Make Keyless entry unlock all doors
Discussion in 'Gen 3 Prius Main Forum' started by Bgustafson, Apr 6, 2018.
  1. Bgustafson
    Bgustafson Active Member
    259
    222
    Chicago
    And for my next question....This one has been bugging me and I kept meaning to post but always forgot to. ;)
    My 2006 Four would unlock all the doors whenever I used keyless entry on the driver's side door. My 2013 Persona only unlocks the driver's door. This really bugs me - is there a way to reprogram the car to unlock all doors when I reach for the driver's side handle? Seems simple enough.
    Thanks! (y)
  2. Rodilyn
    Rodilyn New Member
    Carson CA
    I'm not sure about your particular vehicle. I have an 08 Toyota Highlander that was able to be switched (by the dealer). So they were able to program all doors to open upon keyless touch. My 2017 prius prime I was able to set that up within the settings on my computer /navigation system. Check your manual - and /or call your service advisor at your local dealership. Hope this helps!
  3. BZzap!
    BZzap! Senior Member
    1,607
    878
    As annoying as it is, you do know that the Keyless open button has to be pushed twice to open all locks at the same time?
    Bill the Engineer likes this.
  4. JC91006
    JC91006 Senior Member
    16,656
    8,504
    You can select that option by standing next to the car and holding the lock and panic button in your keyfob (i think it's these 2 buttons) at same time for a few seconds until it beeps once. That changes the lock settings to drivers door only. (I know this is in your owner's manual, holding 2 buttons at the same time on the keyfob)
    If those 2 buttons don't work, try holding lock and unlock buttons.
    Change it back to unlocking all doors by doing the same process
  5. Kramah313
    Kramah313 Active Member
    408
    322
    Dallas, TX
    On my 2012 that can be changed on the display but hitting settings and then either general or car - it’s one of the options listed. I changed that also for the same reason when I got mine
  6. kc5dlo
    kc5dlo Active Member
    266
    163
    DFW TX
    2021 Prius
    I could have sworn I used the Carrista app to change mine and also stop the constant beeping in reverse.
    James Powers likes this.
  7. Bgustafson
    259
    222
    Chicago
    Thanks! I'm going to try this later today. (y)
  8. GFO
    GFO Member
    75
    49
    Larkspur
    Can confirm this works as I just did it, pressing down on Lock and Panic and then holding for about 4-5 seconds until the car beeps. Now all my doors unlock when I grab the door handle and have the FOB in my pocket.
    Thanks, JC!
    ehsieh and JC91006 like this.
  9. Bgustafson
    259
    222
    Chicago
    I can also confirm that @JC91006's method is a winner! Thanks so much!
    stephensprius likes this.
  10. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    This is great! I love this forum. Going to try this tomorrow morning in my wife’s car. This has always annoyed us. Thanks guys!!
    Bgustafson likes this.
  11. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    Wish I would have found this before I bought the carista OBD tool! Only good thing I got out of that was turning the big girl backup beeps and the doors..
  12. stephensprius
    670
    226
    On another off-topic note: nice beard @James Powers
  13. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    Is this applicable only to Toyota vehicles, or?
  14. Grit
    Grit Senior Member
    6,413
    4,181
    Wilkes Land
    If you hold both buttons down and look directly at the MDF, you will see an image of a prius with all door opens. If you repeat that procedure, only the driver side door has its door open on the display. Said so in the manual also.
    JC91006 and Raytheeagle like this.
  15. James Powers
    396
    555
    Bay Area
    Ha, thanks.. Adds about 5hp too. lol
  16. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    You should be able to go to vehicle customization (Or something along those lines) and go to door lock settings and be able to change it to unlock all doors.
  17. stephensprius
    670
    226
    HAHA
  18. CR94
    CR94 Senior Member
    2,660
    1,149
    Northwestern S.C.
    Easy instructions how to do that yourself are in the owner's manual.
    Grit likes this.
  19. Simonak
    Simonak Member
    I did change my with Techstream software but not everyone have access to one.
  20. Mendel Leisk
    40,467
    Specifically, on page 48:
    Bay Stater, quantumy and breakfast like this.
