OEM 2012-14 Toyota Prius C Receiver AM FM CD XM Capable Part Number 86140-52110 Please do your own research to make sure this item will attach to your vehicle. This is great to upgrade your current normal Radio (non-display) unit to one with a Screen, Navigation and Backup Camera! Or replace your current bad Prius C navigation system. Included with this unit are the following (MSRP noted to the left) RECEIVER ASSEMBLY, RADIO 86140-52110 - $2,387.70 Left and Right Display Unit Brackets - $22.56 GPS ANTENNA (Plug into the back) - $15 Axxess AX-TOYCAM2 Rearview Backup Camera Harness $15 Toyota Bluetooth Navigation Receiver Wire Harness 86842 WY010 $67 This was swapped out for a high performance system.
