5200 mile road trip in a 2012 ? Advice please.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by SusanLovesHerPrius, May 13, 2018.
Tags:
  1. SusanLovesHerPrius
    SusanLovesHerPrius New Member
    Orlando, FL
    Two Eco
    I have a 2012 Prius that I bought used two years ago. It is at 90k miles. I love it and have had zero problems. The only maintenance I've done so far is regular oil changes and new tires. I am contemplating a cross-country road trip this summer that would put 5200 miles on it in 30 days. I have two questions: 1) What preventive maintenance should I have done before I go? AND 2) Would a trip like this wear my car out? I can go by plane and rent a car at my final destination, but I'd miss all the fun of cross-country with my kid.
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    get your tranny fluid flushed
    paprius4030 likes this.
  3. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Consider changing your air filter if it hasn't been done recently. Also replace the cabin filter. Check all fluid levels and tire pressure. Don't forget the spare. (y)
    FYI: Your next major service interval is at 120K miles.
    Have a safe trip.
    paprius4030 and NutzAboutBolts like this.
  4. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,501
    1,596
    Bay Area
    Check engine, cabin air filters, check and change fluids if necessary, check your brakes if there’s enough brake pads and rotors for any damage, inflate your tires to 35psi on all 4, check washer fluids and top off as needed in case you run over a whole bunch of gnats on the road and wiper blade inserts if it’s working properly by clearing your windshield, check your battery voltage, it should be 12.6v and above, usually you want to change it every 5-6 years... they don’t last long. Check spade tires and inflate to recommended psi.
    Bay Stater likes this.
  5. MelonPrius
    MelonPrius Senior Member
    839
    514
    Las Vegas
    If you drive the speed limit, capped at 70 mph, highway traveling is the least stressful driving for your engine. Two danger areas for all cars (IMO) on a long trip are a flat tire and fluid issues. Make sure the fluids are topped off and fresh and make sure tire treads and sidewalls are in good shape.
    Bay Stater and paprius4030 like this.
  6. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Above is all good advise. I recommend keeping a close eye on your oil. adding when it gets 1/2 a qt. low don't wait until it's a qt. low heat and a low oil level is a bad combination. Get your maintaince done a few weeks before you leave just incase somebody screws something up you have time to take care of it. Make sure your tires are good and inflate to 42/40.
    bat4255, Raytheeagle and MelonPrius like this.
  7. MelonPrius
    839
    514
    Las Vegas
    Oh yeah, the oil. I was 2,000 miles away from home years ago in my old reliable 10 year old Camry and the engine started sounding funny. I was advised to put in a quart of oil and it worked like a charm.
    Have a mechanic examine your hoses under the hood. If you have a fluid issue on a road trip in a '12, it could be due to a leak in a worn hose.
  8. paprius4030
    2,077
    296
    York,Pa.
    Actually it's a simple Drain and Refill, no flush
  9. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    661
    263
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Change engine and tranny fluid. Top off all other fluids and take an extra qt of engine oil along just in case. Of course get the brakes and tires checked also.
    Have fun :)
    Here is a link to our trips last year.
    Road Trip | PriusChat
    #9 bat4255, May 15, 2018
  10. farmecologist
    farmecologist Senior Member
    1,954
    1,797
    Southern MN
    Yep do all the above...and go on your trip!
    Our 2010 has been on three long road trips so far and has done very well...lots of mountain climbs/descents too :
    As an example...here is our 2017 route : https://drive.google.com/open?id=1xHF9v2dpDqkYzE939LNQDA07UR0&usp=sharing
    I will warn you that the engine screams like thunder climbing and descending ( in B mode ) mountain passes. However, it made it just fine with no ill effects.
    #10 farmecologist, May 15, 2018
    Bay Stater, Raytheeagle and Merkey like this.
