Prius C need EWD for ECU and Hybrid Control Module
Discussion in 'Prius c Technical Discussion' started by kiwi, Apr 23, 2018.
  1. kiwi
    kiwi Member
    246
    87
    New Zealand
    Need EWD (Electronic Wiring Diagram) for ECU and Hybrid Control Module for Prius C. Any year from 2012 up will do. PM please with the link to the file if you have one.
  2. Brandon Most
    Brandon Most Member
    116
    70
    Dixon, CA
    2016 Prius c
    https://techinfo.toyota.com will of course have it for sure. I downloaded a ton of wiring diagrams etc for the 2016 C when I was last on there, but I haven't sorted through them yet.
    Raytheeagle and bisco like this.
  3. kiwi
    kiwi Member
    246
    87
    New Zealand
    Would you be so kind to PM me Wiring Diagram for ECU, Power Management Control and Battery Voltage Sensor.
    #3 kiwi, Apr 29, 2018
  4. kiwi
    kiwi Member
    246
    87
    New Zealand
    Topic can be closed. Sourced what I was after from my fellow Toyota Technical Expert.
  5. Moparbee
    Moparbee New Member
    New Mexico
    Kiwi, I'm trying to get a hold of you, can you message me please?
