DTC B1507 (Open in Turn Signal Circuit) in history; no symptoms
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Elektroingenieur, May 28, 2018.
  1. Elektroingenieur
    2,515
    3,277
    Three Touring
    During a routine Health Check with a Toyota Techstream diagnostic system, I found my 2016 Prius Three Touring had Combination Meter diagnostic trouble code B1507, Open in Turn Signal Circuit, in the history, but not current. I hadn’t noticed any problems with the turn signals, and all four turn signal lights and both indicators in the Combination Meter blinked as expected in turn, lane change, and emergency flasher modes.
    The Repair Manual troubleshooting procedure wasn’t helpful, since it requires at least one malfunctioning light. The Active Test items “Turn Signal (Left) Indicator” and “Turn Signal (Right) Indicator” each illuminated the respective lamps and indicator. With IG OFF, the voltage across the auxiliary battery was 12.39 V.
    Without any observed symptoms, much less a confirmed malfunction, I’m disinclined to go hunting for intermittent connections, nor to involve a dealer. After clearing the code from the Combination Meter so I can tell if it returns, I think I’ll close this one out for now as “No Trouble Found.”
    alanclarkeau and krmcg like this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    Yes, could be a mystery and never reoccur. Do you recall any error warnings on the dashboard? Or possibly they don't regard it as an error worthy of a warning, but a log for service to check out.
    Sounds a bit like my single event Brake Light Switch error which triggered just about every warning - as many are related to the brake system.
    Elektroingenieur likes this.
  3. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    As long as there wasn't a code logged in the computer for CURRENT/PENDING, codes,y guess could be it was an intermittent code.
    In my view, there isn't anything to worry about.
  4. Elektroingenieur
    2,515
    3,277
    Three Touring
    I didn’t see any warnings. I think you’re right that the fault is logged only as a troubleshooting aid: the New Car Features book lists the messages that the Combination Meter can display, and there isn’t one for turn signals.
    alanclarkeau likes this.
