Rust on rear hatch handle
Discussion in 'Prime Main Forum (2017-2022)' started by Flaming, Aug 28, 2018.
  1. schja01
    schja01 Senior Member
    1,815
    1,205
    Chicagoland
    2024 Prius
    Limited AWD-e
    Stainless Steel. YES !!!
  2. Mendel Leisk
    40,493
    They know what it is, use it for the EGR cooler. :)
  3. bisco
    51,038
    but they would have to reduce the mpg then.:unsure:
  4. mdhare
    mdhare Member
    59
    33
    Madison, WI
    Premium Manufactured 12/16, appears to have plastic.
    Flaming, Mendel Leisk and bisco like this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Only thing worse than road salt is living on a small island. My Nissan Frontier went to the body shop at least once a year over the 7 years we owned it. Mostly minor stiff, but once for an almost complete disassembly. Thankfully, labor is cheap there.
    And I had it pressure washed top and bottom and waxed at least every two weeks. One time, the guys discovered that the frame was almost rusted through and it was on the verge of folding just about under the driver's seat.
    Starship16 likes this.
  6. Flaming
    Flaming Active Member
    138
    122
    QC , Canada
    Technology
    if it's possible , would you kindly show us a picture , thx !
  7. bresna
    bresna Active Member
    193
    144
    Southern Maine
    Mine is slightly rusted as well. I don't think it's bad enough to worry but it might continue and that has me worried. :)
  8. Flaming
    138
    122
    QC , Canada
    Technology
    On a new car , the bodywork warranty is 60 months , so why accept this ? '' slightly rusted '' is already too much and unacceptable.
    if my car was 5 years .. ok but the car is 1 year old. So .. nop. I will have this repaired by Toyota.
    Trollbait likes this.
  9. Washingtonian
    Washingtonian Senior Member
    726
    621
    It is not actually the "rear hatch handle". It is the steel frame that the handle is attached to. The handle is some kind of rubber coated material. I wonder how easy it is to remove and replace the steel part that rusts?
  10. Rightrudder
    Rightrudder Member
    49
    59
    Nazareth, PA
    Got my Advanced on 1/27/17 and my handle is plastic. Odd that they would change it to metal in the later models.
  11. Flaming
    138
    122
    QC , Canada
    Technology
    thx for your input. yes, surely something happened in the assembly process at the factory.The fact that Toyota in Japan has requested that two rear hatch from Canada to be shipped to them for analysis seems to suggest that this is a ''mistake'' . Perhaps this story will end with a Technical Service Bulletin and Toyota will replace the part by consumer request if the issue is present.
  12. DavidA
    2,341
    1,818
    Chicago western burbs
    Mine was built in late May 2017. The metal backing plate does not show rust. I also have low mileage (less than 10K), so it might show rust eventually.
  13. bb4srv
    bb4srv Active Member
    140
    107
    2018 Prius Prime
    Technology
    Mine was built in Jan 2018. That piece is metal and confirmed with a magnet. Waiting for it to rust and have a new hatch :)
  14. schja01
    1,815
    1,205
    Chicagoland
    2024 Prius
    Limited AWD-e
    You do realize the paint will not match the rest of the car.
  15. Flaming
    138
    122
    QC , Canada
    Technology
    new hatch ? .. nop .. at best If it ever happens, it will be replaced by a plastic part .. that's what I was told at the dealer .. my part is on order.
  16. Mendel Leisk
    40,493
    Remove it in advance, spray it with matt-black PlastiDip?
  17. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Maybe but not necessarily. A high quality paint technician can match color and metallic effect very closely by doing a test sprayout then tinting the paint as needed. Experienced technicians can do this by eye, but spectrophotometers are also quite common now in higher end bodyshops. The spectrophotometer reading is input into software which then tells the technician the exact paint formula to mix up. It's not foolproof but it does reduce the amount of hand tinting needed. Also since a bodyshop is typically lighted with fluorescent (or now LED) lights, to make sure that it will look good in sunlight, a good paint technician will inspect the color and metallic flake using a "sun gun" which is a powerful flashlight that duplicates outdoor lighting. And they will hold the sun gun at different angles to the panel because color and effects look different at an angle compared to straight on. If they don't do this, the paint will seem to match when you are standing in front of the door, fender, etc. but later when approaching your car from an angle you will see a difference.
    As a final trick a high quality shop when they do the final coat they will purposely overspray onto adjacent panels using a fadeout spray technique, resulting in a gradual transition from the new paint to the old, which is very effective in hiding any small differences in color that remain. However car paint is very expensive so lower quality shops don't do this.
    But to your point, yes if the shop has less experienced paint technicians who just mix up the standard formula then spray it without doing a test sprayout then yes there is a good chance it won't exactly match.
  18. geguia
    geguia Active Member
    210
    108
    los angeles
    hopefully you get a new car. I wouldn't be caught dead with that rust.
  19. Mendel Leisk
    40,493
    We're redoing a bathroom, and I brought in a small paint chip, less than a square inch, for paint match. She put a contraption on it, pressed a button, and mix up a gallon.
    It's moot in the bathroom I'm redoing, it's a complete repaint, but yesterday I was doing some touch-up in the adjacent bathroom, same colour I was hoping, just some fist-sized zones. Primed it first, then brushed on some of the matched paint, and made a point to use just enough paint, and keep brushing outward, letting the brush dry up, feathering it out.
    Just one coat so far, and it's virtually disappeared, I'm having a hard time finding the repair zone, lol.
    Not readily visible, but I found the framing and bolts on the car's underside hopelessly rust-prone. Everything has rust-bloom, very fast.
  20. Trollbait
    12,320
    Plasti-dip will wear off if the hatch is regularly opened as finger tips hit the piece; use regular paint.
    The factory coatings are too thin, or the piece back and edgings didn't get painted at all. My guess is the edge where salt can get caught is the weak point.
