Actual puddle lights installed
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Depe, Aug 18, 2018.
  1. Depe
    Depe Junior Member
    33
    Tennessee
    Four Touring
    I’ve had these installed for awhile now. They are OEM puddle lights that you can get off of the new Nissan/Infiniti cars and not a cheap set from eBay. Wiring is just like OEM, in which I ran them to the drivers side a pillar. They activate when you open the doors and/or when you walk up to the car and the courtesy lights light up
    krmcg, Starship16 and padroo like this.
  2. padroo
    padroo Senior Member
    2,763
    2,252
    How are they mounted?
    Putting anything under a car in the rust belt has to survive winter slush and snow.
  3. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    They look very nice. (Be careful if you have to jack up the car to change a flat.) Great picture, I wish the rear tail lights were really that bright. :)
  4. Depe
    Depe Junior Member
    33
    Tennessee
    Four Touring
    The are mounted to the side skirts. Holes were drilled for the light. Then 2 mounting holes were drilled per light and held in with oem nissan clips lol
    No worries sir. I do all my own work and made sure to mount it away from the jacking points. Also I will never jack up the car any where along the sides.
    #4 Depe, Aug 18, 2018
    Starship16 likes this.
  5. Starship16
    1,348
    1,455
    Beach Christmas
    Looks great. I wish I had that kind of installation skill. (And I hope I never have to use that little scissor jack that came with my car. :LOL:)
  6. dml996
    dml996 Junior Member
    Spartanburg, South Carolina
    how did you wire them? Where is the switch?
  7. Mendel Leisk
    41,305
    You should do a dry run, see what you're in for. The link between the torsion rod and the jack is a cast eye: the torsion rod crook dances around like crazy with every turn. And the metal is very soft, starts getting chewed up right away. Looks like this:
    It's the single eye design that makes it so unstable. Honda (OTOH) uses a bent-plate in a U-shape, with two holes, which keeps it much more stable as you turn:
    Sorry for being off-topic, can't resist a rant.
