Tires: Anybody have Michelin Premiers?
Discussion in 'Gen 4 Prius Main Forum' started by Starship16, Aug 11, 2018.
  1. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    PRIUS FOR SALE! I'm going Ford tough.... I won't care if a big truck is noisy. :D
    (Yeah, yeah... I know. Go ahead and DO let the DOOR hit me on the way out!)
    #21 Starship16, Aug 11, 2018
    padroo and Since2002 like this.
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    You can get the same effect by swapping them L > R & R > L - that'll reverse the rotation.
    One thing I've noticed is that rotated tyres are often noisier for a 1000km or so till they bed into the new wear pattern for the wheel position.
    RCO and Starship16 like this.
  3. ChapmanF
    18,067
    I have found mine (on Gen 3) very quiet, comfortable, and sure-footed, overall very nice to drive on, but some of the edge came off my enthusiasm when I checked the treadwear just recently and found them pretty much on track to be done at 40,000 miles, rather than the 60,000 advertised (and that's with very conscientious inflation, etc.).
    That bumps the price a good bit in terms of cents per mile or dollars per year....
    -Chap
    Starship16 likes this.
  4. Starship16
    1,348
    1,455
    Beach Christmas
    Thanks Alan. I can do as you suggested, that's easier. I guess I don't really need to put the front tires on the back. And it's been 3,000 miles since the last rotation. I thought they got a little quieter for awhile, but now they seem even louder! It's crazy. Makes no sense!
  5. Starship16
    1,348
    1,455
    Beach Christmas
    That's right Chap. I saw several reviews, and people said they got much less treadwear than advertised. But of course, we don't how they drive, or if they check the tire pressure, etc.
    #25 Starship16, Aug 11, 2018
  6. robsnyder20
    robsnyder20 Active Member
    377
    302
    SW Florida USA
    I had the Hydroedges on my previous car and even though they weren't noisy they did a horrible job gripping the road, especially in the rain, expecially after having them for roughly 30k miles (In Florida we have thunderstorms nightly in the summer). Anything above 45+ MPH in decent rain caused me to death grip the wheel. I got them swapped out for the defenders. Took a mileage hit but at least I could drive in the rain comfortably.
  7. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    It's possible they revised them from one year to the next due to complaints like yours, and you have the pre-revision ones...
  8. Starship16
    1,348
    1,455
    Beach Christmas
    Thanks. It's just a very odd situation. After only 12,000 miles, today I noticed that the outside edges of all 4 tires appear to be showing excessive wear already... wearing faster than any other tire I've had. Tomorrow I'm having one last rotarion done. After that, I'm done with it.
  9. alanclarkeau
    7,045
    7,592
    I'm not sure about in USA - but sometimes the companies source tyres from different factories. I well remember getting a pair of Michelins and thinking they were different sound and feel from the previous pair (VW Microbus '70s). When I mentioned it to the tyre shop, he went and looked - oh, they're IRISH, the previous ones were ??French I think??. He said different batches of tyres, being organic, will often have slight differences.
  10. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    Starship, I guess you're on top of the inflation? Got them at the recommended 36/35 psi from a quality tire gauge?
    Wear at the edges like that usually points to under inflation and\or cornering hard.
    But anyway, if they're starting to wear out, maybe that's the answer to your prayers.
    For my part, I just hope the OEM tires are OK in the rain this fall and snow this winter... I'm not expecting miracles, since they're low rolling resistance type.
  11. Starship16
    1,348
    1,455
    Beach Christmas
    Thanks. I am actually a very conservative driver. No hard cornering. And the PSI is just three over the factory specs. I am at the tire shop right now. And all this new rubber sure smells good!:LOL:
    Edit: rotation completed. A big X pattern. Now everything is rolling in the opposite direction, and on opposite axles. And the "placebo effect" is already setting in. I drove 20 miles, some of that on the freeway, and I would say the tires are 50% quieter.
    I had him set the psi at 40 on all tires. He tried to talk me out of it -- he said that might be what's causing the noise. (But it's not the PSI. I also drove with them set at factory 36/35. Still noisy.) So I am done! Now we can bury this thread. Thanks to all who replied.
    #31 Starship16, Aug 14, 2018
    Mendel Leisk and krmcg like this.
  12. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    You're wrong to have him over-inflate the tires. If I were him, I would not have done it. Toyota knows what they're doing when the set the specs. Factory inflation specs give the best balance of economy and performance. If you over-inflate them, you may get a tiny increase in fuel efficiency, however, your traction (including braking and wet/snow acceleration and road-holding) will be decreased. You will also wear the center of the tires faster than you should.
    Congrats on the new tires. Do yourself a favor and deflate them to Toyota specs.
    quantumy and RCO like this.
  13. Starship16
    1,348
    1,455
    Beach Christmas
    You know you just opened up a HUGE can of worms, right? :ROFLMAO: I think 99% of the Prius owners on this website, add extra air to their tires. Even the founder of the website has a blog that he wrote, touting all the benefits of over inflation. Have you seen the dozens of tire pressure threads here?
    I don't do it for any extra mpg, I just do it so I don't have to check the tires as often. :D ;)
    In 45 years of driving, I have always added four or five extra psi to the tires. And they have been fine. No unusual wear or performance problems. And the "natural bleed" brings them back down to normal eventually.
    But on the other hand, there is nothing wrong with keeping the tires at factory specs. Just personal preference, I guess.
    alanclarkeau and krmcg like this.
  14. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    I used to think it was smart too, then I crashed my motorcycle in 2009 and broke my leg in 3 places, thanks partly to over-inflating tires. I could've been killed. Higher inflation = smaller contact patches = less traction in braking, turning and accelerating. There's no two ways about it. Softer tires give better traction, as long as the sidewalls aren't rolling or the center isn't caving in. It's just an economy thing.
    Some of my fellow motorcyclists put car tires on the rear of their bikes and it's a whole sub-group who are fed up with only getting 6,000 miles out of a $150 tire. So they "darkside" their bikes and get 50k+ miles and most of them manage not to crash. I can only guess because they don't lean very far. I opened a can of worms with them, and fought as long as I could to try to get people to listen to the engineers. It's a safety issue.
    The natural bleed is because Schrader valves weren't designed for very high pressures. Maybe 30-35 psi. I had them on my last bike; it was a bummer. I had to re-inflate them to 75 psi every week. (they lost about 20 psi per week) My new bike has Presta valves, and there's hardly any leakage any more.
    Back to the car. Less traction means longer stopping distance, since ABS will kick in sooner due to tire lock-up. It might mean the difference between crashing or not, or between injury or not or between life or death.
    But hey, if you chuckleheads want to over-inflate for that extra 1-2 mpg and tell yourself you know more than the automotive engineers, it's your life and your car.
  15. krmcg
    2,592
    2,392
    Whittier, CA
    Different opinions. Most people agree to disagree - but some just know that only they are right.
  16. Starship16
    1,348
    1,455
    Beach Christmas
    Well, I've been called a lot worse in my lifetime. Chucklehead? :LOL:
    Update: From the mountains, to the sea, and to all of Southern California... a good evening.
    Drove 105 miles. Temp was 85 degrees. Went on several of the worst roads. And a lot of smooth streets, and also a few miles on the freeway. I would say yes, the tires are now at least 50% quieter. That's good enough. I am never touching them again! :ROFLMAO: I hope this placebo effect lasts for awhile.
    The tires are now running in a different direction, on different axels, and on different corners. Case closed!!:cool:
    "42 is the answer to all things in the Universe."
    Priuschat member ETP
    #36 Starship16, Aug 14, 2018
    RCO, Smaug1, krmcg and 1 other person like this.
  17. alanclarkeau
    7,045
    7,592
    My only major accident, I'd been on a long drive (5000km), pressures were up by 4 or 5 psi. Partly because I had a reasonable load and higher speeds, but the grip was appreciably improved.
    When I returned, I put my car in for a service. They reduced my pressures to factory suggestions. 2 days later, I lost traction on a bend due to the poorer grip, slid into a spoon drain and rolled. No injury. But after repairing, the pressures went up again.
    krmcg likes this.
  18. alanclarkeau
    7,045
    7,592
    I'm not sure that you can make a widespread suggestion on the basis of a motorcycle experience. They are slightly different from a PRIUS, the chassis is different for a start, and handling is quite different.
    krmcg and Starship16 like this.
  19. Smaug1
    Smaug1 Member
    135
    95
    Chicago suburbs
    2018 Prius
    Good point, but in both bikes and cars, over-inflating causes a smaller contact patch, which equals LESS traction, unless the tire is severely under-inflated.
    Fact: Race cars and bikes run lower tire pressure for this reason. (and because they're generally not as concerned with fuel economy as with grip)
    RCO likes this.
  20. Starship16
    1,348
    1,455
    Beach Christmas
    I won't mention that I'm also running Premium fuel...:eek:
    - Drive mode in "PWR"
    - Shell V-Power "Nitro" premium gas
    - Chevron Techron fuel additive
    - Mobil-1 5W-30 full synthetic oil
    - Tire PSI at 40 on all tires -- Michelin Premier A/S Total Performance -- (bring earplugs :LOL:)
    (I've gone over to the dark side. I will leave my Priuschat membership card at the door on my way out)
    #40 Starship16, Aug 15, 2018
    krmcg likes this.
