Show off your Rims
Discussion in 'Prime Accessories and Modifications' started by 5herw1N, Mar 27, 2018.
  1. dalecooper
    dalecooper New Member
    24
    Columbus, OH
    2018 Prius Prime
    When you start your car on a full charge, how many EV miles are you seeing? Before rims vs after. Also, if your commute is 30 miles roundtrip, I'm guessing you must drive around 50 total miles per day to get that ~110mpg average.
  2. slothsandwich
    slothsandwich Junior Member
    27
    Denver
    2018 Prius Prime
    Found this pic online so obviously not my stats but what should I be looking at to see "how many EV miles"? Screen Shot 2018-08-21 at 12.37.09 PM.png
  3. triggerhappy007
    triggerhappy007 Active Member
    498
    334
    The number right above the EV car.
  4. dalecooper
    24
    Columbus, OH
    2018 Prius Prime
    Yours may by default be displayed as a % - you can change that to show the actual miles estimated. I think you can also view it in one of the menus on that screen if you keep arrowing down. Surprised you haven't looked at it, I'm fixated on it every day as the car is sooooo much better on ev!
  5. slothsandwich
    27
    Denver
    2018 Prius Prime
    I had it on percentage which I watched like a hawk but not that I have it on mileage, I can better see how many miles I'm getting out of each EV drive. This pic was taken this morning right after I left the garage on a full charge. Not sure what trip I had selected here to show AVG 999.9 MPG, ha ha ha, I typically have my trip set to standard odometer and Average MPG
  6. slothsandwich
    27
    Denver
    2018 Prius Prime
    Took this pic after adjusting my trip readout and arriving at my office. IMG_2663.jpg
  7. burnout8488
    burnout8488 Member
    124
    81
    Endwell, NY
    I use 8-10% more EV battery percentage on my 17" wheels versus the stock 15s. It's a big hit considering I don't need to use fuel on my commute, but with 17" wheels I do.
  8. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    You should !
    toyopri808 likes this.
  9. slothsandwich
    27
    Denver
    2018 Prius Prime
    @burnout8488 - That is about what I would guess I lost by plus sizing to 17". Is it worth it? NOOOO. Do the OEM 15" wheel look like a dumpster fire? YASSSSS.
    dalecooper likes this.
  10. toyopri808
    toyopri808 Active Member
    226
    116
    Thats crazy considering you have RPF1s! That's the wheel I have my eyes set on too, but specs similar to @Munch's
  11. burnout8488
    burnout8488 Member
    124
    81
    Endwell, NY
    Yep, they're pretty light for 17s but the 15s are sooo much lighter. If I had 17" eco tires it'd probably be a bit better though.
    I love how it drives on these tires though, very sharp steering and less body roll.
  12. JspecPrime
    JspecPrime Member
    68
    37
    L.A.
    2018 Prius Prime
    Just bought my new... Brand used wheels. Gonna install them after I get my Work lugnuts IMG_0846.jpeg
    Penny6 and benagi like this.
  13. Jer707
    Jer707 New Member
    Bay Area ca
    2018 Prius Prime
    Konig Dekagram’s 215/50/r17’s!
    Travis64 and slothsandwich like this.
  14. Rob43
    Rob43 Senior Member
    1,373
    1,048
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Looks real good, your wheel is nice n light at 16.83 lbs (y).
    Rob43
    don_chuwish and Jer707 like this.
  15. Salamander_King
    Salamander_King Senior Member
    11,014
    8,942
    New England
    OK, everyone in this thread is showing off lager than stock custom wheels mainly for looks. I was looking for winter wheels for snow tires. Went to Discount Tire Direct online, and got this wheel (MB Icon) with Michelin Xice Xi3 for less than $500 total (tires, valves, and wheel, including lugnuts, mounted and balanced, shipped free). With sale and rebates, this 15 inch alloy wheel was cheaper than steel wheel and much lighter. Have not put on yet. No snow on ground, though yesterday low temp was down to 32F.
    #95 Salamander_King, Sep 26, 2018
    don_chuwish, benagi and slothsandwich like this.
  16. Mark57
    2,945
    2,740
    OK
    Probably from the extra 5 drilled lug holes.;)
  17. slothsandwich
    27
    Denver
    2018 Prius Prime
    I can't imagine dual drill would shave that much weight, ha ha
  18. INFINIT tony
    INFINIT tony Member
    60
    97
    SGV
    I know these rims. Did you buy these off Anthony?
    JspecPrime likes this.
  19. toyopri808
    226
    116
    Enkei RPF1 - build thread coming soon :)
  20. h22fastback
    h22fastback Junior Member
    Massachusetts
    That looks great, what are the specs on the rpf1?
    Btw: where did you get the window visors from?
