Is the Optima Yellow Top a good batt?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Jun 17, 2018.
  1. bisco
    51,023
    my fingers hurt.:oops:
    Mendel Leisk and Raytheeagle like this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Since I only use my iPhone 5S, I’ll probably end up with carpal tunnel for the long posts:sick:.
  3. bisco
    51,023
    i don't know how you guys do it. when i'm out and (rarely) have to use the phone, i get very frustrated.
    Raytheeagle likes this.
  4. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    I’m never at a computer long enough to do it any other way;).
    So you get used to it(y).
  5. farmecologist
    farmecologist Senior Member
    1,954
    1,797
    Southern MN
    Taxi/Limo and Raytheeagle like this.
  6. kens97uber171
    kens97uber171 Active Member
    177
    133
    US
    Bought an Optima for mine.
    Definitely leave the car in ready mode when your sitting.. the car cannot keep the 12v battery up when it's just sitting there in account mode.
    The engine will start and stop..but it's also maintain voltage on both the Hybrid and 12V battery too.
  7. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    Close enough for government work ! ;)
  8. sam spade 2
    7,035
    2,798
    2017 Prius c
    The water does not boil off, therefore the vent only comes into play in an extreme and unusual situation.
    They tend to last longer too.
    AGM is pretty much the standard in cars these days.
    The Prius does not require anything special.
    Physical size and the right kind of posts might be more important than electrical spec's.
    You are making this MUCH harder than it IS.
    Any "name brand" AGM that will fit physically will be fine.
  9. sam spade 2
    7,035
    2,798
    2017 Prius c
    It is not and does not.
    Shop around for a battery that will fit your model car.
    I'm pretty sure that they ALL will be AGM type.
    You REALLY do not want to go back to a conventional wet battery where the level needs to be constantly checked, acid fumes can come out and having a proper venting arrangement is really important.
  10. Mendel Leisk
    40,467
    A lot of automotive retailer websites allow you to enter your vehicle stats and will show you what compatible batteries they have. Pep Boys is one, has a conventional shaped AGM, with the prerequisite posts, vent, dimensions, by Bosch if I recall correctly. It periodically goes on sale for around $145 (US), AND they'll install for you at that price.
    That said, the last time I tried to search a battery on their site, I hit the wall: it was a maddening, confounding trial, could not make headway. Maybe it was just me, having an elder day, not sure. Or maybe the website was having issues. Anyway, try them, and any other automotive retailers in your area, see what they've got. If you're hitting the website wall too, try phoning them.
    I used to think getting anything other than Original Equipment Manufacturer batteries you would be getting a one-size-fits-all, but that doesn't appear to be the case. I get the sense that there are not that many manufacturers, they're catering to the OEM requests and aftermarket, and apart from some variations in branding, you can get a battery that's basically identical to OEM, but more readily available and cheaper.
  11. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    When the time comes. I will just buy the Toyota brand, dealer-installed battery. They always seem to be on sale.
    Have you thought about getting a portable radio for the car? I've seen ones that charge by solar, and also have AA batteries, or you can crank it for power.... Or you can plug it in. Your choice.
    And maybe get a bright battery-powered LED light and hang it inside your Prius?
  12. Starship16
    1,348
    1,455
    Beach Christmas
    This is the emergency radio I have. If you use the crank, I think you get 30 minutes of play time. So keep cranking :LOL: Or just use the AA battery power. They last about 60 hours.
    CC Solar Observer and 5V AC Adapter
  13. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    Thanks Mendel and all for being generous with your advice
    Pep boys does have a nice deal and Bosch is good quality right ?
    and they put it in ? that is nice
    I have been thinking about a rechargable top light that would help They are around 200 and up last time I looked
    and a battery powered radio too
    Robert Holt, m.wynn and Mendel Leisk like this.
  14. Mendel Leisk
    40,467
    Did you find it on their site? That was my stumbling block, last time I looked. No first hand experience, but at least a couple of members here (IIRC) got the Bosch battery, included install, and no reports of problems.
  15. Taxi/Limo
    524
    107
    Yes on there site it is 189.00 and then a discount makes it 151.00
    I can't put the link here Prius Chat won't let me
  16. VTAERO
    VTAERO Junior Member
    Fredericksburg, VA
    My optima yellow top just failed 2 nights ago after 5yrs of service. I quickly replaced it in the parking lot of Autozone for $225. I like the yellow top because I tend to sit in the car when it's NOT in "ready" mode and listen to the radio while also charging lots of stuff from the lighter sockets. So I like the deep cycle.
    VS995 ?
    bisco and Taxi/Limo like this.
  17. Taxi/Limo
    524
    107
    That is what I have been doing Why is the Optima Yellow top better for that than the others?
  18. VTAERO
    Fredericksburg, VA
    The yellow top like other deep cycle batteries should be better at being discharged farther than a regular lead acid starting car battery. We can use the deep cycle kind because we don't have a starter that has to turn over the engine. We just have to boot the computer so it throws the relays to connect the huge 200 volt battery for the hybrid system.
    When mine failed it failed such that it just didn't do anything at all anymore. I had to jump start the Prius with one of those little lithium ion jump packs, but I keep it in the car in case I have to help others because I don't want to jump start anyone else's car off the Prius because we have very sensitive electronics and a tiny battery. In my case I have the deep cycle that doesn't put out the starting current for a normal car.
    With the yellow top I've been really using it and I never felt like I was discharging it to much. It worked flawlessly for 5 years and then it just died. I jumped the car and drove to autozone for another.
    VS995 ?
    j12piprius likes this.
  19. bisco
    51,023
    this feature was one of the early adopters priorities, whereas deep discharging the oem (leaving a light on/door ajar etc) could basically kill it.
  20. Starship16
    1,348
    1,455
    Beach Christmas
    "We’re sorry we don’t have an OPTIMA® battery that will fit your particular make and model vehicle."
    That is what the Optima website tells me about my 2016 Prius.
