18x9.5 +40 offset NT03 fit the Prime?
Discussion in 'Prime Accessories and Modifications' started by LaoBron Prime, Jul 15, 2018.
  1. LaoBron Prime
    LaoBron Prime Member
    44
    Fresno
    2018 Prius Prime
    Hi everyone new prime owner loving it. Came across these Enkei wheels at 5x100 pattern for cheap just wondering if they would fit our prime. I’ve searched and only seen 8.5 but not 9.5. Thanks
  2. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    No.
    Having said that,..... if you have enough time & money I guess almost anything is possible when talking cars.
    Rob43
    LaoBron Prime likes this.
  3. LaoBron Prime
    44
    Fresno
    2018 Prius Prime
    Aww darn thanks for explaining that to me
  4. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
  5. LaoBron Prime
    44
    Fresno
    2018 Prius Prime
    How about these rob? 17x7.5 +48 wrapped in 225/45/17. I’ve searched and got mixed answers with the frs stock wheels being the same size but not fitting without a spacer. But other afterMarket wheels do fit[​IMG]
  6. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    From a Performance / Handling standpoint, a 17x7.5" & 225/45-17 works quite well, steering response will feel sharp.
    Tire: a 225/45-17 is a very good choice because of its exact 25.0" diameter, plus it's also a great choice for a
    7.5" wide wheel.
    Wheel: a 17x7.5", 5x100 normally works well. My only concern is your +48 ET, this moves the tire/wheel closer
    to the strut by roughly 21mm's with this setup. You "might" need a 3 or 5mm spacer to move the tire/wheel away from the strut.
    Rob43
    benagi and LaoBron Prime like this.
  7. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Bought anything yet ?
    Rob43
  8. LaoBron Prime
    44
    Fresno
    2018 Prius Prime
    Yes I ended up buying Tony’s wedssport sa55M. 18x8 +45. I ordered some 5mm spacers to bring them out a little cause it looks a little sucked in.
    As for tires I might go 215/45 or maybe 225/45. I plan to lower it with just springs or maybe keep it stock height since it doesnt look too bad. any thoughts?
  9. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    For a 18x8" you want either a 215/40-18 (24.8") or a 225/40-18 (25.1"), give a lot of consideration to the General
    G-Max AS-05. Assess your lowering needs after you've had your new wheels & tires for a week or two.
    Rob43
  10. LaoBron Prime
    44
    Fresno
    2018 Prius Prime
    The 45 wouldn’t cover the GAp area more if I decide not to lower it?
  11. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Sure...
    But if you're using that logic, why not just go nuts & go to a 50+ series tire.
    Point is this: You Need To Stay At ~25.0" Inches Overall Diameter.
    Rob43
  12. LaoBron Prime
    44
    Fresno
    2018 Prius Prime
    Got it thanks for your help rob
  13. Nopho4u
    Nopho4u Senior Member
    1,007
    2,061
    Socal son
    old post but I think it would fit. rear of a gen 3 can handle 18x9.5 +43 (streched tire and rolled fender) and I imagine 3mm less offset might stick out a tiny pic but it's doable. This is amusing the gen 4 handles can handle the same specs
  14. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    That's the epitome of Not Fitting....
    The moment someone is forced to run a smaller undersized tire (typically not as safe) and then needs to get a rolled fender (more expense), this means it doesn't fit properly.
    Rob43
  15. Nopho4u
    1,007
    2,061
    Socal son
    I didn't know you were only recommending tire rack conservative "normal" people set ups.
    Pictured above are the following specs:
    F: 19x9J +43mm
    R: 19x9J +38mm
    a by 9.5 +43 is the same as a x9 +38 (as shown on the rear) I'm pretty sure if the original poster was considering that wheel he realizes it's semi aggressive. From the looks of it it's not even much of a streach (225 or even 235 or so being the barrel lips aren't even exposed)
  16. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Look if you're into rubbing, then go for it !
    But face the fact's of your supplied pic, the moment any passengers are put into that car it's gonna rub, nobody likes an ill working chassis that rubs.
    Rob43
  17. Nopho4u
    1,007
    2,061
    Socal son
    I don't even own a 4th gen. I'm just stating that one can go much more aggressive if they want. With the right suspension, tire set up, fender roll etc there won't be any rubbing. Of course that's a much more advanced set up then the plug and play conservative specs you are recommending or i'm sure the typical prius own would even want to go thru.
    Just another example of a more agressive set up
    FRONT
    19×8.5J INSET 33(LO) 18mm SPACER INSERT
    REAR
    19×9.5J INSET 31(LO)
  18. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Just like I said in post #2; "if you have enough time & money I guess almost anything is possible".
    Having said that, who wants to be forced to run the ridiculous amount of rear negative camber that's clearly visible
    in both of your pics.
    I'd guess that the rear camber on either of these cars is somewhere/roughly at ~neg 4 degrees, this creates all kinds
    of new issues.
    Rob43
  19. Nopho4u
    1,007
    2,061
    Socal son
    First car is stock camber. 2nd car is not.
  20. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Maybe it's the interwebs fault, but the first & second chassis looks like added neg. camber.
    Rob43
