Spark plugs replaced at 104K miles on 2010 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hatbe, Jun 17, 2018.
  1. hatbe
    hatbe Junior Member
    San Jose, CA
    These are the spark plugs from my 2010 Prius, it has 104K miles when I replaced them, and still in OK condition. The original spark plugs are Denso SC20HR11, I replaced with DensSC16HR11
  2. JC91006
    JC91006 Senior Member
    16,723
    8,546
    They look like they can go another 100k miles
    GrGramps and Raytheeagle like this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,513
    Bay Area, California
    2019 Prius Prime
    Any reason for replacing them before 120 k miles rolled up?
  4. hatbe
    hatbe Junior Member
    San Jose, CA
    No, I just want to do all major maintenance in one shot: spark plugs, inverter coolant, engine coolant, brake fluid flushing and throttle cleaning.
    Raytheeagle likes this.
  5. Raytheeagle
    11,263
    15,513
    2019 Prius Prime
    You missed the egr circuit cleaning;).
    But that’s not in the owners manual :whistle:.
    Another item to consider (y).
    Mendel Leisk and mjoo like this.
  6. Patrick Wong
    18,200
    6,497
    Do you have a wire gauge set so that you can assess the gap size of the used plugs?
  7. hatbe
    hatbe Junior Member
    San Jose, CA
    I checked the gap is 1.05 mm, I guess the carbon build up cause the gap a bit smaller
    Mendel Leisk and Patrick Wong like this.
  8. hatbe
    hatbe Junior Member
    San Jose, CA
    Thanks for reminding, I will do the EGR pipe cleaning soon.
  9. Raytheeagle
    11,263
    15,513
    2019 Prius Prime
    Oh it’s more than the pipe ;).
    Intake manifold, egr valve and egr cooler. Best to pair with an engine coolant change and when the windshield wiper cowling is removed (like wen doing the spark plugs):).
    The pipe will give you insight into the situation and state of affairs though(y).
    JC91006 likes this.
  10. JC91006
    16,723
    8,546
    I'm waiting for Toyota to issue a recall to clean the EGR circuit because of all the head gasket failures.....and they better hurry as I'm approaching 110k miles
  11. Raytheeagle
    11,263
    15,513
    2019 Prius Prime
    You’re going to wait:whistle:?
    Just don’t wait too long or you'll be one of those in the wake;).
    How much oil is the early Gen3 consuming?
    JC91006 likes this.
  12. JC91006
    16,723
    8,546
    I cleaned the EGR pipe around 100k miles to buy extra time. Oil burning is around 1 qt every 2500 or so miles. More if it's driven at high speeds
  13. orenji
    orenji Senior Member
    5,887
    3,488
    TSB would be issued, I dont think a recall would be issued. A lot of factors could be the cause for head gasket failures.
  14. JC91006
    16,723
    8,546
    TSB would make it owners responsibility....
  15. Raytheeagle
    11,263
    15,513
    2019 Prius Prime
    Still on prescribed 0w-20 or have you clubbed up?
    JC91006 likes this.
  16. JC91006
    16,723
    8,546
    Next oil change will be 5w-30. I had a stock of 0w-20 that my gen2 can't use
  17. orenji
    5,887
    3,488
    TSB would make the owner responsible, the car is over 100k miles.
    JC91006 likes this.
  18. orenji
    5,887
    3,488
    Go to 0W-40 weight. It's doing wonders on another vehicle that was burning oil.
    j12piprius and JC91006 like this.
  19. JC91006
    16,723
    8,546
    Surely this will be a lawsuit in the making for the people that already have failures
  20. Raytheeagle
    11,263
    15,513
    2019 Prius Prime
    5w-30 works too;).
    Been on that program for 60 k miles and doing well:).
    But I’ll experiment up at 190 k around thanksgiving (y).
    orenji likes this.
