Slight damage - how to clean?
Discussion in 'Gen 3 Prius Main Forum' started by Oddfodder, Jun 25, 2018.
  1. Oddfodder
    Oddfodder New Member
    28
    Freiburg, Germany
    I'm a fairly new Prius Gen 3 owner - bought my used 2012, loaded with accessories a couple of months ago and absolutely love it.
    I'm not too happy at the moment though because someone must've backed into my car while it was parked. No note or anything, just some ugly black scuffing on the rear passenger side.
    I'm hopeful that I can clean the black away and also that the small dent that's there now won't be too noticeable if the black is gone. The car still drives perfectly.
    Any suggestion on how to try to clean it? Simply try soap and water with a soft cloth or does anyone know of something that might be better?
    Images are attached as an embedded media folder - I hope this is visible, looking at my post, I don't see them but hopefully everyone else can.
    Very appreciate for any advice!
    Thanks and best,
    Oddfodder
  2. JC91006
    JC91006 Senior Member
    16,656
    8,504
    Step up the cleaning process until it comes off.
    1 soap and water
    2. Wax and polish
    3. Clay bar
    4. Rubbing compound
    5. Possibly using a Buffing machine (without rubbing compound on the surface)
    If rubbing compound won't remove it, it's probably going to need a body shop
  3. Oddfodder
    28
    Freiburg, Germany
    Thanks JC. I was aware of points 1, 2, 4 & 5 as options but didn't know that wax and polish might clean that stuff off - good to know.
    I'm pretty sure it's the black from someone's bumper so hopefully it's not too difficult.
  4. JC91006
    16,656
    8,504
    Wax and polish does the least amount of damage, rubbing compound will start stripping the clearcoat. I don't like using rubbing compound unless it's totally necessary
    Oddfodder likes this.
  5. Oddfodder
    28
    Freiburg, Germany
    Cool info, thx. Crossing my fingers that soap & water does the trick!
  6. Mendel Leisk
    40,472
    Yeah, an old terrycloth towel rag with a dollop of of car polish. May get it all, should at least diminish it.
  7. PosauneGuy
    PosauneGuy Member
    119
    89
    California, here I come...
    2025 Prius
    I've had success with one of those scouring pads one uses for nonstick pans...they're also good for getting bugs off the front bumper and side view mirrors.
  8. Mendel Leisk
    40,472
    I'd be cautious with those, try on a hidden spot first. May take the gloss off, quite quickly.
    The worst mess was when I parked under a tree weeping sap. I used a kerosene wetted rag with a dab of car polish (non abrasive car polish, not cleaner wax) and took it one spot at a time.
  9. Oddfodder
    28
    Freiburg, Germany
    Thanks to all. Honestly, the scouring pad thing makes me kinda nervous. My wife has these "magic erasers" (white, blackboard eraser-sized foamy fads) that work wonders on pretty much anything. I'm thinking about giving that a shot - on a hidden area first of course - anyone tried that or have any input?
  10. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    A light spritz of WD-40 on a rag might do the trick, followed by gentle rubbing. Put some car wax on afterwards.
    Oddfodder and Mendel Leisk like this.
  11. WesleyG94
    WesleyG94 Junior Member
    Tucson, AZ
    Rubbing compound is my go-to. May not get it back to perfect but usually gets it looking good enough that no-one else will know!
  12. Mendel Leisk
    40,472
    The magic eraser is somewhat abrasive too. Again you could try, but start with a hidden spot.
  13. Oddfodder
    28
    Freiburg, Germany
    Thanks, never heard that one before.
  14. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Years ago with a previous car that was in perfect cosmetic shape when I got it, someone backed into it and left a perfect imprint of a hitch receiver in my back bumper. As in your case, no note. After fuming a bit, I told myself, "Oh well. It was gonna happen eventually. Now I don't have to wonder when." ;)
  15. RRxing
    2,530
    1,806
    NEPA
    I've used it before to remove some adhesive residue from when they take off the white plastic from newly delivered cars. Should work on the OP's black streaks as well. Worth a shot...
  16. Mendel Leisk
    40,472
    I wonder what's the main ingredient in WD40, might be kerosene?
    Yeah WD40's a good low volatility cleaner; I'll sometimes use it for hand cleaner, before the orange Gojo stuff.
  17. BZzap!
    BZzap! Senior Member
    1,607
    878
    Try using a lite application of headlight cleaning compound. It’s formula is about the same as 3M’s finishing polish, called “Finesse”.
  18. Mendel Leisk
    40,472
    I've got a couple of powders from my furniture refinishing episodes: pumice (quite aggressive, will take gloss off, leave it mat) and rottenstone (slick as snot, will bring it back to gloss). Just a thought, lol.
  19. Oddfodder
    28
    Freiburg, Germany
    clean_pri.jpeg Well, this is embarrassing - but I'd rather be embarrassed with a good outcome than a bad one :p
    So here I am collecting all this info from you guys (thanks again!) and without telling me, my wife goes out with a bottle of glass cleaner and a very soft rag. Two minutes later, the car looks great! But I got some great tips for the future, just hope I never need them.;)
    jerrymildred, RRxing and Mendel Leisk like this.
  20. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    I would re-wax the cleaned area.
    Glass cleaner can have ammonia in it and might be pretty tough on wax.
    But at least it worked.
    Basically, my advice in the future is to use and try automotive choices 1st. Forays into kitchen and bathroom cleaners and tools, are really unnecessary and potentially damaging.
    If your wife had used the wrong cleaner, or you had used a too abrasive pad? You could be talking about how minimal cosmetic, perfectly removable damage had become something much worse.
    Stick to the automotive aisle. Lots of good products designed to clean your vehicle. IMO no need to experiment with the same tools used to clean toilets or smudged bathroom mirrors.
    orenji, Mendel Leisk and Oddfodder like this.
