High Voltage Leak
Discussion in 'Gen 3 Prius Main Forum' started by franken1313, Jul 16, 2018.
  1. franken1313
    franken1313 Member
    216
    26
    US
    How do I check the high voltage battery and all its components for leaks? Would voltage leaks be found only from the cells?
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    The car does it every time the car starts. If you're talking about physical chemical leaking then just open the case and look.
    Raytheeagle likes this.
