Rear lights gen 3
Discussion in 'Gen 3 Prius Accessories and Modifications' started by taxicraig, Aug 14, 2018.
  1. taxicraig
    taxicraig Junior Member
    GB
    Does the rear lights from a facelift 2012 gen 3 fit and work in a pre facelift 2010 .thanks
  2. MagnusAG99
    MagnusAG99 Senior Member
    673
    521
    Norway
    Yes they work, its the same connector on face lift model
    James Powers likes this.
  3. Radiospank
    Radiospank Member
    166
    77
    this is great news because I really love those 2012 hockey stick tail lights much better than the 2010 ones.
    Robert Holt, Grit and MagnusAG99 like this.
  4. MagnusAG99
    673
    521
    Norway
    U can get aftermarket taillights that looks even better for a lower price tho, there is loads of options, crystaleye got some, valenti got some, spec-D got some and some more.
    James Powers and Radiospank like this.
  5. longdrive352
    longdrive352 Junior Member
    Jacksonville, FL
    Are the aftermarket lights still as bright as the originals ? I really want to upgrade to an all LED smoked version, but I worry that the LEDs for the brakes and turn signals may not be as bright as the factory lights. Recommendations ?? I have a 2010 Winter Gray.
    Burna J likes this.
  6. MagnusAG99
    673
    521
    Norway
    Theyre WAY brighter than the stock taillights... The stock tailights r crap compared to Valenti, Valenti is full LED, the rear indicators r bright AF, same is the brake lights , and the normal lights. Here is a few pics of mine. They wouldnt have gotten SAE, DOT and ECE certified if they were not bright enough.
    Robert Holt likes this.
  7. Grit
    Grit Senior Member
    6,571
    4,223
    Wilkes Land
    Could be brighter, but will the LEDs be reliable and last longer than stock LEDs? If not, you'll have to buy another set.
