Driving on bad hybrid battery
Discussion in 'Gen 3 Prius Main Forum' started by Keepdriving, May 23, 2018.
  1. Keepdriving
    Keepdriving Junior Member
    35
    27
    Palatine
    Yes, must cleat the error code to drive normally. You could still drive but cruise control doesn’t engage and the ICE sounds like it’s gonna die if I try to push past 40mph. Also mpg sucks big time.
    jack black and Johnny Cakes like this.
  2. Keepdriving
    35
    27
    Palatine
    The hybrid battery must be on its last legs. Chs light came on 4 times during 15 miles of driving with AC set at the lowest setting. Made it home with ac off with no problem getting 53 mpg for those same 15 miles though. But definitely the battery is almost done, I think.
    DLC82SV likes this.
  3. Johnny Cakes
    Johnny Cakes Senior Member
    1,033
    772
    Virginia, USA
    Keep us posted -- I've liked reading this thread because so few people are willing to just drive a car into the ground, even when that is the best option. That you have gotten an extra year out of the car shows that it was a good decision.
    DLC82SV, dubit and PokerMunkee like this.
  4. PokerMunkee
    PokerMunkee Junior Member
    34
    Denver, CO
    I agree, keep us posted! Also what option you go with replacing it. I was quoted by a local place that they charge $2k for re manufactured battery pack. Surely there are cheaper/better options!
  5. Keepdriving
    35
    27
    Palatine
    It rained quite a bit last two days and I had on the lights, defogger, and wiper at the highest setting and the energy level went down from 7 to 2 in less than a minute. Turned off the defogger and set the wiper to intermittent setting and thankfully chs warning didnt come on. Also, this never happened before where the energy level showed 8 bars but since the chs first came on last year, several times it went all the way to the top. I guess it means not good. upload_2018-6-22_18-41-1.png
  6. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yes, as you've pointed out correctly this is the car subtly telling you it's sick. That battery is doomed. It may last another year though you just don't know. Lots of people, myself included, have run such sick Prii vehicles for 2-3 years before the actual failure lights come on. And in my case, I ran for almost 8 months after that before I replaced a module with just clearing the codes more and more often.
    If you love the car and want to keep it, start saving for a new pack. Either new from Toyota or new from me. Don't even bother with reconditioned/refurbished.
    If you are looking for a new car, now would be the best time to trade it in. When the dash lights up like a Christmas tree, the trade-in value takes a huge beating.
    DLC82SV likes this.
  7. Keepdriving
    35
    27
    Palatine
    What’s an actual failure light? Does the car not start then? If I could drive for another 2-3 years I would be very happy. Probably will go over 250k miles by then. This weekend drove over 140 miles at 52mpg. Other than the battery discharging very fast, mpg hasn’t really dropped. I do pulse and glide more than before though.
    DLC82SV likes this.
  8. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    An actual failure looks like your post #21 at the top of this page. I still wonder about intermittent connections, maybe corrosion on the battery, as an expended battery doesn't have the capacity yours seems to have when it it working. Also, I would expect a few more years out of a 2010. However, if you swap it out you will fix any corrosion. ;-)
  9. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Just re-read that you already had a failure 10-months ago. You're on its last legs then undoubtedly and the value has already dropped. So either keep it and fix it or sell it as junk.
    You should have seen this battery behaviour for the past 2-3 years just getting gradually worse and worse and worse. Then you get the code you got 10 months ago. You're driving on borrowed time. Eventually the codes will come back. And you will have to clear them weekly to keep driving, then daily, then it just won't move. Other faults like HV Isolation faults can strand you anywhere so make sure you have an OBDII reader/scanner/clearer with you. Driving on a known bad battery will make it run hotter. This can lead to the pack exploding, in the sense that the vent tops will forcibly blow off and release gas into the car and potentially the entire pack will start to deform and warp the assembly.
  10. Keepdriving
    35
    27
    Palatine
    Yup, that’s me. I had to clear the code 5 times in one day, 4 times within an hour period a few days ago with ac at lowest setting. Hopefully it will last me a few more months before I get a new car.
  11. Keepdriving
    35
    27
    Palatine
    I think it’s best if I just get a new car instead of spending more money into a car that has 210k+ miles. I just don’t like the looks of a newest Prius. Maybe certified older model Prius might be the way to go when the time comes.
    DLC82SV likes this.
  12. Ray Moore
    Ray Moore Active Member
    857
    52
    Inspiring story.
    DLC82SV likes this.
  13. Keepdriving
    35
    27
    Palatine
    A year ago today my chs light came on. Drove exactly 20k miles since. Battery discharges faster each day it seems, but as long as I have the energy monitor on, and make sure the battery is charging as I’m driving, so far so good. But chs light came on about 10 times last week when in the parking lot looking to park. Bad battery doesn’t like me going at 5 miles per hour.
    DLC82SV and bisco like this.
  14. Johnny Cakes
    1,033
    772
    Virginia, USA
    You are my hero! You are playing with house money right now.
    DLC82SV and davecook89t like this.
  15. JC91006
    JC91006 Senior Member
    16,639
    8,495
    Maybe you just have a bad gas cap
    m.wynn and DLC82SV like this.
  16. DLC82SV
    DLC82SV Member
    241
    119
    Dealers will do it for 2k now.
  17. DLC82SV
    DLC82SV Member
    241
    119
    So am I missing something? Why are all of you buying this techstream OBDII scanner? Does it clear something I can't from the MFD? I use the display button combined with flashing my headlights on the off 3 times and it brings me to a service menu on my center screen. I can view and clear my codes and voltage and everything right from there? Am I missing something or are you guys? 20180724_080916.jpeg
  18. DLC82SV
    DLC82SV Member
    241
    119
    ROFLMAO Or bad gas!
  19. Grit
    Grit Senior Member
    6,371
    4,159
    Wilkes Land
    Apples vs oranges.
  20. DLC82SV
    DLC82SV Member
    241
    119
