2017 seat torx size
Discussion in 'Gen 4 Prius Technical Discussion' started by deathmage, Apr 23, 2017.
  1. deathmage
    deathmage Junior Member
    Los Angeles ca
    does anybody know the torx screw size of the front seat? My T40 is too small, so I'm guessing t55
  2. Mendel Leisk
    40,514
    Just get a set?
    kithmo and RCO like this.
  3. deathmage
    Los Angeles ca
    I do have a set. Just don't wanna waste money on another having the same ones. I know it's either t50, t55 or t60. I believe it's t55, but need confirmation. There are no info anywhere.
  4. Elektroingenieur
    2,515
    3,277
    Three Touring
    According to Toyota’s Repair Manual (available by subscription to techinfo.toyota.com), it’s a T50 TORX, for both 2016 and 2017 models. The seat bolts are supposed to be torqued to 37 N•m, in this order: front inside, front outside, rear inside, rear outside.
    Rather than a TORX key, the Repair Manual recommends a TORX socket, which can be used with a torque wrench. The seat’s attachment to the body may be important for its performance in a collision, so I’d want to be careful that the bolts are tightened to the specified value.
  5. deathmage
    Los Angeles ca
    thanks for the info. I bought the T55 and it was too big. So I went and order both T50 and T45.
    Elektroingenieur likes this.
  6. Scott Farnsworth
    Scott Farnsworth New Member
    Hi Deathmage - what size worked for you, please? Need to yank front seats on 2016 Prius Two. Tried the T-40 but was too small. thx
  7. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    Not sure if you'll get a reply in a hurry:
  8. Prodigyplace
    12,398
    11,676
    Central Virginia
    That's because post 4 said the documentation states it needs a T-50 TORX socket.
  9. padroo
    padroo Senior Member
    2,763
    2,251
    I haven't removed one but have seen locktite on seat bolts.
  10. Elektroingenieur
    2,515
    3,277
    Three Touring
    On my 2016, it’s definitely a T50, just as the Repair Manual says.
    I haven’t removed mine, either, so I can’t say what they do in manufacturing. The Repair Manual doesn’t mention the need to apply a thread coating or to use only new (and perhaps pre-coated) bolts, which it does for other fasteners that are non-reusable or require an adhesive.
    The torque specification (see post #4) is printed inside a double box, which Toyota uses to emphasize the “Tightening torque for ‘Major areas involving basic vehicle performance such as moving/turning/stopping.’”
    Prodigyplace and alanclarkeau like this.
