Q about the gas tank
Discussion in 'Prime Main Forum (2017-2022)' started by EyePrime, May 26, 2018.
  1. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    We went on a road trip this victoria day (Stat holiday in Canada) and found that the fuel indicator decreased alot faster under half.
    Does anyone know why this happens?
  2. Salamander_King
    Salamander_King Senior Member
    11,004
    8,925
    New England
    How far did you drive on gas (HV)? With listed 55 mpg, it will use half of tank in ~300 miles (~480 km).
    KrPtNk likes this.
  3. EyePrime
    268
    115
    2018 Prius Prime
    500Km there 500km bakcj
  4. ClemsonSteve
    ClemsonSteve Active Member
    270
    248
    South Carolina
    It’s because of what I would call the funnel effect. The liquid level drops faster as the walls of the container get closer together as the liquid drains. So I think it’s because of the shape of the gas tank. Just a quick disclaimer—I’ve been wrong more than once :)
    Tideland Prius and EyePrime like this.
  5. Salamander_King
    11,004
    8,925
    New England
    Assuming you did not charge during the trip, you mean, the first 500 km on the way, you lost half of tank, but on next 500km on your way back, you lost more than half of tank?
  6. EyePrime
    268
    115
    2018 Prius Prime
    Yeah it just seems the idicator goes down faster after half a tank. We used hv the hole way
  7. Salamander_King
    11,004
    8,925
    New England
    I am not sure if the half point in the gas gauge on PRIME is really half empty gas tank. I know when gas gauge is showing completely empty (meaning no bar lit), there is still more than one gallon of gas left in the tank. Rate of decrease may not have changed after half point, but it may give you an impression it decreased more rapidly if the half point is really not at the middle of gauge.
    EyePrime likes this.
  8. ClemsonSteve
    270
    248
    South Carolina
    I’ve always observed this with my cars—for example I might get 200 miles from my Audi’s first half of a tank, and then 145 miles out of the second half. But I think it’s correct to say that the second half is not measured like the first, as stated above.
    benagi likes this.
  9. Salamander_King
    11,004
    8,925
    New England
    Yes, I have seen the same behaviour with some of my other cars as well. My point is when gas gauge is pointing empty, it is often not completely empty.
    #9 Salamander_King, May 26, 2018
    ClemsonSteve likes this.
  10. fuzzy1
    10,335
  11. Salamander_King
    11,004
    8,925
    New England
    Yap, your comment explains it all.
  12. orenji
    orenji Senior Member
    5,886
    3,487
    Also a full tank is not all gas....
  13. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Both the GII and GIII do this. I'd say it's "normal". ;)
  14. bisco
    51,043
    the pip has 8 bars and each represents a gallon. i'm surprised they were not able to accomplish this on the prime.
  15. Salamander_King
    11,004
    8,925
    New England
    PRIME also have 8 bars, but 1 bar is further divided into half bar making 16 increments. I have not done a long HV drive in a while to see how the rate of gas use changes (or not change) after a half point on my car. If 1 full bar = 1 gallon, then there must be 3.4 gallons of gas not shown in the gauge, presumably above full mark and below empty.
    #15 Salamander_King, May 26, 2018
  16. bisco
    51,043
    perhaps a bar represents more than a gallon, since the prime tank is larger than pip. idk. pip has a bout 2 gallons left when the last bar starts flashing.
    Salamander_King likes this.
  17. Mendel Leisk
    40,498
    The gas gauge will tend to hold on full inordinately long, before it starts dropping. It's really hard to judge your fuel consumption based on that gauge. Also, maybe your speed for the second half of the tank was higher, and/or headwinds, and/or grade change.
    Just assume there is a plausible explanation?
  18. Sid786
    Sid786 Active Member
    262
    148
    Cherry Hill, NJ
    Since I am doing long distance driving for the past few days, so I have noticed that the first 100 miles on HV, you has gauge will not move at all. After that first 100 miles gauge moves pretty fast but at uniform speed. Every 120 HV miles seems to be equal to 1.5 bars on gas gauge.
    EyePrime and Salamander_King like this.
  19. Tideland Prius
    16,435
    The gas gauge isn't linear. I haven't checked with the Gen 3 or 4 but I remember with the Gen 2, out of 10 pips, the 6th to 9th pip took 80km each. The 1st-5th pip (lower half of the tank) took 50km each. The first pip depends on your fuel efficient. I aim for 100km before the first pip disappears. If it's a bad mpg tank, it'll drop out at 80km, if I'm fuel efficient, I can squeeze out 120km before the first pip disappears.
    I know it's harder to gauge (pun intended) with the Gen 4/Prime since it's a digital bar graph rather than set pips.
  20. David Beale
    5,963
    1,987
    Edmonton Alberta
    AND, if you do as I do, that is, fill the tank until I see fuel in the filler tube, you get an extra 200 km range! Well, maybe 100. ;)
    Oh, and no, I won't harm the car doing this because I actually USE my brain when doing so.
