Why is it beeping??
Discussion in 'Gen 4 Prius Main Forum' started by Dizzypole, Aug 6, 2018.
  1. Dizzypole
    Dizzypole Junior Member
    Leeds
    2018 Prius
    Excel
    Had the car a week now and loving it, but every so often when driving it gives out a loud beep, but no messages on screens, sometimes it gives a lower level beep, again no message. Any ideas. Thought it might be lane departure, but not close to the lines. Thanks in anticipation.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    It's to remind you that it's related to an early Saturn Rocket.
    Seriously - not sure. I assume you're going forward? Do you have Blind Spot indicator - I don't so I'm not sure if it beeps? The Lane Departure will beep if you change lanes without indicating - or if you use the "3 blink" indicator and it finishes before you cross the lane.
    RCO likes this.
  3. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    272
    Harrisburg, PA
    Lane departure assist?
  4. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    Your microwave pizza is ready?
    RCO likes this.
  5. krmcg
    2,592
    2,391
    Whittier, CA
    The lane departure alert will give some false positives when you are not close to the stripes. The blind spot monitor is silent.
    alanclarkeau likes this.
  6. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    Not sure about this, but does lane departure assist beep if it loses one of the lane lines????
    #6 RCO, Aug 7, 2018
  7. alanclarkeau
    7,045
    7,589
    No - I think it just forgets what it went to the kitchen to get.:sneaky:
  8. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    Ok, I've morphed into a lane keeping assistant then. :ROFLMAO:
  9. alanclarkeau
    7,045
    7,589
    Hmmm - maybe I need one - I have mainly driven alone for 18 years now. Not that she ever nagged, actually - just good advice.
    jerrymildred and RCO like this.
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,798
    2017 Prius c
    If it is loud, it more likely is the "crash avoidance" alert.....which probably should be accompanied by some red lights flashing.
    If you are in the habit of rolling up to objects ahead of you with your foot off the brake.......stop doing that.
    It is easy enough to test the lane keeping feature. Just turn it OFF for a while.
  11. Jeppefinn
    Jeppefinn Active Member
    121
    139
    Espoo, Finland
    On mine (2016 excel, called Premium here) it beeps for traffic cameras automatically, switch to your map view so you can see the camera icon pop up in the lower right part of the sceen so you can see if that's what it is.
    It's pretty loud sometimes, I'm guessing it is the same volume setting as with RDS warnings.
    #11 Jeppefinn, Aug 7, 2018
    kithmo, RCO and StarmanUK like this.
  12. Mendel Leisk
    40,514
    Hmm, our aftermarket Garmin does that too, could be.
  13. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    It'll also beep if you've set speed limiting cruise control and you exceed the speed (e.g. going down hill).
    If you have Speed Cameras turned on in the Sat Nav it'll beep whenever one is coming up.
    kithmo and RCO like this.
  14. kithmo
    kithmo Couch Potato
    2,404
    2,774
    47
    South Yorkshire, UK
    Yep, I'd guess fixed speed cameras too. IIRC there are two different beeps, one to tell you there's a camera coming up and a different one if you're over the limit on approach.
    Jeppefinn likes this.
  15. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    Me? Over the limit, hic! I don't think so hic Officer! The Bartender assured me it was non-hic-alcoholic whisky!
    kithmo and alanclarkeau like this.
  16. Dizzypole
    Leeds
    2018 Prius
    Excel
    Thanks peeps, I’ve figured the loud one is the speed camera, just foxed me as there wasn’t one on the road I was travelling, but was on the road under the bridge. The other may be the lane departure, but it seems to go off when no lines...
    Jeppefinn and RCO like this.
  17. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    Was that in the way I thought at post #6?
  18. krmcg
    2,592
    2,391
    Whittier, CA
    Yes, and my "false positives" in post #5.
    RCO likes this.
