Suitable substitutes for the Toyota ATF-WS transmission or transaxle fluid?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rocketboy235, Aug 27, 2017.
  1. RRxing
    RRxing Senior Member
    2,551
    1,825
    NEPA
    North America for the WIN! :)
  2. Mendel Leisk
    41,738
    Smuggling, air-lifts?
  3. Simtronic
    Simtronic Active Member
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I have never used WS since my first Prius at 50,000 miles it now has 250,000 miles on it and is still drives well though it is my sons car now. My current plugin got changed to Millers at 50K. Only failures I have heard about are very high milage that haven't changed the oil ever!
  4. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Roads and parking lots are spotlessly clean in Europe. Maybe that was the purpose.
    There appears to be some sort of warranty for the Valvoline substitute if you change every 30k miles. I might go for that but it does not seem cost effective as you note.
  5. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    We have a winner! (y)'
    Glad to hear someone using an alternative without problems. Mind revealing what kind you used?
    Tim Jones likes this.
  6. douglasjre
    douglasjre Senior Member
    2,195
    731
    Null, NL
    I used Maxlife LV in two different 3rd Gen Priuses. I have a total of 100k trouble free miles with that and I use the Prius to pull 2,000 lb trailers at 85mph for 5,000 miles of that 100k. I also drive these two cars fast enough that my fuel economy is 30mpg. I'm not having any troubles thus far....
    Tim Jones, Prieth, m.wynn and 4 others like this.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    MaxLife is big over at Bitog. Lots of Prius owners use it. Good product.
  8. edthefox5
    10,096
    4,833
    Clearwater, Florida
  9. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I am in the UK and use Millers WS fully synthetic I believe in the states Redline make an equivalent. Check the specs you want a low viscosity and fully synthetic. I used to be on here a lot and those that tow or drive hard can find better specs than the Toyota WS not necessarily for less bucks though
    douglasjre, edthefox5 and j12piprius like this.
  10. douglasjre
    2,195
    731
    Null, NL
    I put 210k on my 2nd gen and put Toyota brand was in it every 50k. That car lived it's life w a trailer attached at wtfo. It too had no issues.
    Is Maxlife LV any better than WS?
  11. kage1974
    kage1974 New Member
    Central WI
    The reason I'm asking is because I use my 2014 for rural mail delivery. Hard stops and starts, 4-5 hours a day. My wife and I started driving a Prius in 2008, put 280k normal driving miles on it and never serviced the transmission. No problems with that car at all other than front wheel bearings at 275k. The 2014 is approaching 140k and since this car is exposed to hard driving conditions I will be servicing the CVT and I want to use something better than stock. I have a gallon of Tribodyn MV-ATV full synthetic fluid ready to go in the coming weeks when I get time to change it. Toyota WS is on the 'meets or exceeds' list for this product. I'll keep up on the thread if I have any problems.
    jzchen, farmecologist and Grit like this.
  12. farmecologist
    1,958
    1,799
    Southern MN
    I don't doubt that the Prius transaxle can handle infrequent or no transaxle fluid changes...it is pretty simple and robust. In fact, I'm convinced that the majority of Prius vehicles don''t ever have this done...because most dealers don't recommend it. However, we purchased a 2012 Prius v (wagon) which was driven in pretty harsh conditions and the transaxle fluid looked pretty horrible when I changed it. So I'm sure the transaxle probably could have 'handled it'...but I didn't want to test it. :D
    Glad to see you are going to change it. 140K seems like a good time. (n)
    Simtronic, m.wynn, j12piprius and 2 others like this.
  13. Simtronic
    290
    116
    Surrey, UK
    2017 Prius PHV
    Business Ed. Plus
    I agree the transmission is very basic and simple with a fraction of the complexity of a conventional auto, I changed mine the first time after taking a sample. Hardy as they may be I didn't want what looked like black soup in the trans
  14. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I’m basing my choice on the manufacturer that has a monetary stake in making their product/WS right. People do not want to spend more than they have to for the fluid, and companies do not want to have to shell out money for someone’s replacement CVT. Valvoline’s language was questionable, so I sent them the question for out Prius v. The answer came back this morning that their MaxLife is compatible. Amsoil is the other one with a warranty as far as I know. I haven’t sorted out the details because they are based on vehicle manufacturers change interval, and the Prius does not have any.....
  15. PixelRogue
    488
    86
    US
    edthefox5 likes this.
  16. douglasjre
    2,195
    731
    Null, NL
    Me and my friends now have 12 Prius'. I convinced everyone I know to get one or two. Four have maxlife LV. Total miles driven w LV combined is 300k mi. No issues.
    edthefox5, Fred_H, m.wynn and 2 others like this.
  17. Tim Jones
    Tim Jones Senior Member
    1,759
    565
    SE Texas
    2011 Nissan LEAF
  18. Elektroingenieur
    2,515
    3,285
    Three Touring
    How do you know, or do you mean simply that you haven’t observed any symptoms of transaxle failure in the time and distance since you began using the third-party ATF?
    Have you done anything to determine whether this ATF, compared to Toyota ATF WS, has increased—or for that matter, decreased—the rate of wear or the risk of failure of the gears or seals, for example?
  19. Tim Jones
    1,759
    565
    SE Texas
    2011 Nissan LEAF
    It's WS.................... and I don't use Toyota motor oil.......... zero leaks and oil consumption.....239,000
    So you go to the dealer and have Toyota Oil installed????
    I also have a 2010 Honda Goldwing.....never ran Honda Oil.....110,00 and going strong...
    douglasjre and edthefox5 like this.
  20. Mendel Leisk
    41,738
    Conflation. Toyota doesn't insist you use their motor oil. On the other hand, they do put a very strong warning that any other fluid in the transaxle could damage it.
    Myself, I'm just bright enough to know I can't possibly know better than them.
    CR94 likes this.
