Oil Catch Can, Eliminate that knock!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by danlatu, May 22, 2017.
  1. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    I'll be watching for it!
    NutzAboutBolts likes this.
  2. farmecologist
    farmecologist Senior Member
    1,955
    1,798
    Southern MN
    So what can did you go with?
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,502
    1,597
    Bay Area
    I went with this one, in black
    Bay Stater and farmecologist like this.
  4. tvpierce
    tvpierce Senior Member
    951
    880
    Maine
    2013 Prius v wagon
    The Ruien OCC has two chambers on the intake side that come empty. You stuff those with stainless steel scrub pad, which will encourage vapor to coagulate into a liquid that will drip down into the catch can.
    Lightning Racer and Bay Stater like this.
  5. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    The hoses are not fuel spec'd. Bought them from Home Depot in the plumbing dept.
  6. Bay Stater
    534
    771
    Central Mass
    That's what my coke bottle collection container looks like. Have about 5K miles of collected substance.:eek:
  7. MattStevenson
    MattStevenson Member
    57
    35
    US
    Did you need any additional hardware?
  8. Mendel Leisk
    40,471
    If you're splicing into the existing hose you'll need a couple of:
    3/8" brass hose barb splicer
    And a few more:
    stainless steel hose clamp (capable of clamping ~5/8" OD hose)
    I've seen a few installations that didn't bother with the clamps though. In particular with something like heavy black-rubber fuel line (spec. SAE-30R7 or SAE-30R6), pushed onto those aggressive barb connectors, I don't think the clamps are really needed. But they certainly don't hurt.
  9. evilchargerfan
    evilchargerfan Junior Member
    24
    42
    San Diego
    after 500 miles, I have about half an inch collected in my catch can (apologies for not measuring exact ounces)
    Bay Stater and Raytheeagle like this.
  10. evilchargerfan
    24
    42
    San Diego
    guys, I know this catch can thread is not the best place to ask this .... AND ... I didnt feel right making a thread all for myself and being greedy .... but would some of you kindly take a glance over at my thread? I'm having a heck of a time, with the engine "shakes" on start up, and battling a CEL for misfire on cyl 1:
    Chargerfan - First Problem Detected 117K: Engine Shake On Take Off And On Start Up - ClubLexus - Lexus Forum Discussion
    (mods, if linking to another forum is not allowed, please advise)
  11. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    Can't seem to log in using Google account over there, repeatedly!
    UOA
    Check plugs. They have charts showing pictures of what's the cause of the different looks.
    Still losing oil? You've driven a good amount and may need to add.
    Compression test?
    Robert Holt and evilchargerfan like this.
  12. evilchargerfan
    24
    42
    San Diego
    I did a dealer oil change 1k ago, because I requested for an oil consumption test. They (the dealer) would only agree to the test IF I do an oil change with them, using their filter and their oil ... which is funny because I use oem toyota filters and they use mobil1 0w-20 as I do
    that said, no uoa this time around, but I do usually get those done with blackstone labs.
    I'll check the oil level soon, I'm actually eager to see how much as been lost in 1k. my guess is, 1 qt. And compression and leak down test, are 2 things I have yet to try
  13. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    Reason I first noted UOA is because you can see if dirt is getting by your filter. You noted the pre-filter addition. That is not going to help make the air cleaner, just prolong the service life of the filter. If you want cleaner air then replace filter with new one, or go back to stock. I'm also concerned oil is fouling your plugs. From what I learned from issues of harsh Cleveland life for my W201 oil goes to coolant. (Can please correct me if I'm wrong, but oil pressure > coolant pressure). No report of that, so must be going somewhere else.
  14. NutzAboutBolts
    1,502
    1,597
    Bay Area
    I’ll have to check when we film lol.
  15. MattStevenson
    57
    35
    US
    I'm at 122k. Wish I came across this a while ago.
    JDZILL likes this.
  16. NutzAboutBolts
    1,502
    1,597
    Bay Area
    It’s never too late lol we haven’t film yet either
  17. qettyz
    qettyz Active Member
    181
    206
    Finland
    Quite difference on OCC contents now when wheather has been warm vs spring.
    When temps were little bit lower(5 - 15C) i got mostly water, fuel and just little bit oil to bring light brown color.
    Now temps has been 15 - 30C and i got only oil(maybe spoon in a week) and maybe slight ammount of fuel.
    But strange how that ammount of oil does not appear when colder.
    scona and Raytheeagle like this.
  18. Mendel Leisk
    40,471
    If you let it sit for a few weeks, maybe your winter drain will stratify to show more oil than you think. Ours looked like cream when drain, but when settled was still about 3/4 oil.
    Oil Catch Can, Eliminate that knock! | Page 51 | PriusChat
    qettyz likes this.
  19. Michael Mann
    Michael Mann Active Member
    167
    408
    Bay Area, CA
    BE6919D2-323C-42D4-A50B-FF84D5218B0C.jpeg I ended up mounting mine on the low side below the manifold. Not very assessable from the top but it’s an easy drain during DIY oil changes.
  20. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Go low:).
    I’ll be curious what you catch;).
    I’ve only caught about 6 ounces to date over 9 k miles and it is odiferous like gas with oil mixed in :whistle:.
    Does your catch can have a dipstick so you can check the level? I check ours every so often to make sure nothing drastic is going on ;).
    Nice install location (y).
    Bay Stater, JDZILL and Michael Mann like this.
