Scratched rear light panel?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by Khang H., Jul 2, 2018.
  1. Khang H.
    Khang H. New Member
    Hi Prime family,
    I scratched my rear brake light panel (the tail end) when it "touched" the parking garage ceiling. I should have known better :( I wonder if there's any recommendation for a DIY fix? I understand that it won't look perfect but any help is appreciated.
    Thank you in advance.
  2. schja01
    schja01 Senior Member
    1,815
    1,205
    Chicagoland
    2024 Prius
    Limited AWD-e
    Not sure how you touch a garage ceiling but I’d try rubbing it out with some fine grit rubbing compound.
    J
    Khang H. likes this.
  3. Khang H.
    Khang H. New Member
    It was my work garage parking and the hatch opened just to touch one of the lower bars of the ceiling - at least it was slow. Thank you for the tip, I'll give it a try!
  4. Weasle543
    Weasle543 Member
    55
    Ohio
    A headlight restoration kit should be able to work that out.
  5. Khang H.
    Khang H. New Member
    Thank you! I got a rubbing compound and it looks fine now :) 20180703_225030.jpeg
    schja01 likes this.
  6. prius4-me
    prius4-me Member
    58
    29
    Denver, Colorado
    Glad the rubbing compound worked. FYI - I always start with toothpaste first.
  7. Marine Ray
    Marine Ray Senior Member
    1,139
    944
    Sparks, NV
    Do you use toothpaste w/ flouride? To prevent cavities? :p
  8. prius4-me
    prius4-me Member
    58
    29
    Denver, Colorado
    Ha! You must think I was joking?? Actually toothpaste works surprisingly well when you need a very mild abrasive, especially the whitening toothpastes. The non-fluoride ones may not work as well since they are more likely to be 'natural' and therefore may not have the abrasive quality. Even cigarette ashes work on some applications such as removing permanent marker from white boards that are inteneded only for temporary markers! On a vehicle I would skip the cigarette ashes and start with toothpaste, then polishing compound if needed and as a last resort, rubbing compound.
    Marine Ray likes this.
  9. Mendel Leisk
    40,495
    I find Dupi-Color touch up paint flows good. has an abrasive pen too, that's handy for prep.
  10. Prodigyplace
    12,397
    11,676
    Central Virginia
    Not on a tail light!! :eek::whistle:
    #10 Prodigyplace, Mar 15, 2019
  11. Mendel Leisk
    40,495
    Yeah, I guess I didn't look too close.
    I had to do our spoiler a time or two, after garage door encounters. But it's just piano-black.
    Prodigyplace likes this.
