE="HoustonEvolution, post: 2710155, member:
    your idea is really tempting BUT the fobs I see all the time are about $100 and even then that's a risk that it will work at all. I've been burned on ebay used before. I'm actually in the computer field so the programming doesn't worry. Just finding good starting materials I don't have to worry about is the trick.[/QUOTE]
    I went back and checked. I was mistaken that I bought the keyfob at eBay. Actually I got it from Amazon.
  15. Lightning Racer
    Lightning Racer Active Member
    239
    320
    Anchorage, Alaska
    Check out Low Price Keys Low Price Keys - Car Key Replacement . The founder, Santiago, used to post here as @ovni. He moved to the Houston area a while back. When I bought my 2010 with solar roof in 2016 in California, I got new key from his San Francisco franchisee, complete with programming and cut key for something like $150-$165. It only took about 15 minutes too.
    MelonPrius likes this.
  16. MelonPrius
    839
    514
    Las Vegas
    Thx for posting. I'll swing by the next time I'm in Orange County.
  17. Aluhex
    Aluhex New Member
    Orange County
    I'm located in Orange County and don't mind programming it for $50 if you want to provide your own keyfob or I can provide one for you.
  18. SFtroll
    SFtroll Junior Member
    Cedar Creek, Texas
    I bought my 2010 Prius with only one fob about 2 years ago. I found a new fob on Amazon for $30 and found a shop called Batteries Plus Bulb. Each shop is privately owned so the price varies greatly from locations of this chain store. So I called around and found a manager at one location that charged $35 to program the fob and would cut the emergency key for another $15. The whole process took about 15 minutes and I did my own version of the chicken dance as I exited the shop. Oh yeah I had called the dealership and they wanted $210 just to program a fob that I brought in myself. If I find the link that finds shops to do low cost fob programming near you by entering your zip code I will post it.
    MelonPrius and bisco like this.
  19. bisco
    51,024
    thanks!
    good to know they can do that kind of work
  20. MelonPrius
    839
    514
    Las Vegas
    Thanks for posting this. I've been looking for this kind of pricing and I happen to have a batteries plus bulb a few miles away. Other estimates from local locksmiths have been over $200, so thanks again for the info.
