100,000 service
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by domtick, Aug 17, 2018.
  1. domtick
    domtick Junior Member
    Middletown. Delaware
    My 2012 is coming up on 100,000 miles. I know the dealership will want to squeeze ever penny out of me. What really needs done?
    51,013
    i think nothing. check the maintenance schedule that came with your car, don't listen to dealer recommendations.
  3. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,497
    1,593
    Bay Area
    Nothing major till 120k, which will involve
    Engine and inverter coolant drain and refill. Engine oil replace
    Engine and cabin air filter replace
    Transmission drain and refill
    Brake flush
    Brake inspection
    Brake sliding pins lubing
    You can do these minor maintenance such as
    Throttle body cleaning
    Egr system cleaning
    Pcv replacement
    Hv battery fan cleaning
    Not sure what else I miss.
    All of these can be found on my YouTube channel if you want to do it yourself and save money on labor.
    Rebound, Robert Holt and Raytheeagle like this.
  4. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    If you go through the NutzAboutBolts videos, you’ll see that you can tackle most of those projects yourself. If you do one every month or two, you’ll have it done by the time the car hits 120,000 miles.
    I found that the Prius is a very easy car to work on. I’d begin with the Prius Engine Cleaning video which NutsAboutBolts posted. Easier to work on a clean engine.
    Raytheeagle, RMB and NutzAboutBolts like this.
  5. Mendel Leisk
    40,457
    Why is this so hard? (n)
    Anyway, the usual, plus the engine coolant (not the inverter):
    BTW: @bisco has gone over to the dark side, lol.
    Raytheeagle and bisco like this.
  6. bisco
    51,013
    mendel, i am your father :sneaky:
  7. Rebound
    3,972
    2,626
    Portland, OR
    You missed spark plugs at 120k
    Raytheeagle and NutzAboutBolts like this.
  8. NutzAboutBolts
    1,497
    1,593
    Bay Area
    Thanks! Its exhausting repeating myself lol
    Raytheeagle likes this.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Shouldn’t your mask be black then;).
    Or are you just happy being one of many and blending in:whistle:?
    At least you didn’t choose General Grievous(y).
