Getting ready to replace the Spark Plugs
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by iskoos, Mar 12, 2018.
  1. tvpierce
    tvpierce Senior Member
    951
    880
    Maine
    2013 Prius v wagon
    How'd you get the new ones started?
  2. Pdaddy
    Pdaddy Member
    160
    49
    You can use the same hose to start the thread and then finish with the socket
    iPad ?
  3. tvpierce
    951
    880
    Maine
    2013 Prius v wagon
    Exactly. The question to @Bay Stater was re: using the magnet fishing tool to remove them. It doesn't work as well for installing.
    Bay Stater likes this.
  4. Mendel Leisk
    40,465
    A kosher spark plug socket with rubber insert is what I like. Tip: tape the extension to socket joint, just in case; it can grip too good, pull off the extension when you try to pull it off.
  5. Pdaddy
    Pdaddy Member
    160
    49
    What about spark plug wires? What is the expected life span?
    iPad ?
  6. Mendel Leisk
    40,465
    There aren't really traditional spark plug wires, with individual coils. Take a look and you'll see what's going on.
  7. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    It's been awhile, but I used the magnetic extending rod to lower them back in. Removed the rod. Lowered the socket with extender to position the plugs to the threads and hand tighten them in. Then connected the ratchet to the socket extender to finish up.(y)
